13 registered members (Edwin, John07, KEVFITZ, Budster, Wirewheel, Alistair, Paul F, Lance, Rainer Duell, NelsonG, Dada, dmh, James B W), 58 guests, and 18 spiders.
+8Rich 341
John V6 177
New Artwork
by Bunny. 21/07/19 10:58 AM
Bonnet strap For Sale on Ebay
by Redfate. 21/07/19 08:10 AM
FaceApp
by Alistair. 21/07/19 07:53 AM
LED 8700 EVO 2 headlamps
by LightSpeed. 21/07/19 03:29 AM
Steering wheel is sweating oil
by NelsonG. 20/07/19 09:27 PM
Water Melons
by +8Rich. 20/07/19 07:46 PM
Pedal Car Restoration Update
by DaveW. 20/07/19 02:45 PM
BHM breakfast 6/7/19
Wolverstone Classics on the Park
Some other little planes
All Morgans' Day 7th June 2020 Bookings now open
Some little planes.
Steve Witney, Pierre-Francois, Caroash, John d, Rogerhamp1971
6600 Registered Users
Forums33
Topics35,660
Posts575,584
Members6,600
Most Online341
Feb 11th, 2018
toitoine
Page 2 of 6 1 2 3 4 5 6
Re: Car underside cleaning [Re: CooperMan] #550268
26/12/18 07:20 PM
26/12/18 07:20 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
Originally Posted By CooperMan
Rob T, personally I take the wheels off and brush off the underside whilst dry
You can then use this opportunity to check over all the bits that should be tight, plus the brakes, check for any hoses/cables chafing & I then mask over the brake discs and give the under-arches a blast over with a coat of Waxoil, or similar
Agree, best done dry using a brush
Water to the underside, chassis washers and Morgans don’t work too well together
Too many nooks and crannies
I’d use Tectyl 506 spray after you’ve cleaned as it’s transparent amber coloured so you can see the condition of everything
Much nicer than black stuff everywhere
Just be aware that the overspray gets everywhere so do it outside on a still day
I did it in my garage and then realised very quickly I had to sheet everything including me - my Mog, me and garage ended up looking like the end scene from ET
2008 Bugatti Blue Roadster 4 Seater
Re: Car underside cleaning [Re: Rob Thornton] #550276
26/12/18 07:45 PM
26/12/18 07:45 PM
stevemag Offline
stevemag  Offline
Waxoil....on a warm day .....sorted
Magwa
2000 Porsche boxster
1975 honda tl 125
Re: Car underside cleaning [Re: stevemag] #550278
26/12/18 08:26 PM
26/12/18 08:26 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Many years ago I decided to Waxoyl my MGB GT. I wasn't sure how much to use, and assumed that more had to be better than less. After I finished I left it parked on a grassy bit of our driveway, on a hot day.
Needless to say the excess Waxoyl dripped out of all the nooks and crannies and did a fine job of killing the grass, leaving an MGB-shaped image burnt into the grass. 'Er Indoors was not best pleased.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Car underside cleaning [Re: Rob Thornton] #550280
26/12/18 08:32 PM
26/12/18 08:32 PM
South Oxfordshire
SFG Offline
SFG  Offline
South Oxfordshire
I followed a friend's recommendation to take a screw out of the door striker plate of the MX-5, and squirt waxoil in, to get to the sills. Thought this would be a good idea on the clk as well. Next time I used the CLK I found waxoil all over the seat belts.
SFG
2012 4/4 Sport
Re: Car underside cleaning [Re: Max5] #550291
26/12/18 10:37 PM
26/12/18 10:37 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
Originally Posted By Max5
Bob - are winter tyres worth it? Very definitely!! I fit them every Nov. and leave them on till the end of March.
Cheers Max5.
Best Regards
Lang may yer lum reek
Re: Car underside cleaning [Re: Rob Thornton] #550296
26/12/18 11:19 PM
26/12/18 11:19 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The centre section of a Morgan never gets soiled in my experience. The wings are best dry brushed with the wheels off, but cover the splines if you have centrelocks. I've started to use a rubber glove which works really well. Pay particular attention to where the front wing attaches under the door. The fasteners changed over time but some brackets are open fronted and retain mud.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Re: Car underside cleaning [Re: Rob Thornton] #550315
27/12/18 08:47 AM
27/12/18 08:47 AM
Reading
Rob Thornton Offline OP
Reading
Many thanks for all the advice, ideas and tips.
Its now on with the boiler suit ready to put the jacks, stands, brushes and Waxoyl (not forgetting the rubber glove!) into action.
Rob T
2001 Royal Ivory Plus 8
Re: Car underside cleaning [Re: Rob Thornton] #550324
27/12/18 09:27 AM
27/12/18 09:27 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Rob,
I would recommend you use the waxoyl in the spring / summer when the air is warmer.
This makes it easier to keep it a fluid and it flows better into all those little places before it sets off.
2006 Indigo Blue Roadster S1
Re: Car underside cleaning [Re: John V6] #550326
27/12/18 09:52 AM
27/12/18 09:52 AM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
Anyone thought of Dinitrol? Comes in different constituencies for different places under the car.
Best Regards
Re: Car underside cleaning [Re: BobtheTrain] #550328
27/12/18 10:02 AM
27/12/18 10:02 AM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I switched from Waxoyl to Bilt-Hamber Dynax S50 many years ago, following a review in Practical Classics that placed it top of all the underbody waxes in salt spray tests. I reckon it's brilliant, comes in amber or clear formulations is spray cans or tins.
I'm sure Dinitrol is pretty good, but I've been totally satisfied with Dynax so never bothered to change again.
Moderated by  Aeroman, Simon
