Who's Online
19 registered (P964, Sir Percival, LE52MOG, Alistair, RJW, westgardronning, Hamwich, hugo, paddockman, milligoon, jong, petemog, John V6, Fox Terrier, Richard Wood, TBM, Clipper, Bunny, Sinbad), 108 Guests and 18 Spiders online.
The winter M3W
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Sports Exhaust
by paddockman
21/01/19 09:18 AM
Lowering blocks ?
by Cat302
21/01/19 07:24 AM
Anybody Understand Latin?
by Clipper
20/01/19 09:24 PM
Getting the wheels Off
by IcePack
20/01/19 07:22 PM
Must be getting old or just like Quality
by Jack The Lad
20/01/19 06:42 PM
Vintage roads great and small (TV)
by PaulV
20/01/19 05:30 PM
Co Pilot Headwear?
by jong
20/01/19 05:16 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
34,013 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 3 of 4 < 1 2 3 4 >
Topic Options
#513362 - 16/05/18 03:26 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: howard]
PaulJ Offline
Loc: Somerset, UK
Originally Posted By howard
no way do "revvy" and turbo relate. To the contrary, the idea of a turbo is to pressurise the input gas and in doing so to put a larger volume of combustible gasses through an engine than would happen if it were N/A. Or to put it another way, at a boost of say 1.22 bar, the turbo engine is passing the same amount of gasses through at 4000rpm as an NA engine of the same size would at 4800 rpm.
not only that but a lot of these turbo engines dont rise to s decent crescendo at 8000 rpm but make exceeding 500 rpm a bit pointless when you get the same sort of acceleration at 2500 rpm. and since power generated relates directly to fuel used, the only real gain is in pumping losses on a smaller / slower revving unit.
work of the devil I say. Or at least of the eco-devils.
P.S. Remember the old F1 days when the option was either a 1.5 litre turbo engine of a 4.5 litre NA engine of roughly the seame power.
Of course Howard is right in his assertion that n/a engines are more revvy, building their power up to a peak, then asking for a gearchange so it can all be done again, however I would contend that most drivers, on this forum at least, do not want to drive like that all the time. Ask anyone who has swapped a Plus 4 for a Roadster what makes for the better drive, and I would wager it will be the V6 because of its' torque, so if engine manufacturers are able to get bagfulls of torque from small engines, without the dreaded turbo lag, which they can, then surely this has to be the way to go?
It will be very interesting to see which way MMC go in the next few years.
_________________________
[Beginning to get the best out of the ARP4]
Top
#513363 - 16/05/18 03:27 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: Peter J]
howard Offline
Originally Posted By Peter J
This all reminds me of the debate about ABS on motorcycles in the run up to it becoming mandatory on all bigger bikes.
I have two cars that produce just under 400bhp. One has 6 cylinders and two turbos, is 3.0L and the other is has 8 cylinders, natural aspiration and 4.8L.
In the real world both use about the same amount of fuel, but the Turbo produces 50% less CO2 on the EU Test Cycle, mostly because it produces torque at virtually no throttle opening.
If the two engines use the same amount of fuel in daily use then they have to be producing the same amount of co2
What you are illustrating is the use of turbos to deceive the EU test regime A pc eco nonsense.
The realistic way of reducing co2 is to reduce the size and weight of modern cars. You can add into that a reduction in traffic jams by enlarging roads for example.
What you are seeing is a conflict between the public who regard say a range rover as a sensible size and the eco warriors who want you all on bikes or busses
Edited by howard (16/05/18 03:28 PM)
Top
#513365 - 16/05/18 03:49 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: howard]
Peter J Offline
Formerly known as Aldermog
Loc: Salisbury, UK
Absolutely right, the "lower CO2" on the Turbo demonstrates perfectly the scientific deceit inherent in the EU tests (and the "new" one is little better) on emissions. What makes me really annoyed is that the tax paid is based on data that is scientifically flawed.
Removes "grumpy" jacket.
Tarka the 'Otter Mog
2014 Plus 8
Top
#513367 - 16/05/18 04:08 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: madmax]
Paul F Offline
Loc: Costock, South Nottinghamshire...
Understand all the arguments above.
However, we have just swapped a 4 cylinder 1.6 normally aspirated MINI for a 3 cylinder 1.5 turbo MINI. The turbo car is a fair bit heavier (MINI ONE 3 door vs MINI Clubman 6 door) and the engine generates a bit more power - the good bit is that it uses around 20% less fuel both locally and on a run than the NA 1.6.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
#513370 - 16/05/18 04:27 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: Peter J]
howard Offline
But it goes a lot further than that Peter. Cars are vilified by the eco warriors depite producing far far less CO2 than many other machines from CH boilers to busses, trucks and cows.But the mainly left leaning academics who run the anti car campaign simply dont accept the idea of personal choice. Take plane flight - less CO2 per passenger mile than busses but you wouldnt believe that from the propaganda.
I'll give you one significant CO2 saver - a statutory limit on the weight of cars to 1000kg.
Top
#513378 - 16/05/18 05:09 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: howard]
madmax Offline
Loc: East Anglia
Tax cars by weight as well as Co2 and car tax and vehicle VED and fuel tax ....
Top
#513392 - 16/05/18 05:55 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: howard]
Hamwich Online   content
Loc: Gloucestershire, UK
Only if you completely distort the comparison by taking long-distance flight with short inner-city bus journeys.
Short flights create around 0.18kg/passenger mile, bus journeys of comparable distances are around 0.08.
https://www.eea.europa.eu/media/infographics/co2-emissions-from-passenger-transport/image
Edited by Hamwich (16/05/18 06:01 PM)
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#513396 - 16/05/18 06:03 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: howard]
Peter J Offline
Loc: Salisbury, UK
I'll buy that... Introduce a "small car" concept, like the Japanese Kei cars. The Honda
S660 was amazing. Flat road tax of £75.00
Then a band structure for the rest that takes in weight, total footprint and purchase price, so LWB Range Rovers would be taxed at £2500 a year.
As for sources of CO2, you are right, personal motor transport is a bit part in the CO2 generation game. The US Department of energy stated recently that Natural CO2 sources account for the majority of CO2 released into the atmosphere.
Oceans provide the greatest annual amount of CO2 of any natural or anthropogenic source.
Other sources of natural CO2 include animal and plant respiration, decomposition of organic matter, forest fires, and emissions from volcanic eruptions.
There are also naturally occurring CO2 deposits found in rock layers within the Earth’s crust that could serve as CO2 sources.
All of this is ignored by the eco-mentalists and academics. swear
2014 Plus 8
Top
#513400 - 16/05/18 06:13 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: Peter J]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
Guess I'd better find a MINI for everyday grin2
My garage pal said one of his customer's wanted to sell a cheap car he'd bought for a son. Allegedly 12 month test, cam belt all the bits done. Didn't give me any details on vehicle just that it was an early collaboration that Honda had an input to. I frightened myself with the "Triumph Acclaim" thought! eek
Though any that are still running are probably considered "emerging classics" laugh2
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#513417 - 16/05/18 09:15 PM Re: Ford 3cyl 1500cc turbo engine - 197 bhp [Re: Peter J]
David_E Offline
Loc: Bedfordshire
But most of that natural CO2 is absorbed at a similar rate that it is generated, which is why the level stayed pretty much constant for so long until we started making significant use of fossil fuels.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
Top
