13 registered members (asmair, John07, GrumpyPa, Clipper, Tresco, bmgermany, DrFitz, Ian12345Aero8, Mark Adams, Ian Hubbard, brownbaker, Chris99, Grumpy2), 139 guests, and 13 spiders.
+8Rich 235
John V6 136
OZ 4/4 115
CooperMan 107
RichardV6 104
Modesto, Wheelybin, Bonnie66, RichT56, Morgandave
8324 Registered Users
Owners Handbook Surprise
by Ron C. 31/03/23 07:13 PM
Rest shock absorber adjustment
by Topline123. 31/03/23 05:55 PM
rear shocks
by Grumpy2. 31/03/23 04:33 PM
Super Duper 3 launch tomorrow..
by +8Rich. 31/03/23 02:52 PM
Smart Meter Fun
by DaveW. 31/03/23 11:52 AM
Roadtax tip
by CooperMan. 31/03/23 11:05 AM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,894
Posts759,840
Members8,324
Most Online1,033
Dec 28th, 2019
Wingman
Easy up hood: Plate with clip broken off #534958
29/09/18 08:38 PM
29/09/18 08:38 PM
Northern Germany
bmgermany Online sad OP
bmgermany  Online Sad OP
Northern Germany
From my hoodframe the plate with the retaining clip (at the front rail to the windscreen) is broken off at the weld seam.
I remember that someone also had this problem.
But I didn't find the posting anymore.
My question:
Does the everflex have to be removed from the rail for TIG welding?
Re: Easy up hood: Plate with clip broken off [Re: bmgermany] #534960
29/09/18 08:48 PM
29/09/18 08:48 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
John V6 has been down this road maybe a pm to him..
Regards Richard
1993 Connaught Green +8 prev
Re: Easy up hood: Plate with clip broken off [Re: bmgermany] #534962
29/09/18 08:55 PM
29/09/18 08:55 PM
U
uvk33n Offline
TM Photographer of 2008
uvk33n  Offline
U
Both of mine have failed. Take out the rubber seal in the header rail and then remove the wood screws. The rail will then separate from the hood.
See here.
Ken
Re: Easy up hood: Plate with clip broken off [Re: bmgermany] #535008
30/09/18 08:04 AM
30/09/18 08:04 AM
Suffolk, England
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk, England
It is simple. Pull off the rubber seal & unscrew it as Ken says.
I had the welder add weld to the non broken side also . MMC don't use enough in my opinion.
I then fitted a new seal.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Easy up hood: Plate with clip broken off [Re: bmgermany] #535018
30/09/18 08:41 AM
30/09/18 08:41 AM
Northern Germany
Northern Germany
Hello and thank you to all!
I´ll do it as you suggested.
I´ll try to use the old seal again, I did change the seal last year, so I try to use it again.
Re: Easy up hood: Plate with clip broken off [Re: bmgermany] #540624
02/11/18 09:53 PM
02/11/18 09:53 PM
Northern Germany
Northern Germany
Today I repaired my front hoodframe.
The main problem was to get out the 11 Phillips screws. Their heads where filled with the window glue from Teroson, that was used by the garage to fix the sealing.
On the way to my welder I bought new ssteel Torx screws so most of the work is done.
I noticed there's a plastic frame, not wood, under the stainless steel windowframe so I ripped off a screw head. A little bit of oil was very helpfull to fix the ssteelframe to the plasticframe under the hoodmaterial.
By the way, because I was looking for the best glue to use on the former used window glue I had a chat with the servicedepartment from Henkel. I was astonished how helpfull they are! I got an reply on a German holiday!
