Who's Online
13 registered (RedThree, RicHardy, Mark H, lowebird, Craig Jezzard69, Graham, G4FUJ, Alistair, Phil1953, DavidR, dmh, asbojohn, Gerhard, JCK), 38 Guests and 15 Spiders online.
Yesterday's outing
RRAF Normandy Rally last week.
Spotted in Honfleur
For the Lotus fans
Spotted today at Kop Hill
Dewalt 18 volt Battery Grease Gun
by Craig Jezzard69
55 minutes 22 seconds ago
+4 inertia switch
by asbojohn
Today at 08:24 PM
M3W to Portugal
by Alistair
Today at 05:51 PM
Falling Leaves, Which Garden Vac?
by IvorMog
Today at 04:25 PM
Fuel filler caps Plus 8
by Culminator
Today at 01:25 PM
Alternate Parts List
by Westward
Today at 12:28 PM
Owner’s Hand Book (revisited)
by Fox Terrier
Today at 08:11 AM
Grahamt43, Erock Germany, revheadfrank, Scarper, mossmog53
6189 Registered Users
Shout Box
Forum Stats
6,189 Registered Members
33 Forums
32,981 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 3 1 2 3 >
Topic Options
#503533 - 13/03/18 07:40 PM Plus 4 tourer gdi out of service
atalante83 Offline
We ve A big problem with a plus four tourer gdi which is always not working despite a lot of search .
The car stop running when you accelarate suddently.
The electronics cards have been changed twice under waranty.
Some mecanics tried to find the issue but without succes
Have you any idea for resolving the problem .
Top
#503563 - 13/03/18 09:32 PM Re: Plus 4 tourer gdi out of service [Re: atalante83]
Moggo Offline
Loc: Devon
Does the engine cut out altogether or just stutter?
Possibility issue of fuel starvation. Try changing the air filter and the fuel filter canister. These two items might have been missed at service interval. Air flow sensor could be another culprit.
_________________________
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70.
http://moggo-blog.blogspot.com/
Top
#503602 - 14/03/18 06:22 AM Re: Plus 4 tourer gdi out of service [Re: atalante83]
atalante83 Offline
Stutter in A first Time And after several km the engine cut out.
Air filter and fuel filter canister were changed
I ll Check if air flow sensor was changed.
Thanks for help this friend car was not running since new And nobody has done efficiently the warranty job.
Top
#503622 - 14/03/18 09:04 AM Re: Plus 4 tourer gdi out of service [Re: atalante83]
DaveW Offline
Loc: South Yorkshire
Check all the fuses as there may be a hairline crack.
And check the electrical connections especially around the fly by wire system.
If all else fails, send it back to the factory or ask BHM, which is probably closer.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#503646 - 14/03/18 10:38 AM Re: Plus 4 tourer gdi out of service [Re: atalante83]
griffo Offline
Loc: Cornwall
I cannot offer any helpful advice but, as a Plus 4 GDI owner, I'd be very interested to learn what the fault was when you find out. Mine refused to start once after being laid up for a few weeks. Everything was checked by the local dealer's engineer with his laptop software and nothing amiss. Then, finally, it spluttered into life. We never did find out what the problem was and, mercifully, it has not recurred.
www.griffopix.com
Top
#503672 - 14/03/18 12:20 PM Re: Plus 4 tourer gdi out of service [Re: DaveW]
Moggo Offline
Loc: Devon
Agreed - It sounds electrical.
Also worth checking are the battery terminals and the engine earthing cable. Also try removing dashboard (easy removal by just lowering steering wheel and unscrewing the three screws holding it in place); then detach as many connectors as you can and spray with electrical cleaner before re-connecting.
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70.
Top
#503693 - 14/03/18 02:42 PM Re: Plus 4 tourer gdi out of service [Re: atalante83]
John V6 Offline
Loc: Suffolk
There is an earth under the dash on the passenger side. It is bolted to the bottom of the heater. As Morgan put sealant between the heater & the bulkhead it can be an issue. Also on mine the nut was loose.
2006 Indigo Blue Roadster S1
Top
#504009 - 16/03/18 10:06 AM Re: Plus 4 tourer gdi out of service [Re: atalante83]
lowebird Online   happy
Loc: norfolk, UK
As an aside, I was talking to Richard Thorne at the London Classic Car Show and he told me that the GDI engine is now only used in one S American country ( can't remember which ) but that doesn't bode well for maintenance in the coming years.
I was always under the impression that it was a main stream Ford engine but it seems not.
Do we sell now and buy some alternative ( don't ask me what ) or do we enjoy whilst we can and await the axe of doom when we will all be driving electric buggies.
Reg
Top
#504011 - 16/03/18 10:17 AM Re: Plus 4 tourer gdi out of service [Re: atalante83]
DaveW Offline
The simple answer is to replace it with a 2.5L Duratec when all else fails. Not a cheap option but one solution!
Top
#504035 - 16/03/18 01:47 PM Re: Plus 4 tourer gdi out of service [Re: atalante83]
Loc: norfolk, UK
As you say Dave, simple but a tad expensive! I wonder what Morgan will replace the GDI with?
Reg
Top
Page 1 of 3 1 2 3 >
