1 registered members (Trw), 182 guests, and 14 spiders.
+8Rich 240
John V6 142
Hamwich 126
Image 120
Wanted M3W
by Gambalunga. 23/02/20 11:07 PM
Driveline Information
by Rob82. 23/02/20 09:51 PM
Fog stirrer
by nick w. 23/02/20 09:42 PM
Roadster ground clearance
by Richard Wood. 23/02/20 08:00 PM
Copy of warrentee
by Bluesman. 23/02/20 07:57 PM
Starter Motor - which one
by DaveK. 23/02/20 06:32 PM
Inner track rod end - bush O/D
by teknome. 23/02/20 05:09 PM
Garage art
near eccleston VA
FolkMog lunch
well..
Today at Krazy Horse
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,315
Posts606,351
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
The Wolf Performance/BHM skid plate #522946
18/07/18 02:42 PM
18/07/18 02:42 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
I purchased one at Blenheim from BHM. Excellent quality as you would expect from Cain!
It should have been a half hour job, but you know how these things pan out...........................
Nice etched logo which I have fitted facing forward, and it comes with two allen headed countersunk machine screws and a drill bit........
What could possibly go wrong.
I don't have a G clamp small enough to hold the piece, but cable ties are good enough!
Get it level!!
Obviously the Morgan needs lifting quite a way. Even so I had to take some covers off the pit to get the drill in position.
The cross-member is thick and so takes time to drill through. If you wish to protect the gearbox casing, insert either a piece of wood, or metal above the cross-member to take the force out of the drill as it comes through.
On the second hole, just at the point of penetration, the bit stuck, and the end broke off...... Not a disaster as I have other drills, but access was tight, and my affliction of positional vertigo makes it quite hard to move about under the Morgan without the world spinning.................
Then more trouble loomed. I dropped one of the machine screws into the pit, and it did one of those trans-dimensional shifts. It vanished......... Half an hour later and losing patience I had to give up. It had gone................
A quick message to the Cain-meister, and a replacement was in the post......... thumbs clap
So today I finished the half hour job........
The quality is superb. Yes I could have made one, but it wouldn't have been as good as this.
I probably won't fit one to my Roadster because the sump is much lower than this, but a worthwhile addition for 4/4 and Plus 4.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #522969
18/07/18 04:32 PM
18/07/18 04:32 PM
Northamptonshire UK
Stringers Best Mate Offline
Northamptonshire UK
I'm afraid I succumbed too..
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523002
18/07/18 05:51 PM
18/07/18 05:51 PM
Perthshire Scotland
jimmyw Offline
jimmyw  Offline
Perthshire Scotland
Well done Dave I had mine fitted when the car was being serviced .
Jimmy
2015 4/4 Sport Green
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523003
18/07/18 05:52 PM
18/07/18 05:52 PM
Edenbridge, Kent, UK
N22MOG Offline
N22MOG  Offline
I had BHM fit one to my Plus 8 at the last service. It feels much less worrying when I hit a speed bump now.
Steve L.
1996 Plus 8
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523007
18/07/18 06:29 PM
18/07/18 06:29 PM
Carmarthen
teifistar Offline
teifistar  Offline
Carmarthen
Fitted one just before our trip to Le Mans Classique. A very well made piece of kit which proved its worth during the trip, with me and the Mrs. and luggage on board there is not much clearance.
Leaving the hotel car park in Il de Re, it caught the bottom and actually dented the plate (I was going very gently). Two days later it hit a speed bump in the Medoc and then again entering a car park in St. Emilion.
The plate does actually decrease the ground clearance very slightly, but I was very glad I had fitted it.
Dave, the underside of your car looks as if it just left the factory or maybe even cleaner.
"Hasta la victoria siempre"
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523008
18/07/18 06:33 PM
18/07/18 06:33 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Well two years on I think the regular soaking when driving in rain has helped!!!! The underside does stay remarkably clean, even after 6,500 miles.............
SBM's looks even cleaner.........
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523013
18/07/18 06:37 PM
18/07/18 06:37 PM
Newton Abbot, South Devon UK
Felix42 Offline
Felix42  Offline
I imagine that these skid plates reduce the ground clearance quite a lot.
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523017
18/07/18 06:40 PM
18/07/18 06:40 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Dave , the underneath of your Mog looks mighty clean !!
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523019
18/07/18 06:48 PM
18/07/18 06:48 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
It only reduces the clearance by the thickness of the plate, maybe 5 or 6mm.
The issue is that if you ground the cross-member, which is an inverted U, sometimes the Morgan will get stuck. This plate makes it far less likely to get stuck on a hump.
Clean is good MM!!
Re: The Wolf Performance/BHM skid plate [Re: DaveW] #523043
18/07/18 08:13 PM
18/07/18 08:13 PM
nick w Offline
nick w  Offline
Just out of interest, if the function is to slide the car up and over the obstacle rather than hit it head on, wouldn't a thin sheet of aluminium achieve that?
Am I being awfully naive?
Nick
Moderated by  Aeroman, Simon
