Morgan Aero 8
Who's Online
16 registered (Corsu, Peter J, M3W55, Wirewheel, James B W, Moggo, Neptune, ewn, yobtaf, Hamwich, Fuel.inj, Mike D, Dean-Royal, Elcyd, HeadlessBlue, Godders), 111 Guests and 10 Spiders online.
More recent pics...
pic of car as suggested in welcome forum
Ford GDI engine for sale
Today at Rattray Head
The brae of Coynach
Purist experience... 4/4 or +4...
by pete757
17/02/19 12:54 PM
Roadster heater blower control switch (2009/10)
by Terry S
17/02/19 12:26 PM
ROVER V8 - STROMBERGS AND FUEL PUMP
by SuffJohn
17/02/19 09:52 AM
ONE YEAR ON !!!!! ......
by KEVFITZ
17/02/19 08:09 AM
Finally... Something’s Gone Wrong!😂
by KenShapiro
16/02/19 10:31 PM
First Oil Change - V6 Roadster - different sump?
by MDS61
16/02/19 08:28 PM
1964 4/4 - Battery
by britmog
16/02/19 08:18 PM
Lindsay B, Reckless, nate22, Mike3W, Dutchie55
6364 Registered Users
Shout Box
Forum Stats
6,364 Registered Members
33 Forums
34,233 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
02mog, Aero Angel
Page 1 of 2 1 2 >
Topic Options
#532899 - 14/09/18 02:13 PM Tyre Pressure when Hot
Peter J Online   crying
Formerly known as Aldermog
Loc: Salisbury, UK
I set the MP4 S to 24 psi, as I'd had the ZZ3s.
For no good reason after getting home today I checked the pressures hot, all were up 5 psi... and the tyre body was noticeably warm.
The ZZ3s never warmed up, even 7 hard (for me) laps of Castle Coombe didn't get them more than slightly warm.
Question to those who know more.. should I set cold pressure lower, say 22 psi, given how easily there MP$ S heat up?
_________________________
Tarka the 'Otter Mog
2014 Plus 8
Top
#532903 - 14/09/18 02:47 PM Re: Tyre Pressure when Hot [Re: Peter J]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
I would try up a couple of psi Peter. I suspect a lot of the heat is due to sidewall flexing more than it should?
A tyre that is below manufacturer advised pressure (perhaps slow puncture) will heat up more than a tyre at correct pressure.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#532909 - 14/09/18 03:33 PM Re: Tyre Pressure when Hot [Re: Graham, G4FUJ]
Loc: Salisbury, UK
Good point: the sidewalls are, compared with the ZZ3s, far more flexible. So 26 all round and then see what they go up to?
Also, whilst the Sticker Plate in the car says 25 all round the Aero 8 is listed as 29 all round. So I think 26 is a good starting point.
2014 Plus 8
Top
#532910 - 14/09/18 03:43 PM Re: Tyre Pressure when Hot [Re: Peter J]
Alistair Offline
Smile, it confuses them
Loc: Hampshire
If you watch the tyre pressure sensors in the MB you will notice quite a change in pressure from stationary to exercising with vigour.
The last few mornings have been cooler so a good blast will see them going up during the drive. I would expect to see +3-4 normally unless I really push when it will go up +4-6. Mostly hard braking and pushing on heats them up from my experience.
I would not drop pressure for general road use as under-pressure is more dangerous.
If you are track bound it is a little more sensible to drop them a little prior to going out knowing that the work will increase them. Then check them after a few sighting laps, without using the handbrake in the pits to avoid smokey moments. Ahh the smell of burning pads, yum.
Is it true ? I just have to pop out to the garage and check again, see you in an hour (or three)
Top
#532916 - 14/09/18 04:17 PM Re: Tyre Pressure when Hot [Re: Peter J]
milligoon Offline
Loc: Dorset, UK
Peter, we could set up your tyres buy use of my FLIR camera, Yeh I finally have a cool geeky use for it wink
Oh yes if they are stickier tyres then they will get hotter anyway.
Need to see if your current pressures are causing any issues under/over pressured etc which will lead to premature wear.
Mark - driving
Top
#532919 - 14/09/18 04:55 PM Re: Tyre Pressure when Hot [Re: Peter J]
Gareth H Offline
Loc: Salisbury Plain
Peter, all normal, I'd stick with the correct pressures, you could maybe adjust by a couple of psi to change the balance front to rear.
That's jogged my memory, I've got a flir camera for an android phone that is still boxed, if anybody would be interested?
Gareth
Aero 8
R Nine T
335d
BMW Power!
Top
#532931 - 14/09/18 06:24 PM Re: Tyre Pressure when Hot [Re: Peter J]
Shooter Offline
Loc: Oreton, Shropshire
I though Aero tyres were 25 all round? or maybe that's just the 18's.
Aero 8 GTN. #10
Aero 8 S5.... #10
Top
#533106 - 16/09/18 02:47 PM Re: Tyre Pressure when Hot [Re: Peter J]
AeroIan Offline
Loc: N.Ireland
On this trip I have 25 when starting (Pirelli rosso) but it is SO warm they are getting to about 30 and I do think the handling is slightly affected
Aero-Ian
Aero 8 Series 1
BMW M140i
2003 Defender 90
BMW 330d M Touring
Top
#533108 - 16/09/18 03:52 PM Re: Tyre Pressure when Hot [Re: Peter J]
aerotaff Offline
Aerolan.
Top
#533110 - 16/09/18 04:01 PM Re: Tyre Pressure when Hot [Re: Peter J]
aerotaff Offline
Aerolan. I also run rossos 25 cold and they increase to about 28 hot , so not too far off.I disconnected the morgan gauge when i got the car it was always very intermittent constantly running low compared to a manual gauge.
Em
Top
Page 1 of 2 1 2 >
