Morgan Aero 8
3 registered members (Ross, Georgetoad, Taffmog), 172 guests, and 23 spiders.
John V6 425
+8Rich 414
TBM 237
Heinz 193
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Plus Four road test
by TimG. 04/06/20 03:42 PM
tempting fate maybe
by meabh. 04/06/20 01:22 PM
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,416
Posts629,629
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
Page 8 of 8 1 2 3 4 5 6 7 8
Re: Bloomin' Sidepipes [Re: dodgyken] #574878
03/05/19 10:34 AM
03/05/19 10:34 AM
Oreton, Shropshire
Shooter Offline
Shooter  Offline
Oreton, Shropshire
I always thought that the paperwork when ordering an Aero stated that side pipes were not holomogated and were an after-fit but you paid for 'side-exit preparation'.
Maybe that is just in the UK.
Aero 8 GTN. #10
Aero 8 S5.... #10
Re: Bloomin' Sidepipes [Re: Shooter] #574879
03/05/19 11:19 AM
03/05/19 11:19 AM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
I understand you are correct.
Of course, in the UK there is no measured noise check in the MOT, and largely little real control of after market modifications.
Tarka is rated at 87db at 4725 rpm. At Castle Combe circuit they measured 86db at about 4500 rpm. I believe the car has an absolutely standard exhaust.
As there are no silencers after the ones under the running boards below the doors I cannot see that side pipes would make much, if any, more noise.
Tarka the 'Otter Mog
2014 Plus 8
Re: Bloomin' Sidepipes [Re: Peter J] #574886
03/05/19 11:45 AM
03/05/19 11:45 AM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
It may have to do with the regulations as to where the sound is measured.
Re: Bloomin' Sidepipes [Re: Gambalunga] #574933
03/05/19 02:30 PM
03/05/19 02:30 PM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
True, the UK Homologation test is "drive by", so side pipes might be louder.
2014 Plus 8
Re: Bloomin' Sidepipes [Re: Peter J] #574934
03/05/19 02:32 PM
03/05/19 02:32 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Highly likely as the sound pressure wave is travelling directly towards the microphone
(was Furloughed - now Redundant)
Re: Bloomin' Sidepipes [Re: CooperMan] #574951
03/05/19 03:58 PM
03/05/19 03:58 PM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
Perhaps the solution for the test is to simply turn the outlets so they point under the car.... then turn them back.... hide
2014 Plus 8
Re: Bloomin' Sidepipes [Re: Peter J] #574952
03/05/19 04:02 PM
03/05/19 04:02 PM
Zurich, Milan
Ale_72 Offline
Ale_72  Offline
Zurich, Milan
They seems different. The muffler on the side exhaust is smaller.
Rear
https://www.facebook.com/MorganAeroSS/photos/a.266120833573480/266121430240087/?type=3&theater
Side
https://www.facebook.com/MorganAeroSS/photos/a.266120833573480/266121566906740/?type=3&theater
2010 Violet Aero Supersports | 2010 White Boxster Spyder
Re: Bloomin' Sidepipes [Re: Ale_72] #574985
03/05/19 08:49 PM
03/05/19 08:49 PM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
Tarka has a single, quite small, polished stainless covered silencer under each running board, with the outlet running to the back, ending in a double outlet. So different again from both the examples in your photos.
2014 Plus 8
Re: Bloomin' Sidepipes [Re: dodgyken] #575574
07/05/19 12:51 PM
07/05/19 12:51 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Part of the problem may be that what we see externally as a 'silencer' my have a very different construction & baffles/restrictions internally
Some are constructed to be a Silencer, and some are just a Resonator & you can't tell from the nice shiny outer casing
Re: Bloomin' Sidepipes [Re: dodgyken] #581401
14/06/19 11:47 AM
14/06/19 11:47 AM
Zurich, Milan
Ale_72 Offline
Ale_72  Offline
Zurich, Milan
So at the end you went for the rear exhausts and ended up putting it up for sale:
https://www.autoscout24.ch/it/d/morgan-aero-8-cabriolet-occasion?vehid=6775834
Moderated by  Aeroman, Simon
