16 registered members (PocketRocket, Gordon D, DavidR, AZJowett, britmog, John Winn, +8Rich, DCH, LightSpeed, Spanner Juggler, M3W55, thelastgizmo, Stringers Best Mate, paulmog, PaulV, planenut), 160 guests, and 13 spiders.
John V6 430
+8Rich 406
TBM 238
Heinz 195
4/4 1.8 Duratec oil pressure lowish
by Riggsy. 02/06/20 03:30 PM
A Morgan meet?
by sospan. 02/06/20 10:58 AM
rands Foot Lockers-Any thoughts?
by Nostalgiajohn. 01/06/20 08:45 PM
Sidescreen restoration
by Phil4/4. 01/06/20 08:25 PM
Exhaust manifold temperatures - misfiring
by thelastgizmo. 01/06/20 06:15 PM
393 km, from one end to the other.
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,391
Posts629,175
Members6,938
Most Online1,033
Dec 28th, 2019
DirkM
Yellow Engine Warning Light On #4919
28/05/07 09:39 PM
28/05/07 09:39 PM
Malvern Worcs UK
Michael Offline OP
Michael  Offline OP
Malvern Worcs UK
Anyone know the list of likely reasons for the yellow engine management light staying on? I was going to take it into the factory tomorrow but they are on their holiday shutdown until 4th June.
If the rain stops I would like to get out in the Aero this week but don't want to risk serious damage to engine.
ooo
Michael
Aero 8 S4
Re: Yellow Engine Warning Light On [Re: Michael] #4924
28/05/07 10:15 PM
28/05/07 10:15 PM
Eton, Berks
Aeroman Offline
Aeroman  Offline
Eton, Berks
I think that if you check the handbook Michael, and depending on which warning light is showing, but if it is the one on the far left, it is counter-intuitive and consequently, should be ON when everything is working OK. thumbs
Aeroman
Brian
1970 Morgan Plus 8 - Moss Box (Black, soon to be the original Indigo Blue)
2014 Morgan SP1 (Rocket Red)
Re: Yellow Engine Warning Light On [Re: Michael] #4925
28/05/07 10:21 PM
28/05/07 10:21 PM
cerealsurfer Offline
only a small inballance from one of the sensors can cause the light to come on the BMW ecu is pretty sensative.. however from my experience it's best to get it checked out... some errors can be driven with however others can have serious results if driven..
Re: Yellow Engine Warning Light On [Re: cerealsurfer] #4930
29/05/07 08:00 AM
29/05/07 08:00 AM
Malvern Worcs UK
Michael Offline OP
Michael  Offline OP
Malvern Worcs UK
Thanks guy's it is the light that should go out with the engine running Brian, the one with the outline of an engine in yellow.
No symptoms just the light, I will have a ring around today to see if I can find anyone to look at it.
Michael
Aero 8 S4
Re: Yellow Engine Warning Light On [Re: Michael] #4931
29/05/07 08:50 AM
29/05/07 08:50 AM
Kent, England
chris Offline
chris  Offline
Kent, England
Quote from the handbook:
2. MIL (Malfunction indicator light)
Yellow . This warning light will show when the ignition is turned on, after a few seconds it will go out.
The light is used to show any fault in the fuel, engine management or exhaust system, which would affect the exhaust or evaporative emissions from the vehicle.
If the light comes on when the engine is running, the cause should be investigated immediately. The fault could be very serious and result in expensive repairs.
This can only be done by a qualified person, using the correct diagnosis equipment. Contact your dealer if this should happen.
Re: Yellow Engine Warning Light On [Re: chris] #4932
29/05/07 08:54 AM
29/05/07 08:54 AM
Malvern Worcs UK
Michael Offline OP
Michael  Offline OP
Malvern Worcs UK
Thanks Chris the problem for me is my nearest dealer is the factory which are closed so not shure where to go for nearest service dept, I tried local BMW dealer but they said no.
Michael
Aero 8 S4
Re: Yellow Engine Warning Light On [Re: Michael] #4933
29/05/07 09:52 AM
29/05/07 09:52 AM
The BMW dealer can hook up using the BMW X5 connector and software map and hey presto.
An indy can also do it... we use a Bosh laptop style tablet PC and a BMW connector!!
The hook-up is down to the right of the steering collumn orientated front-to-back.
I've had an AA chap also hook-up ---- especially good if you have the AA parts and labor cover
Re: Yellow Engine Warning Light On [Re: cerealsurfer] #4934
29/05/07 10:48 AM
29/05/07 10:48 AM
Sevenoaks,Kent
Viper Offline
Sir S1'a'lot
Viper  Offline
Sir S1'a'lot
Sevenoaks,Kent
Think you'll find the light may not be on at all....just looks like it is.
Life is a bowl full of cherries....there you go wink
Re: Yellow Engine Warning Light On [Re: cerealsurfer] #4935
29/05/07 11:20 AM
29/05/07 11:20 AM
Surrey, UK
Boshly Offline
NGUNS!!
Boshly  Offline
NGUNS!!
Surrey, UK
I'm getting a strange tingly feeling here a "Bosh" laptop and the AA... Maybe I should be more techie smile
BtG
PSfor those who think I am going mad AA are my initials
PPS apologies Michael absoloutely no use to your problem. Hope its a simple one
Cheers
BtG
Re: Yellow Engine Warning Light On [Re: Boshly] #4937
29/05/07 01:35 PM
29/05/07 01:35 PM
Malvern Worcs UK
Michael Offline OP
Michael  Offline OP
Malvern Worcs UK
Light is definitely on and should not be, tried BMW dealer they would not look at it.
Michael
Aero 8 S4
Moderated by  Aeroman, Simon
