Who's Online
19 registered (+8Rich, James B W, petemog, Craig Jezz, bmgermany, Gambalunga, KEVFITZ, Richard Wood, scratched, pete757, teifistar, Neptune, Alistair, rid967, Esprit, N22MOG, DaveW, pandy, 3Gs), 74 Guests and 18 Spiders online.
anxiety or reproach
Last snowman waves goodby from deep Bavaria
 Morgan 1909 Runabout Electric Replica
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
hybrid golf
by johncc
25/03/19 10:10 PM
chrome headlight rims.
by Chilliblu
25/03/19 06:39 PM
Whoops have I upset you !
by +8Rich
25/03/19 05:12 PM
Banner batteries - End of Life
by Alistair
25/03/19 12:52 PM
Skullmog - please get in contact !
by nippymog
25/03/19 09:32 AM
Well that’s FUBAR’d
by simonjrw
25/03/19 09:23 AM
Oh dear!
by Scrambledsignals
25/03/19 01:48 AM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,627 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
RJobso, Stuart Mort
Page 2 of 3 < 1 2 3 >
Topic Options
#548137 - 15/12/18 08:38 AM Re: Which Ctek? [Re: Jon G4LJW]
John V6 Offline
Loc: Suffolk
I bent the ali plate slightly so the wires can go to the battery. I fitted an inline fuse. The ali plate also has draught excluder foam glued to the inside edges so that it seals well.
I have used the cigarette lighter before but prefer a proper connection in case of shorts.
_________________________
2006 Indigo Blue Roadster S1
Top
#548145 - 15/12/18 09:06 AM Re: Which Ctek? [Re: Jon G4LJW]
Jack The Lad Offline
Posting Desperado
Loc: The frozen North
Found the box in the garage .
CTEK MXS 3.8 12V/3.8A RECOMMENDED BATTERY SIZE:
Charging 1.2-80Ah
Maintenance Charging 1.2-130Ah.
5 YEAR WARRANTY.
safe and easy to use
connect and forget
unique 7 step charging
extends battery life
ps. there is a bag to carry it in and a large booklet with all its details .
GOOD LUCK .
Top
#548147 - 15/12/18 09:11 AM Re: Which Ctek? [Re: Jon G4LJW]
Burgundymog Offline
Loc: Essex
I use the old fashioned method.........I drive mine regularly drive
Keith
2013 narrow bodied + 4 Ruby. Wolf performance Re-map suspension mods and K&N cone filter.
Top
#548151 - 15/12/18 09:17 AM Re: Which Ctek? [Re: Jon G4LJW]
Richard Wood Online   NoMood
Loc: East Harling, Norfolk UK
Definitely not a good choice to use the cigar lighter socket even if it appears to work fine.
Volt drop is the main reason reducing charge current to the battery and caused by:
A tenuous connection to the poorly designed power socket
Relatively thin wires to fuse
An extra 15 amp fuse (which may blow with powerful charger) and associated connection
The charger will typically have its own fusing and connecting it directly to battery will bypass all of above.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#548165 - 15/12/18 09:53 AM Re: Which Ctek? [Re: Jon G4LJW]
PHZI Offline
Agree. Wire direct to the bsttery. By the way I use a CTEK MXS 5.0. Caters for larger batteries as well, as I use on different cars. £69 on E Bay.
Top
#548174 - 15/12/18 10:18 AM Re: Which Ctek? [Re: Burgundymog]
Posting Desperado
You aint up here Keith icicles from the nose and the other part. cold
Top
#548189 - 15/12/18 12:08 PM Re: Which Ctek? [Re: Jon G4LJW]
sospan Offline
Loc: Llanelli
I use mine with the direct to battery fittings. I don’t like using the power/lighter socket as they can be loose fitting and lose contact. Luckily my battery is under the bonnet so no need to make cable extenders for the hidden batteries near the rear axle.
Red Plus8
Top
#548196 - 15/12/18 12:29 PM Re: Which Ctek? [Re: Jon G4LJW]
lowebird Offline
Loc: norfolk, UK
I have two of them and have used them both via 12v sockets in all my cars ( except the Beetle as the socket is only usable with the ignition on ) and I have had no problems.
I work on the principle that if a 12v plug is supplied then it must be safe to use them in this fashion.
Reg
Top
#548197 - 15/12/18 12:35 PM Re: Which Ctek? [Re: Jon G4LJW]
Jon G4LJW Offline
Loc: Lampeter, Wales
I've ordered the MXS 5.0, and will try the lighter socket initially. If works, that's great to start with. I will certainly look at the option of direct connection to the battery, if I can do it neatly...
Thanks for all the great info!
Jon
AM02 MOG
2011 Ivory Plus 4 Sport
Photos
Top
#548257 - 15/12/18 07:04 PM Re: Which Ctek? [Re: Jon G4LJW]
Paul F Offline
Loc: Costock, South Nottinghamshire...
I used the lighter socket initially but found that it was an unreliable connection.We go into the garage daily to get to swmbo’s car so it was checked daily and found to be giving erratic results almost daily. I gave in and hard wired a fused connection to the battery - which took 10 minutes including drilling a hole in in the plywood.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
