Who's Online
6 registered (Mi3Wheeler, dino642, Alistair, MeyerMog, SpeedMog, Roger Steele), 32 Guests and 3 Spiders online.
More photos as promised
Top speed unreached
James Bond????
Recent outing in Bretagne
Winter Sun
New Member Saying Hello
by Wrighty
11/02/12 12:33 PM
Plus 4 goes in to build
by Gambalunga
10/02/12 10:13 PM
Headrests
by Levitt
10/02/12 03:48 PM
new member checking in
by ricks67m
10/02/12 03:22 PM
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Le Mans Classic Laps
by philrs
09/02/12 08:53 PM
Juergen1965, mog86, Wrighty, jbk, Barmar
2091 Registered Users
Shout Box
Forum Stats
2091 Members
48 Forums
7280 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Topic Options
#49796 - 31/08/10 01:38 PM Spare wheel fitting 4/4 70th anniversary
4acker Offline
Loc: Germany
Hello everybody,
I bought a used 4/4 70th Anniversary with disc wheel. The former owner changed the spare wheel's fitting to fit a luggage rack (longer wing nut and spacer)and the original fitting get lost. So I can't drive without the luggage rack and instead the hub cap on the spare wheel. Could anyone send me a photo of the original fitting or the part numbers of the original wing nut (?) and spacer?
Kind regards,
Christian
Top
#49992 - 04/09/10 06:47 AM Re: Spare wheel fitting 4/4 70th anniversary [Re: 4acker]
rubymorgan Offline
Loc: Sunny Australia
Originally Posted By: 4acker
Hello everybody,
Kind regards,Christian
Gday,
not quiet sure what you actually mean mate!
you can drive with luggage rack and spare wheel in place? OR
the hub cap needs to be removed so you can secure luggage rack?
OR what????? stars
_________________________
Top
#50013 - 04/09/10 08:00 PM Re: Spare wheel fitting 4/4 70th anniversary [Re: rubymorgan]
nputtick Offline
Loc: N.Yorks, UK
He has steel wheels with hub caps. With just the spare wheel fitted, the wheel is held in place by a threaded rod and a circular washer which engage in the central hole of the wheel, with the hub cap fitted over it. To mount a luggage rack, the hub cap would have to be left off, and a different threaded rod with a T-bar welded to it (mine is s/s), plus a circular washer (on mine this is alu). The centre of the wheel is one of the three points of fixing for the rack.
So I would guess he would need a threaded rod of the correct length with a nut or small T-bar welded to the end, and a shaped circular washer to fit in the central hole, and it is this setup that has been lost.
It should be quite easy to make one, or I would guess that John Worral at Heart of England could probably supply or make one in s/s.
Top
#50022 - 05/09/10 01:03 AM Re: Spare wheel fitting 4/4 70th anniversary [Re: nputtick]
rubymorgan Offline
Ahh now all is clear
thanks for the info
Top
#50055 - 06/09/10 03:02 PM Re: Spare wheel fitting 4/4 70th anniversary [Re: nputtick]
4acker Offline
Loc: Germany
That 's correct. If have only the spacer to fit a luggage rack (for wire wheels) to my spare wheel (disc wheel). This is long spacer and a long wing nut. I am interested to see what the factory specification was. The 4/4 was delivered without a luggage rack and the hub cap on the spare wheel. If have never seen some where else what was under the hub cap and the original part were lost.
Top
#50058 - 06/09/10 06:26 PM Re: Spare wheel fitting 4/4 70th anniversary [Re: 4acker]
DaveW Offline
Loc: Yorkshire
This Mog was for sale in London a while ago and shows the standard set up which is neat..
Red Roadster
Top
#50062 - 06/09/10 08:29 PM Re: Spare wheel fitting 4/4 70th anniversary [Re: DaveW]
nputtick Offline
Loc: N.Yorks, UK
What I described should do it - I think the thread is something like M10 - so, cut a length of threaded rod to length so that about 1 inch protrudes beyond the wheel, get a piece of steel or aluminium sheet bigger than the hole in the wheel, drill a hole of say 11mm, and then use an M10 nut to clamp the arrangement down. A nice machined aluminium billet spacer would be better but the whole thing will be covered by the hub cap anyway.
Unless the fitting is different for the disc spare wheel (e.g. using a couple of the stud holes). You could check with the factory.
Top
