14 registered members (TimG, Chris99, Craig Jezz, TBM, RJW, Paul F, drew, John Winn, Ray, Rog G, planenut, Ginmoggie, Image, M3W55),
117
guests, and 10
spiders. |
Topics44,606
Posts754,568
Members8,264
Most Online1,033 Dec 28th, 2019
Re: Supermax Poly vs. steel rear sprocket
[Re: Inge]
#492077
04/01/18 09:54 AM
04/01/18 09:54 AM
MTWV2
[Re: SOLMorgan]
#574412
30/04/19 10:47 AM
30/04/19 10:47 AM
Posts: 1,489 Near Windsor Berkshire
Rog G
Does anyone know if you can get supermax sprockets exchange in the UK or do you need to send to the US? I had mine done about 3 years ago and had to send it to the US, turn around was about 3 weeks they do pulleys in batches so it just depends where you fall in the production cycle as to the actual timescale. Cost if I remember correctly was £450, shipping £60 return and import duty £90.
[Re: Inge]
#574421
30/04/19 11:55 AM
30/04/19 11:55 AM
Posts: 1,301 Southern Vermont
Michael H
Southern Vermont
I was the first customer to order one and It lasted quite well until it failed! I have since bought the steel one with no regrets. The way the SuperMax is built makes it vulnerable. The neoprene wrap is not only bonded to the aluminum wheel but bolted as well in many places. The bolts are tiny as they must fit in the depressions (valleys) of the sprocket and not make contact with the belt. When we removed the wheel to replace the sprocket with the steel one, the neoprene had slipped and had caused some of the bolts to deform the aluminum as well as missing a few. The neoprene was spinning around the wheel so no movement.
I think I racked up about 19,000 miles before failure. I think that the amount of torque reaching the wheel as well as potholes and other obstacles took their toll.
This will never happen with the one piece steel sprocket.
[Re: Inge]
#574452
30/04/19 05:16 PM
30/04/19 05:16 PM
Posts: 1,532 Leicestershire, UK
Bunny
Leicestershire, UK
Yes, I caught the 'tiny bolts' coming loose on my Supermax so refitted them with adhesive on the threads. So far so good, but it's only done around 6K miles... If I had to replace it, I'd probably go for a Fabian steel one (if they're still available at the time).
Andy
