Who's Online
2 registered (rossocorsa, Elcyd), 31 Guests and 9 Spiders online.
Last snowman waves goodby from deep Bavaria
 Morgan 1909 Runabout Electric Replica
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
Oh dear!
by Scrambledsignals
25/03/19 01:48 AM
Roll on Friday!
by Mac39
24/03/19 11:53 PM
At last the affordable 917K ;-)
by +8Rich
24/03/19 10:41 PM
Speedo dial
by DaveK
24/03/19 08:58 PM
4/4 Wings
by DaveK
24/03/19 08:45 PM
chrome rear view mirror
by Chilliblu
24/03/19 06:28 PM
Tarka is 5 years old
by Peter J
24/03/19 05:47 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,620 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
RJobso, Stuart Mort
Page 9 of 11 < 1 2 7 8 9 10 11 >
Topic Options
#545363 - 29/11/18 09:37 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
John V6 Offline
Loc: Suffolk
Dave,
that is what my Roadster does also.
_________________________
2006 Indigo Blue Roadster S1
Top
#545380 - 29/11/18 11:25 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Loc: South Yorkshire
Here's an update, and this, apparently is how the Plus 4 GDI should behave.......(I've consulted my Guru).
Key into ignition.......two seconds and two flashes and it disarms.
Leave key in ignition without turning..............
Wait 30 seconds approx, and the light goes 'flashflash flaaaaash'
So dot dot dash......and this repeats every thirty seconds while the key is in the barrel but the engine not turned on.
Mine is now doing this, so hopefully it's sorted!
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#549848 - 23/12/18 03:34 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Well, yes and no.........
It's sorted with a fully charged battery. I've tested most days since this upgrade and it's been fine. But over a week without charging the battery, and on a day when it was one degree C in the garage, it was slow to disarm. Leaving the key in place, I got one dot-dot-dash, then it rearmed.
A quick charge of the battery restored normal service.
So the voltage sensitivity is real, and just something to be aware of.
On my 2005 Roadster, the immobiliser light flashes until the ignition is switched on. This means that the sensor coil is not permanently live, and on this car there is no significant battery drain.
Top
#551581 - 03/01/19 08:15 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Probably my final word on this. Over Christmas I've allowed the battery to slowly lose charge. I've tested response each day.
Today at 3 degrees C the immobiliser was sluggish. I put the multimeter on the battery and it's showing 12.18volts. Its now back on charge. From this I'm deducing that 12volts is the point at which things might get awkward.
But I carry a 12v booster pack when we're touring so I'm reasonably confident, now I understand what's going on.
Top
#551621 - 04/01/19 07:57 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
If your battery is at 12V it's pretty flat already! smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#551626 - 04/01/19 08:38 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
Richard Wood Offline
Loc: East Harling, Norfolk UK
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#551723 - 04/01/19 04:10 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Today after the charge it showed 13.10 Volts.......
Top
#551727 - 04/01/19 04:21 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
griffo Offline
Loc: Cornwall
My spies tell me the "reluctor" which picks up the signal from the key chip is just held on with a cable tie (try checking that) and it can work loose until it fails to detect the chip. Pip pip.
www.griffopix.com
Top
#551738 - 04/01/19 05:41 PM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
DaveW Offline
Not even a cable tie griffo...see first post. Maybe there is now...
Top
#552055 - 06/01/19 10:03 AM Re: Workshop Note: Immobiliser C.2016........... [Re: DaveW]
griffo Offline
Loc: Cornwall
Thanks Dave,
I have to admit I had not read the first post. I've asked the computer gurus programming the the Ecoboost Plus 4 Plus to delete the immobiliser, which is apparently very easy. So no more chips falling out of keys and non starting issues. I will fit a "secret switch" on the power feed to the low pressure fuel pump instead.
www.griffopix.com
Top
