13 registered members (peterd, Malcolm T, John07, Spanner Juggler, clubsport, Edwin, +8Rich, Budster, BLUE+4, Ian Wegg, daitona, Bitsobrits, 1560), 187 guests, and 14 spiders.
John V6 443
+8Rich 405
TBM 244
Heinz 199
No delivery from Scenic Car Tours
by Spanner Juggler. 01/06/20 09:37 AM
Virtual All Morgans' Day
by Frank 4x4. 01/06/20 08:30 AM
Water Hose Heater Bypass TR4 Engine
by BuyBritish. 01/06/20 05:20 AM
The lubrication button
by Mc Black. 31/05/20 05:21 PM
Hood frame rattle
by Viper. 31/05/20 04:16 PM
Lockdown Fettling
by Budster. 31/05/20 03:33 PM
What am I looking at
by PaulyG. 31/05/20 03:08 PM
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
Social distancing
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,380
Posts628,961
Members6,938
Most Online1,033
Dec 28th, 2019
AlexH, Marian
Technical data for 1937 - 1939 Morgan 4/4 #491193
29/12/17 03:54 PM
29/12/17 03:54 PM
North Somerset, UK
Deejay Offline OP
Deejay  Offline OP
North Somerset, UK
I have come across a data sheet once published by Newnes Motor Repair and Overhauling for the late 1930s 4/4. It has details such as firing order, Solex carb jetting,valve timing, ignition timing, tappet clearances, plug gaps, toe-in of front wheels, tyre and oil pressures, recommended lubes and battery capacity.
Anyone out there need any such info??
Doug
2011 +4 in Rich Maroon
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: Deejay] #491262
29/12/17 10:00 PM
29/12/17 10:00 PM
Florida USA
MarkB Offline
MarkB  Offline
Florida USA
I have a 1938 Series 1 4/4. It may be interesting to see what is being spec'd.
Cheers,
Mark
1934 SS MX4
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: MarkB] #491267
29/12/17 10:27 PM
29/12/17 10:27 PM
North Somerset, UK
Deejay Offline OP
Deejay  Offline OP
North Somerset, UK
Hi Mark B
Firing: 1,3,4,2; Solex choke 30-23, main 115, compensating 210, pilot 60. Valves (set with 6thou clearances) Inlet open 10 BTDC, Close 50 ABDC, Exhaust open 50 BBDC, Close 10 ATDC. Ignition timing: contact points begin to open at TDC (shown for cylinders 1 or 4 when line on flywheel opposite hole in case) . Tappets (cold) inlet .006 inch, exhaust .010 inch. Plug gap .022 - .025; distributor gap .012 - .015; front wheel toe in 1/8 inch max. Oil pressure 40 psi; oil grade 50 in summer and 40 in winter (UK temperatures I guess) Battery 57 ah.
Front tyres 5.00-16 18psi or 4.50-17 21psi.
Hope you ind useful.
Doug
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: Deejay] #491284
30/12/17 01:33 AM
30/12/17 01:33 AM
Florida USA
MarkB Offline
MarkB  Offline
Florida USA
Some good stuff. Do they indicate which engine. Standard Special or Coventry Climax??
Cheers,
Mark
1934 SS MX4
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: MarkB] #491339
30/12/17 12:20 PM
30/12/17 12:20 PM
North Somerset, UK
Deejay Offline OP
Deejay  Offline OP
North Somerset, UK
Cheers,
Sadly not. There are two columns on the sheet labelled 1939 and 1937-38 but no engine type. Details in both columns are identical! I think the Standard engine was introduced in 1939 but whether it would have same settings as CC engine is debatable?
Doug
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: Deejay] #491362
30/12/17 02:32 PM
30/12/17 02:32 PM
Florida USA
MarkB Offline
MarkB  Offline
Florida USA
Makes sense. I suspect CC as you surmise.
Cheers,
Mark
Mark
1934 SS MX4
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: MarkB] #492794
07/01/18 04:39 PM
07/01/18 04:39 PM
Germany
4acker Offline
4acker  Offline
Germany
I saw this thread a bit late. But if someone is interested I still have some pdfs for these cars. Instruction manual, lubrication chart, repair manual.
Send me a PM if interested.
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Re: Technical data for 1937 - 1939 Morgan 4/4 [Re: Deejay] #508424
13/04/18 08:17 PM
13/04/18 08:17 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
very likely the engine is the coventry climax!
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Moderated by  Aeroman, Simon
