16 registered members (DCH, RichB, RB1, +8Rich, Richard J, DickJ, sprinty, Graham, G4FUJ, Q8morgan, M3W55, rockabilly john, Island Mog, Selena, Richard Wood, Morph, MarioCP), 115 guests, and 30 spiders.
John V6 446
+8Rich 416
Hawki 183
Loose Marbles
by +8Rich. 08/07/20 06:46 PM
Spanish M3W - 2013 unit - with db problem
by Marmota. 08/07/20 05:32 PM
An interesting article on E10 from Moss
by +8Rich. 08/07/20 05:20 PM
Remember my 'anyone good at maths question ?
by Bonesie. 08/07/20 02:45 PM
Donington Sunday !
by CooperMan. 08/07/20 12:15 PM
Advice needed
by Sib8292. 08/07/20 12:04 PM
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Our 2020 Morgan Plus 4   110 Anniversary Model
My new Plus Four
Sib8292, Selena, The Alternator, m3wofl, Klaus-Peter K
7049 Registered Users
Topics38,740
Posts636,780
Members7,049
Most Online1,033
Dec 28th, 2019
Francis, Grendelmeier, ShaunD
Transmission tunnel grommets! #516345
05/06/18 12:08 PM
05/06/18 12:08 PM
Barnstaple UK
Adrian Bott Offline OP
Barnstaple UK
Hello there,
I have just bought a 1992 4/4 and am quite amazed to find that there are no transmission tunnel grommets fitted to the numerous inspection hole openings. Can anyone shed some light on this please as it appears none have ever been fitted from the factory? Kind regards, Adrian.
Re: Transmission tunnel grommets! [Re: Adrian Bott] #516346
05/06/18 12:24 PM
05/06/18 12:24 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Originally Posted By Adrian Bott
Hello there,
I take it you mean the gearbox cover rather than the transmission tunnel? The transmission tunnel doesn't have any inspection holes in it as far as I'm aware, at least mine doesn't.
As for the inspection holes in the gearbox cover, I have only ever seen Gaffa Tape being used to cover them.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Transmission tunnel grommets! [Re: Adrian Bott] #516372
05/06/18 05:44 PM
05/06/18 05:44 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
There is often a small round metal plate hanging by one selftapper.
Re: Transmission tunnel grommets! [Re: Adrian Bott] #516434
05/06/18 09:25 PM
05/06/18 09:25 PM
Barnstaple UK
Barnstaple UK
There are 4 apertures but no grommets at all! I can't understand why they haven't been fitted at the factory. Very strange!
Re: Transmission tunnel grommets! [Re: Hamwich] #516436
05/06/18 09:31 PM
05/06/18 09:31 PM
Barnstaple UK
Barnstaple UK
Thanks Tim, yep gearbox cover. There are 4 apertures that are uncovered. I guess I will get some grommets to fit but there is an oval aperture that the speedo cable comes through. No chance of making a grommet or successfully using 'gaffer' tape in that case. I'll keep trying to figure something out for that one. Thanks again!
Re: Transmission tunnel grommets! [Re: Adrian Bott] #516447
05/06/18 10:05 PM
05/06/18 10:05 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
For a large irregular hole, first cut a piece of neoprene slightly larger than the hole to provide a flange. Cut a suitable hole in the middle. Cut a slot if it needs to be slotted over an existing cable. Place it under the hole. Retain temporarily with masking tape or similar.
Then do the same again for the outside. Line up the slots. Run a thin bead of superglue on the neoprene just inside the hole in the panel. Place the two together and hold until the superglue sets.
Remove the temporary masking tape and you have a grommet.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Transmission tunnel grommets! [Re: Adrian Bott] #517627
14/06/18 03:22 PM
14/06/18 03:22 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
I don't know about earlier models but the gearbox cover on the 2012 Plus 4 is an appalling bit of design.
The back of the gearbox cover has the transmission tunnel fitted over it. This means that the leather trim has to be peeled off and the transmission tunnel removed before the gearbox cover can be removed.
The front has a flange folded upwards that makes it impossible to get the cover off (the flange makes it impossible to slide the cover past the heater/radio box). If the flange was folded out from the firewall, in other words part of the firewall not the gearbox cover, the cover could be fitted over it and you could remove the cover without removing the heater/radio box. Apparently in some cars it can only just be forced past bottom of the heater box: not on mine swear
Given that the tail shaft can be accessed from under the car it is difficult to see any need to remove the transmission tunnel unless it has been damaged. In my opinion it should be possible to remove the gearbox cover without disturbing any other components. It is glued to everything with mastic anyway so water should not be a problem frown better still would be some good neoprene strips to form gaskets.
Re: Transmission tunnel grommets! [Re: Adrian Bott] #525926
05/08/18 09:04 AM
05/08/18 09:04 AM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Why would water be an issue unless you regularly roll the car or drive through deep water?
My gearbox is bone dry and clean, the heat shielding on the inside of my gearbox cover, it is bone dry. The heat in the area probably rapidly dries out any splashes. As the floor boards are lower and not sealed from water as far as it is attached to the chassis any water would come through there anyway.
I think it's a bit of a none problem in all reality.
Mark - No Longer driving
Moderated by  Aeroman, Simon
