Who's Online
0 registered (), 109 Guests and 11 Spiders online.
65 Plus 4 Four Seater back seat Lift-a-dot studs
Fuel cap seal
Touring Scotland with Anglemog.
Not out the woods yet...
"Slammed Lada"
Seeking a half tonneau for a 65 +4 four seater
by Edwin
Today at 02:12 AM
Goodwood Festival of Speed and Factory 'tickets'
by pete757
Yesterday at 06:08 PM
Use Gunk/degreaser to clean rear compartment?
by Joejoe
Yesterday at 05:16 PM
A rose between two thorns
by M3W55
Yesterday at 04:16 PM
Fossilmog Annual Hive Beach Picnic Sunday 30 June
by rid967
Yesterday at 12:47 PM
Exhaust Bobbins
by Craig Jezz
14/06/19 11:08 PM
Back on TM with a M3W on order
by lord-richfield
14/06/19 08:51 PM
arnieb, BradB, PANTHRO, MarsdenRobinson, M500
6524 Registered Users
Shout Box
Forum Stats
6,524 Registered Members
33 Forums
35,367 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 3 of 11 < 1 2 3 4 5 10 11 >
Topic Options
#538808 - 23/10/18 09:22 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
IcePack Offline
Key on my 2011 4/4 would occasionally fail. Usually removing it & holding it at arms length then trying again seemed to work. This was from new. Anyway about 4 months ago used my 2nd key & touch wood it has worked every time. Not sure what powers the keys or could their sensitivity be different.
_________________________
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Top
#538813 - 23/10/18 10:38 PM Re: Workshop Note: Immobiliser C.2016........... [Re: IcePack]
BobtheTrain Offline
Loc: Renfrewshire
Hold it to your head when you use it. Clarkson trick, never needed to try it.
Best Regards
Lang may yer lum reek
Top
#538816 - 23/10/18 10:54 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Loc: South Yorkshire
It's not a zapper Bob, just a simple key with a transducer in the plastic part. No batteries either!
The Clarkson trick does work with zappers though. I've tried it a few times.....
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#538822 - 24/10/18 12:03 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
BobtheTrain Offline
Loc: Renfrewshire
Ah! Right. Anyone know why the trick works?
Best Regards
Top
#538836 - 24/10/18 06:57 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
John V6 Offline
Loc: Suffolk
They are ultra sonic & I guess the head acts as an amplifier like the head of a whale does.
2006 Indigo Blue Roadster S1
Top
#538840 - 24/10/18 08:21 AM Re: Workshop Note: Immobiliser C.2016........... [Re: John V6]
Stewart S Offline
Loc: Lancashire, England
Big head!
2008 Bugatti Blue Roadster 4 Seater
Top
#538842 - 24/10/18 08:29 AM Re: Workshop Note: Immobiliser C.2016........... [Re: Stewart S]
CooperMan Offline
Loc: Yorkshire
Big head!
Who ? Clarkson, certainly does !
Top
#538853 - 24/10/18 11:18 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
Ray Offline
Loc: Llanelli
sorry Dave, don't understand is there nothing to internally power the key. Sounds like magic. Can't see any way of getting into the key. PS luckily this car came with four keys.
Edited by Ray (24/10/18 11:21 AM)
Top
#538861 - 24/10/18 12:49 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Google it Ray. The coil around the steering lock barrel induces a current in the chip and asks the chip to identify itself. The chip provides a code which disarms the immobiliser.
The immobiliser remains off until the key is removed and after about twenty seconds it re-arms.
Fancier chips also receive a new code each time they are used but I don't think this happens with the Ford system.
Anyway better news. I spent the morning messing with the cowl. The original key works every time with the cowl removed and the sensor ring closer.
I've re-wrapped the lock barrel, this time with leather. I've also ground away the plastic from the inside of the cowl around the lock hole to get the sensor ring as close to the key as possible. It took three fits to get an acceptable look but its back on. Since then its worked every time. Only time will tell if that's it. thumbs
Top
#538869 - 24/10/18 01:44 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
CooperMan Offline
Loc: Yorkshire
Dave, you mention Ford as the OEM for the immobiliser, (& I assume ignition lock), does that mean with the Land Rover indicator stalks we still have a mix of suppliers ?
Top
