Morgan Aero 8
Who's Online
3 registered (DougalC, Shooter, Draggin), 80 Guests and 63 Spiders online.
New sump guard
Hire Car in Switzerland
Test
Loch Ruthven to fort Augustus
AR in Scotland (and 11 other Morgans)
free entry to Legends of Brands Hatch Superprix
by A11OGE
19/06/18 06:07 PM
brake light
by B3MOG
19/06/18 03:37 PM
Yet another Satnav mounting..
by Stringers Best Mate
19/06/18 03:13 PM
Small job I wish I hadn’t started
by IcePack
19/06/18 02:59 PM
polishing[img]https:
//www.tm-img.com/ima
ges/2018/0
by B3MOG
19/06/18 02:58 PM
Another variant for an additional brake light
by Michael P
19/06/18 12:44 PM
Fuse box
by madmax
19/06/18 10:27 AM
ithinkibrokeit, Martin1965, chrisdee, KevinMcR, dutchie
6064 Registered Users
Shout Box
Forum Stats
6,064 Registered Members
33 Forums
32,153 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 3 of 3 < 1 2 3
Topic Options
#481374 - 07/11/17 03:12 PM Re: A Surprise...of the wrong sort. [Re: milligoon]
Peter J Offline
Formerly known as Aldermog
Loc: Salisbury, UK
Originally Posted By milligoon
Do you leave it on a battery conditioner for long periods of time?
No, mostly not on the trickle charger, usually only if I know it is going to be a couple or 3 weeks before the car is used.
Most of the fluff was white anhydrous copper sulphate, the blue was only under the clamp.
So, likely either the battery is being overcharged by the alternator, or the battery is overheating from the engine bay temperature, or it is simply tired.
_________________________
Tarka the 'Otter Mog
2014 Plus 8
Top
#481411 - 07/11/17 06:21 PM Re: A Surprise...of the wrong sort. [Re: Peter J]
twotribes Offline
Loc: Kent & Dorset, UK
Originally Posted By Peter J
Originally Posted By twotribes
Has your battery still got a little rubber transit plug on one side at the end? If this is not removed on installation, temperature changes could cause pressurised vapour to release where the terminals pass through the casing.
Stuart, I can't see such a plug, could you take a photo to show me where I should be looking?
Hi Peter, I don't have the car with me (it's being prepped awaiting its new owner) so sorry, no photo.
Pretty sure my battery was an Exide Premium and the breather/plug is at the RH end of the battery as fitted in the engine bay (ie the end with the -ve terminal if your car has the same engine bay layout as mine, with the battery fitted 'wrong way round' to get the terminals facing inwards). The rubber plug sits in a 7mm hole located centrally at the very top of the end vertical face of the battery. There was a delivery sticker when new saying the plug must be removed. Indeed, there is a similar hole at the other end of the battery, blanked by a black plastic 'top hat' insert which remains in place. Of course, if your battery is a different brand, I've no idea whether other manufacturers have this breather/plug or not.
Stuart
Top
#482677 - 13/11/17 08:18 PM Re: A Surprise...of the wrong sort. [Re: Peter J]
DaveW Offline
Loc: South Yorkshire
On the matter of anhydrous copper sulphate...............
Over the weekend, our electric shower went cyclical - rapidly shifting from icy cold to red hot with constant water flow.
An internet search suggested the thermostat which sits on top of the plastic water tank, which has a copper top. The thermostat simply sits on the copper top, surrounded by wires.
On inspection I found a big growth of white powder around the thermostat. I cleaned this off using a screwdriver, WD40 and the vacuum cleaner. Hey presto - normal service is resumed.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#482843 - 14/11/17 04:35 PM Re: A Surprise...of the wrong sort. [Re: DaveW]
madmax Offline
Loc: East Anglia
Good job its not on an Aero !
Top
Page 3 of 3 < 1 2 3
