Who's Online
4 registered (Watty, petemog, John Winn, Malcolm T), 124 Guests and 11 Spiders online.
out today
Turbo Plus 4 - final report
Sunny Shropshire!
As Ordered
Spring in Norway
Cockpit canopy
by Bonesie
26/04/19 06:30 AM
Aero Screens... not fit or not to fit
by pete757
26/04/19 01:50 AM
Longterm Storage
by Michael H
25/04/19 10:57 PM
Looks familiar
by Gambalunga
25/04/19 10:27 PM
Have you deleted your Google search history?
by Gambalunga
25/04/19 02:24 PM
Ecoboost Plus 4 - postscript
by griffo
25/04/19 01:25 PM
Liberation Day (Italy)
by Gambalunga
25/04/19 10:54 AM
Andy Hatch, Toyracer59, Roxy Plus4, RobCol, Rsglush
6471 Registered Users
Shout Box
Forum Stats
6,471 Registered Members
33 Forums
34,873 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
adrian, Brian Martin, olive64, urs
Page 3 of 3 < 1 2 3
Topic Options
#484106 - 20/11/17 03:20 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
Richard Wood Offline
Loc: East Harling, Norfolk UK
Originally Posted By Draggin
You would have to have the old style lugs welded to the frame for the rear bevel box mounts.
Something like this maybe innocent
No NVH bar to remove, but then no NVH.
_________________________
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#484111 - 20/11/17 03:34 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
Draggin Offline
Loc: Detroit, Michigan, USA
Yes that would work.
Boys I am so sore today I can barely move. what a workout that was, 10x more involved than I bargained for! But I do know my car a lot better!
kirkusblog.com
1968 Honda CL175,and 2012 Enfield for sale
Top
#510230 - 25/04/18 12:54 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
Draggin Offline
What drive belt tension are you running? Either in degrees of "twist" or in MM of deflection?
kirkusblog.com
Top
#510232 - 25/04/18 01:30 PM Re: Help immediate assistance needed rear dampers [Re: hbatts]
Bunny Offline
Loc: Leicestershire, UK
Originally Posted By hbatts
Can the NVH bar be removed and not used? Will be getting a new chassis for my 2012. I guess what I'm asking is the NVH now an integral part of the new chassis. I've never had any complaints about BB noise and don' need the extra weight of the NVH
Speak to Phil Bleazey. He can supply a kit that does away with the NVH hardware and replaces it with a couple of neat brackets that mount the BB direct to the chassis. It's the 'Stage 1' kit at this link.
Andy
Top
#510233 - 25/04/18 01:32 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
Chris99 Offline
Loc: West Sussex, UK
It needs to be tighter than you may think - about 45 degrees twist on the lower part of the belt works for me.
Don't forget to check it clears the tyre (tire) as there's only a few mm of clearance.
Red Leader drive
Top
#510298 - 25/04/18 07:42 PM Re: Help immediate assistance needed rear dampers [Re: Bunny]
nippymog Offline
Loc: Cheshire, UK
I am only a few hundred miles into running with Phils stage one kit - ditched the NVH in favour of his solid Bevel Box mounts - and its working really well, no roughness or banging. Highly reccomended for the poor souls with the NVH fitted.
Edited by nippymog (25/04/18 07:42 PM)
Edit Reason: spelling !
Top
#557768 - 03/02/19 11:54 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
kankeL Offline
Loc: Rio Del Mar, CA
also the metal inserts that are on the bushings on the adjustable dampers are wider than the mounting points on the frame. FYI
Kirk, I have the same problem. Did you grind the bushing down? Both sides?
2016 M3W, Army Green Matte/Tan Leather
Top
#557966 - 04/02/19 08:58 PM Re: Help immediate assistance needed rear dampers [Re: Draggin]
2Sharp Offline
Is Phil’s kit designed to improve all Morgan 3 wheelers?
Top
#558041 - 05/02/19 11:20 AM Re: Help immediate assistance needed rear dampers [Re: 2Sharp]
nippymog Offline
Loc: Cheshire, UK
Phils Bevels box mounting kit is applicable to all three wheelers that have the NVH kit fitted ( now fitted as standard by the factory since 2014 I believe ). I suggest you contact him to get confirmation :
bleazey@woodenflutes.co.uk
Top
#560892 - 19/02/19 07:04 PM Re: Help immediate assistance needed rear dampers [Re: kankeL]
Draggin Offline
Yes! No other way to do it.
kirkusblog.com
Top
Page 3 of 3 < 1 2 3
Moderator:  Aeroman
