15 registered members (Jon G4LJW, planenut, Uther, Gambalunga, AAJ, milligoon, Roady, thelastgizmo, Phil+8, PiGo, Image, M3W55, Heinz, Mike D, jrt), 109 guests, and 16 spiders.
+8Rich 325
John V6 255
TBM 180
Alistair 151
Hamwich 146
3.7 Roadster turn signal noise.
by John V6. 24/09/20 11:09 AM
Local dialect
by Gordon D. 24/09/20 10:23 AM
Inside the Spitfire Factory
by Ian Wegg. 23/09/20 08:45 PM
Inside the spitfire factory
by IMHO. 23/09/20 08:06 PM
Wots Your Grammer Like?
by Clipper. 23/09/20 07:58 PM
Creaking kingpins
by Grumpy2. 23/09/20 07:10 PM
Annoying resonance at 200rpm
by Kevcaster. 23/09/20 04:33 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,448
Posts651,127
Members7,166
Most Online1,033
Dec 28th, 2019
No Birthdays
2011 +4 Overheating - But Temp Indicating Low #541993
10/11/18 11:21 AM
10/11/18 11:21 AM
Lampeter, Wales
Jon G4LJW Online content OP
Jon G4LJW  Online Content OP
Lampeter, Wales
I just got back from doing only 10 miles, and was surprised to see steam coming out of the bonnet.
The temp gauge was registering something like 80 I think. Am waiting for things to cool before checking coolant level, but I don't understand the temperature reading.
Any thoughts?
Thanks.
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #541995
10/11/18 11:24 AM
10/11/18 11:24 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
You didn’t happen to splash through a puddle near home? The CAT gets extremely hot under the wing, so if it got wet might very well issue lots of steam from under bonnet?
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Deejay] #541997
10/11/18 11:27 AM
10/11/18 11:27 AM
Lampeter, Wales
Lampeter, Wales
Ah - very interesting - lots of rain earlier today, and I went through several very large puddles!
Would that also affect the temp gauge?
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #542005
10/11/18 12:19 PM
10/11/18 12:19 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Jon, the achiles heel on the newer models is the plastic top and bottomed alloy radiators - with the car flexing it soon finds a weak spot. Most replace these with an all aluminium one. With luck it'll be a loose hose.
Regards Richard
1994 Connaught Green +8 prev
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: +8Rich] #542013
10/11/18 12:29 PM
10/11/18 12:29 PM
Lampeter, Wales
Lampeter, Wales
Thanks Rich - I'll look out for that.
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #542046
10/11/18 03:24 PM
10/11/18 03:24 PM
Lampeter, Wales
Lampeter, Wales
I don't think there's anything loose.
I took the car around the block - just 1.5 miles - and the engine seems very hot again.
Coolant level looks good though.
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #542047
10/11/18 03:25 PM
10/11/18 03:25 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
I would endorse what deejay says. It's almost certainly that. The cat gets very hot (it has to to work) which does not affect coolant temp gauge reading. It's difficult at this time of the year I know but if you can avoid splashing a hot catalyst with ice cold puddles it's a good idea. They have been known to crack and fail on Morgans because of this. I insulate my cat with heat shielding material which helps.
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: griffo] #542048
10/11/18 03:33 PM
10/11/18 03:33 PM
Lampeter, Wales
Lampeter, Wales
Thanks for that - it was impossible to drive around some of the big puddles today!
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #542052
10/11/18 03:49 PM
10/11/18 03:49 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
. Check the fan is working. I once managed to knock a spade connection off going through a flood.
Re: 2011 +4 Overheating - But Temp Indicating Low [Re: Jon G4LJW] #542054
10/11/18 03:59 PM
10/11/18 03:59 PM
South West France
CBY Offline
CBY  Offline
South West France
Check the temperature of the lower hose (output) of the radiator. If the temperature is relativity warm vs the upper hose: thermostat problem.
Regards
2005 PLUS 4
Moderated by  Aeroman, Simon
