13 registered members (Robbie, Richard Wood, vittorio, Stringers Best Mate, 2to3wheels, ewn, Grumpy2, TBM, +8Rich, Tresco, Sir Percival, David_E, Graham, G4FUJ), 48 guests, and 7 spiders.
+8Rich 256
John V6 120
Peter J 119
Hamwich 111
Radio reception
by Riverstar. 26/01/20 12:51 PM
Coronavirus / Corona Virus
by Cat302. 26/01/20 01:54 AM
Wiper end caps
by David_E. 25/01/20 10:19 PM
Speedometer Calibration
by planenut. 25/01/20 09:02 PM
Easy-Up Hood stay
by Themorganeer. 25/01/20 07:37 PM
Aerial Fitting "HELP"
by Nostalgiajohn. 25/01/20 07:19 PM
Germany - an aera of MORGAN thieves?
by xc68anc. 25/01/20 02:01 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,081
Posts601,729
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 4 of 4 1 2 3 4
Re: Suspension problem [Re: Richard Wood] #548952
19/12/18 04:53 PM
19/12/18 04:53 PM
Reading
Rob Thornton Offline
Reading
Have you read the article by Peter Ballard linked above Rob?
Richard, I have now read the article and the details of the other advice in the thread and begin to understand!
It would seem that, as with many other aspects of Morgan ownership, there is no right or wrong way, just different levels of performance or handling as determined by the owner.
For my part I will clean the assembly and have a good look at the set up out of curiosity now but, as I am more than happy with the handling characteristics of my Plus 8 at the moment, I will leave well alone!!
Rob T
2001 Royal Ivory Plus 8
Re: Suspension problem [Re: IcePack] #548966
19/12/18 05:51 PM
19/12/18 05:51 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
Originally Posted By IcePack
Rob my car came out of the factory new.
Most of them do.
Best Regards
Lang may yer lum reek
Re: Suspension problem [Re: BobtheTrain] #548976
19/12/18 06:21 PM
19/12/18 06:21 PM
Mandello del Lario, Lake Como,...
Gambalunga Offline
Gambalunga  Offline
When my car left the factory it was an absolute mess. Unfortunately replacing the springs under warranty to resolve the ground clearance problem made the handling suffer to the point that granny with her shopping trolley could get around corners better.
Fitting the SSL systems resolved all the problems.
Re: Suspension problem [Re: DeeDee] #549545
22/12/18 09:59 AM
22/12/18 09:59 AM
South West France
CBY Offline
CBY  Offline
South West France
SSL system is the only solution to be able to adjust easlily the spring clearance in the time. With SSL you get a suspension which works in the right way: soft at the beginning of the compression and with a rate increasing after.
Original Morgan setting with a rebound spring in compression has a reverse working offering a harsh comfort on small deflection, opposite at all the other cars.
Regards
2005 PLUS 4
Re: Suspension problem [Re: Rob Thornton] #549685
22/12/18 07:59 PM
22/12/18 07:59 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
I had multiple issues with the SSL on My +8 Bitsa. The SSL is now on My DHC and I quite like it. I also liked it better on My '63 +4-4 Str but not as well as the DHC. I am using the Blue Roadster springs on the +8. I like these better than the Peter Mulberry Thrust Bearing kit with 140 in/lbs. I am getting old and trying to get comfortable and not driving like a looney anymore.
Button
Page 4 of 4 1 2 3 4
Moderated by  Aeroman, Simon
