Who's Online
16 registered (Rovert, Sir Percival, OZ 4/4, Richard Wood, jeepy, Rog, westgardronning, revb, sarnia, IcePack, NeilMB, rv6, Neilda, Doug J, Hamwich, Volvos60s60), 120 Guests and 13 Spiders online.
 Morgan 1909 Runabout Electric Replica
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
A day out in Felixstowe
Done it!
by Amrum
23/03/19 06:29 PM
Side screen not fitting correctly
by Nfitz
23/03/19 05:43 PM
We can be heroes.....just for 2 days!
by Northernmorgan
23/03/19 03:26 PM
Guy or chap?
by Gambalunga
23/03/19 03:08 PM
Magnum Tuning Performance Chip for S&S Engine
by Bunny
23/03/19 12:04 PM
Thoughts please
by meabh
23/03/19 11:05 AM
Rear tyres for the Coupe, whats the latest ?
by Alistair
23/03/19 08:26 AM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,610 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 2 1 2 >
Topic Options
#518003 - 17/06/18 07:48 AM Intermittent cutting out
Max5 Offline
Loc: Ayrshire
My 1600 X-flow is just back from an engine rebuild by Agra engineering, a respected competition engine builder and it is now producing well north of 100bhp on a rejetted standard progressive Weber. The car ran very well for the first couple of hundred miles but it has now developed a fault which causes the engine to die while driving. The engine will restart after a couple of turns of the key but the process will repeat at random. The carb. has been cleaned out and an in-line filter installed.The engine is running Lumenition electronic ignition with the infra red beam and "chopper" and the standard distributor has been modified for mechanical advance only, with a maximum advance of 34 degrees.
I am leaning towards coil breakdown or a fault in the ignition box but I wondered if anyone else has experienced this and can offer any pointers?
Don.
Top
#518004 - 17/06/18 08:06 AM Re: Intermittent cutting out [Re: Max5]
DaveW Offline
Loc: South Yorkshire
I had a Lumenition module go intermittent on me on an MGB and it drove me mad.
Experts tell you that they either work or they don't but mine was intermittent.
I went through everything, carbs fuel feed, coil etc and as a last resort I went back to points......
Hey presto.
And that module wasn't very old!
_________________________
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#518015 - 17/06/18 08:55 AM Re: Intermittent cutting out [Re: Max5]
Calypso Red Offline
Loc: Staffordshire UK
Does it have a mechanical fuel pump by any chance? I had the same symptom which was due to intermittant sticking of the pump valves. A new pump sorted it.
Calypso Red
1994 +8 BMW Calypso Red.
2002 4/4 4 seater BMW Calypso Red.
Top
#518017 - 17/06/18 09:04 AM Re: Intermittent cutting out [Re: Calypso Red]
Max5 Offline
Loc: Ayrshire
The in-line filter is transparent and the pump can be seen to work quite clearly,thanks.
Top
#518018 - 17/06/18 09:07 AM Re: Intermittent cutting out [Re: DaveW]
Max5 Offline
Loc: Ayrshire
Dave - General consensus in the paddock at the hillclimb I was supposed to be taking part in yesterday and today agrees that the Lumenition may well be the source of the problem.
Don
Top
#518019 - 17/06/18 09:28 AM Re: Intermittent cutting out [Re: Max5]
Mogdriver Offline
Loc: Tauranga. New Zealand
Hi Don
Like Dave I had a fault develop in a Lumenition module that I had correctly installed in a Commodore to replace the points. Luckily it happened close to home but I then had to face the questioning from the agents from whom I had purchased it from down in Wellington ( NZ ). I was accused of incorrect electrical connections but it was not the first Lumenition I had installed and thank goodness they replaced the module. But somewhat frustrating because it was intermittent but once module replaced no further problem.
Doug
From deep deep down under.
Top
#518025 - 17/06/18 10:11 AM Re: Intermittent cutting out [Re: Max5]
DaveW Offline
My first Lumenition worked for years without a problem but the faulty unit was not long out of warranty.
Top
#518042 - 17/06/18 11:54 AM Re: Intermittent cutting out [Re: Max5]
Stephen888 Offline
Loc: Cambridge UK
My ignition started to cut out and eventually failed. It was the Lumenition which had worked ok for many years.
1980 +8 Blue
Stephen
Top
#518056 - 17/06/18 01:17 PM Re: Intermittent cutting out [Re: Max5]
Paul F Offline
Loc: Costock, South Nottinghamshire...
Does the carburettor have an electrically operated “anti-run-on” valve?
If so, worth checking the connections as it will have been one of the things that has been disturbed in the re-fit process.
Also, are there any lengths of rubber pipe in the fuel line? These can fail internally in such a way as to give these symptoms - a friend had this on a Midget and spent weeks looking for an electrical issue when the fault was fixed by changing a short length of pipe.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
#518058 - 17/06/18 01:40 PM Re: Intermittent cutting out [Re: Max5]
DaveW Offline
Oh and another thing. If you have blade fuses, they can develop a hairline crack, which may open up as the fuse heats. With the circuit broken they cool and re-connect, so check any blade fuse feeding the ignition system very closely.
Top
Page 1 of 2 1 2 >
