6 registered members (tommog, RB1, BigLes, Morph, marshalben, mphcarpaintings), 133 guests, and 32 spiders.
+8Rich 437
John V6 423
TBM 233
Heinz 191
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,425
Posts629,868
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Page 2 of 4 1 2 3 4
Re: Dashboard Mods [Re: GARYMYNARD] #538472
21/10/18 08:33 AM
21/10/18 08:33 AM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Did you make that dashboard yourself?
Very retro and superbly executed. The steering wheel boss is different, I guess you had it custom made.
One thing I notice is that you don't seem to have many switches.
Bob
1999 4/4 2 litre Zetec
Re: Dashboard Mods [Re: IvorMog] #538476
21/10/18 08:54 AM
21/10/18 08:54 AM
Ross-on Wye, Herefordshire
bilibib Offline
bilibib  Offline
Yes the Dashboard is my own design and the Steering Wheel centre button I made and had engraved.
There is the same amount of switch functions on the Dashboard as the original with the inclusion of a push button start. The four position rotary light switch replaces the Spot and Light switch, together with the Hazard switch being replaced by a button mounted centrally between the Tacho and Speedo
Owen
"bilibib"
1982 4/4 Twin Cam
Royal Ivory, Dark Red Leather
Re: Dashboard Mods [Re: GARYMYNARD] #538479
21/10/18 09:15 AM
21/10/18 09:15 AM
Rickmansworth UK
GARYMYNARD Offline OP
Rickmansworth UK
The screen vents are there as well, but until it's apart, I can't work out the max height. I would like them to be level with two main clocks
Re: Dashboard Mods [Re: GARYMYNARD] #538481
21/10/18 09:40 AM
21/10/18 09:40 AM
bilibib Offline
bilibib  Offline
The Heater Vents should not not be an issue as long as the minor clocks are not spanned too wide and to help with alignment of the clocks you can always spread and lower the Tacho and Speedo slightly as I have done
Owen
"bilibib"
1982 4/4 Twin Cam
Re: Dashboard Mods [Re: GARYMYNARD] #538645
22/10/18 06:44 PM
22/10/18 06:44 PM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
Whilst on the dashboard subject,
My 4/4 didn’t have the factory fitted clock, Its a stuck on job with a battery, it was already in the car when I purchased it. I changed the battery when it stopped working, and cut a long story short, it fell apart.
I bought another one (£35.00) so it would go into the existing circular surround (because it’s well and truly stuck on)
However, it’s stopped working again, so I was thinking this time of purchasing one of Cains (Wolf) Swiss clocks on the single mounting plate. I think they look really good on black dash boards, but not so sure on mine being a sand colour. I know it’s personal opinion but I don’t want to spoil my dash....even though it has some black on it ....
I’m also halving difficulty removing the old clock, I’ve tried prising it off slowly but it’s just not coming away. I’m afraid it will break the wood dash if I pull it too hard.
I might try some fishing wire behind it. Any advice is appreciated, including replacing clock
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
Re: Dashboard Mods [Re: GARYMYNARD] #538648
22/10/18 07:02 PM
22/10/18 07:02 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Craig, if you manage to peel off the old one and there's a bit of surface damage you could order the proper factory clock, hole saw the hole and drop the 'proper' clock in
Worked well for me with an early Roadster, the power supply is already there tucked up behind the dash
(was Furloughed - now Redundant)
Re: Dashboard Mods [Re: CooperMan] #538649
22/10/18 07:04 PM
22/10/18 07:04 PM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
Good idea, I didn’t think of that thanks Jon
Craig Jezz
Re: Dashboard Mods [Re: GARYMYNARD] #538650
22/10/18 07:11 PM
22/10/18 07:11 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Your dash will be plastic Craig, I would very gently warm the area with a heat gun and then try the fishing line behind it.
Regards Richard
1994 Connaught Green +8 prev
Re: Dashboard Mods [Re: +8Rich] #538651
22/10/18 07:14 PM
22/10/18 07:14 PM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
Thanks Rich, I will try that
Craig Jezz
Re: Dashboard Mods [Re: +8Rich] #538655
22/10/18 07:25 PM
22/10/18 07:25 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Naa, its painted marine ply, seen 'em in the paint shop, that's why they match the body colour
Page 2 of 4 1 2 3 4
Moderated by  Aeroman, Simon
