9 members (Alanv60, JohnHarris, Joe Speetjens, vbalddave, MartinB60, Methodical Ninja, John Winn, Ian Wegg, BobtheTrain), 308 guests, and 18 robots.
John V6 83
+8Rich 69
DaveW 67
Luddite 57
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,890
Members9,203
kamo30
#550142 26/12/18 09:56 AM
PAUL21 Offline OP
Can anyone suggest a solution, I turn the key in the ignition. but the lock symbol won’t go out ,This is my first time on the forum,
Merry Christmas ,
Paul21
Have you lost the little bit in the key for the immobiliser.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
If you have a spare key, try that. If it works then maybe you have lost the immobiliser chip in the key.
"Hasta la victoria siempre"
PAUL21 Offline OP
I have tried both keys , the spare is brand new and unused!!
I don't know if you are a member of the MSCC, if you are then in the December issue of Miscellany, Dave Wellings has a piece about keys and immobilisers, worth a read it could be related to your problem
Try charging the battery. One member on here found the immobiliser a little finicky about less than optimum battery volts.
Thread here
Can you give us more details on what the car is please.
Later cars have an immobiliser ring in the lock.
If the battery is low it may not work well.
As said search for the Dave Wellings thread on this
2025 MG ZS EV aka Trigger
Here's Dave's thread on the subject
http://www.talkmorgan.com/ubbthreads.php/topics/539514/1
There is an issue with later Plus 4's. Try taking the key out of the ignition then rub the fob against the ignition barrel. This is usually sufficient to get the chip close enough to the induction loop to disable the immobiliser. Once the light goes out you have 30 seconds to insert the key and start the car.
Regards
Alan
AP08 MOG
Put the key in the ignition Paul. Don't turn it.
Put a battery conditioner on and the immobiliser will disarm in a few minutes.
PS - if my theory holds true, your Plus 4 will be 2016 onwards with an autophoretic coated chassis........
PAUL21 Offline OP
Thank you all for your help, l have had the car on a trickle charge which said the battery was charged, but when I used an additional jump start the car started immediately and with all keys
Beautiful day in Edinburgh, now can take the car out ,,but will not turn engine off till I return,
Thank you all again
Great news. Enjoy the grin factor
PAUL21 Offline OP
Sorry, forgot to mention I am a member of the MSCC, I have this 2015 plus 4,and a 2018 Plus 8 50th Anniversary model
Cheers Paul
Online NoMood
Dave W to the rescue, again!
Best Regards
Lang may yer lum reek
Well done Paul,
It's so upsetting when this kind of thing happens. It seems to me immobilisers are almost designed to prevent the rightful owners of cars from enjoying them. The chip fell out of my Plus 4 key in Italy and it wouldn't start. Thank God I carried the spare key. FYI the people re-programming my ECU for the Ecoboost conversion will delete the immobiliser at my request so it will always start with the key. I shall risk that the rarity of the Mog, the steering lock and my own "secret switch" will prevent theft.
Good news. So it seems that the galvanised chassis cars are not immune from this!
I wonder how the battery conditioner was connected - direct to the battery, or via the accessory socket?
'09 Gen2 MINI Cooper ragtop
PAUL21 Offline OP
Hi Graham, is was direct to the battery with a lead which I could unplug when taking the car out,it is a fairly basic Halfords unit with a simple green light showing when charged, ,
Would you believe it, took the car out for an hour, About 2ish, it’s been parked in my garage and now won’t start, !!! Maybe the battery is not holding a charge
I have a 20 amp charger will put it on overnight , Bollocks !!
Cheers Paul
Paul,
buy a conditioner like CTEK not a charger. You need to trickle charge to keep the battery healthy.
I'll second that John!
Also Paul, check your battery electrolyte level. smile
It may be that you have cooked your battery - Graham’s suggestion re electrolyte level is the first place I would look.
Our 4/4 sits on a CTEK charger when not being used (wired to battery with a fused lead - not through the cigarette lighter socket) and we have not had a problem.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
X
X
If it's a 2015 car, and battery - I think the battery is sealed.
In cause the place they are mounted is still in technical sence "not a nice place for a long life". So now it's cold outside and in the garage. I think it's reached the end of it life.
Good chargers and conditioners shows it if the battery has a problem. And: with the most good conditioners you can also charge such a small battery like fitted in the morgan.
Best wishes
René
2018 plus4 (sports green)
