13 registered members (KennethM, Ray, Gambalunga, jackmorini, Heinz, Bishmog, +8Rich, Mkiss, DCH, Cumbriankeith, Grumpy2, M3W55, IcePack), 178 guests, and 10 spiders.
John V6 374
+8Rich 211
TBM 153
Front suspension lubrication questions
by thelastgizmo. 25/10/20 07:46 PM
Half shaft problem and BTR axle.
by FrancisD. 25/10/20 05:48 PM
Fuel Tank Capacity. Again
by IvorMog. 25/10/20 04:55 PM
the definition of a classic sports car
by howard. 25/10/20 04:14 PM
Plastic steering column shroud
by SAE. 25/10/20 03:18 PM
My new Plus 8
by Gambalunga. 25/10/20 02:36 PM
OBD pinouts, wiring etc
by Cumbriankeith. 25/10/20 10:33 AM
Definition of a classic sports car
Another Lancastrian
For Sale: Luggage rack & front bumper
Malvern Show 2
Malvern Show 1
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,673
Posts656,191
Members7,205
Most Online1,033
Dec 28th, 2019
Iancarey
Page 4 of 4 1 2 3 4
Re: Suspension problem [Re: Richard Wood] #548952
19/12/18 04:53 PM
19/12/18 04:53 PM
Reading
Rob Thornton Offline
Reading
Have you read the article by Peter Ballard linked above Rob?
Richard, I have now read the article and the details of the other advice in the thread and begin to understand!
It would seem that, as with many other aspects of Morgan ownership, there is no right or wrong way, just different levels of performance or handling as determined by the owner.
For my part I will clean the assembly and have a good look at the set up out of curiosity now but, as I am more than happy with the handling characteristics of my Plus 8 at the moment, I will leave well alone!!
Rob T
2001 Royal Ivory Plus 8
Re: Suspension problem [Re: IcePack] #548966
19/12/18 05:51 PM
19/12/18 05:51 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
Originally Posted By IcePack
Rob my car came out of the factory new.
Most of them do.
Best Regards
Lang may yer lum reek
Re: Suspension problem [Re: BobtheTrain] #548976
19/12/18 06:21 PM
19/12/18 06:21 PM
Mandello del Lario
Gambalunga Online content
Gambalunga  Online Content
Mandello del Lario
When my car left the factory it was an absolute mess. Unfortunately replacing the springs under warranty to resolve the ground clearance problem made the handling suffer to the point that granny with her shopping trolley could get around corners better.
Fitting the SSL systems resolved all the problems.
Re: Suspension problem [Re: DeeDee] #549545
22/12/18 09:59 AM
22/12/18 09:59 AM
South West France
CBY Offline
CBY  Offline
South West France
SSL system is the only solution to be able to adjust easlily the spring clearance in the time. With SSL you get a suspension which works in the right way: soft at the beginning of the compression and with a rate increasing after.
Original Morgan setting with a rebound spring in compression has a reverse working offering a harsh comfort on small deflection, opposite at all the other cars.
Regards
2005 PLUS 4
Re: Suspension problem [Re: Rob Thornton] #549685
22/12/18 07:59 PM
22/12/18 07:59 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
I had multiple issues with the SSL on My +8 Bitsa. The SSL is now on My DHC and I quite like it. I also liked it better on My '63 +4-4 Str but not as well as the DHC. I am using the Blue Roadster springs on the +8. I like these better than the Peter Mulberry Thrust Bearing kit with 140 in/lbs. I am getting old and trying to get comfortable and not driving like a looney anymore.
Button
Page 4 of 4 1 2 3 4
Moderated by  Aeroman, Simon
