Who's Online
4 registered (Bishmog, LightSpeed, RB1, M3W55), 88 Guests and 69 Spiders online.
Chiltern Hills Vintgae Car Rally 19.5.19
Cape to Cape Rally -  Arrival in Falmouth.
When Things Go Wrong
M3W and new shop/garage
Factor 50 Day in the Highlands
Insurance
by Grumpy2
Today at 09:35 PM
LINMOG SEARCH AND RESCUE BASE VISIT
by KEVFITZ
Today at 08:55 PM
Roadster Tires
by Don Smith
Today at 08:52 PM
Congratulations Manchester City
by scratched
Today at 05:50 PM
Little jobs..
by SteveT
Today at 05:32 PM
Beartooth Highway
by Button
Today at 03:35 PM
WW2 switches
by N22MOG
Today at 01:56 PM
Melissa4/4, Illia Pasko, Jazzman, Nico_M3W, mudeford gg
6502 Registered Users
Shout Box
Forum Stats
6,502 Registered Members
33 Forums
35,073 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
dishy
Topic Options
#516345 - 05/06/18 01:08 PM Transmission tunnel grommets!
Adrian Bott Offline
Hello there,
I have just bought a 1992 4/4 and am quite amazed to find that there are no transmission tunnel grommets fitted to the numerous inspection hole openings. Can anyone shed some light on this please as it appears none have ever been fitted from the factory? Kind regards, Adrian.
Top
#516346 - 05/06/18 01:24 PM Re: Transmission tunnel grommets! [Re: Adrian Bott]
Hamwich Offline
Loc: Gloucestershire, UK
Originally Posted By Adrian Bott
Hello there,
I take it you mean the gearbox cover rather than the transmission tunnel? The transmission tunnel doesn't have any inspection holes in it as far as I'm aware, at least mine doesn't.
As for the inspection holes in the gearbox cover, I have only ever seen Gaffa Tape being used to cover them.
_________________________
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#516372 - 05/06/18 06:44 PM Re: Transmission tunnel grommets! [Re: Adrian Bott]
Ray Offline
Loc: Llanelli
There is often a small round metal plate hanging by one selftapper.
Top
#516434 - 05/06/18 10:25 PM Re: Transmission tunnel grommets! [Re: Adrian Bott]
Adrian Bott Offline
There are 4 apertures but no grommets at all! I can't understand why they haven't been fitted at the factory. Very strange!
Top
#516436 - 05/06/18 10:31 PM Re: Transmission tunnel grommets! [Re: Hamwich]
Adrian Bott Offline
Thanks Tim, yep gearbox cover. There are 4 apertures that are uncovered. I guess I will get some grommets to fit but there is an oval aperture that the speedo cable comes through. No chance of making a grommet or successfully using 'gaffer' tape in that case. I'll keep trying to figure something out for that one. Thanks again!
Top
#516447 - 05/06/18 11:05 PM Re: Transmission tunnel grommets! [Re: Adrian Bott]
DaveW Offline
Loc: South Yorkshire
For a large irregular hole, first cut a piece of neoprene slightly larger than the hole to provide a flange. Cut a suitable hole in the middle. Cut a slot if it needs to be slotted over an existing cable. Place it under the hole. Retain temporarily with masking tape or similar.
Then do the same again for the outside. Line up the slots. Run a thin bead of superglue on the neoprene just inside the hole in the panel. Place the two together and hold until the superglue sets.
Remove the temporary masking tape and you have a grommet.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#517627 - 14/06/18 04:22 PM Re: Transmission tunnel grommets! [Re: Adrian Bott]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
I don't know about earlier models but the gearbox cover on the 2012 Plus 4 is an appalling bit of design.
The back of the gearbox cover has the transmission tunnel fitted over it. This means that the leather trim has to be peeled off and the transmission tunnel removed before the gearbox cover can be removed.
The front has a flange folded upwards that makes it impossible to get the cover off (the flange makes it impossible to slide the cover past the heater/radio box). If the flange was folded out from the firewall, in other words part of the firewall not the gearbox cover, the cover could be fitted over it and you could remove the cover without removing the heater/radio box. Apparently in some cars it can only just be forced past bottom of the heater box: not on mine swear
Given that the tail shaft can be accessed from under the car it is difficult to see any need to remove the transmission tunnel unless it has been damaged. In my opinion it should be possible to remove the gearbox cover without disturbing any other components. It is glued to everything with mastic anyway so water should not be a problem frown better still would be some good neoprene strips to form gaskets.
Top
#525926 - 05/08/18 10:04 AM Re: Transmission tunnel grommets! [Re: Adrian Bott]
milligoon Offline
Loc: Dorset, UK
Why would water be an issue unless you regularly roll the car or drive through deep water?
My gearbox is bone dry and clean, the heat shielding on the inside of my gearbox cover, it is bone dry. The heat in the area probably rapidly dries out any splashes. As the floor boards are lower and not sealed from water as far as it is attached to the chassis any water would come through there anyway.
I think it's a bit of a none problem in all reality.
Mark - driving
Top
