Who's Online
15 registered (Alistair, Ulli, Northernmorgan, Q8morgan, Gambalunga, Black Adder, Hamwich, SFG, Jabax4, BobtheTrain, pandy, SAE, dmh, AZJowett, Bloggins), 111 Guests and 11 Spiders online.
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
A day out in Felixstowe
Ecoboost Plus 4 rolling road session
Magnum Tuning Performance Chip for S&S Engine
by Bunny
23/03/19 12:04 PM
Thoughts please
by meabh
23/03/19 11:05 AM
Rear tyres for the Coupe, whats the latest ?
by Alistair
23/03/19 08:26 AM
The Brabham BT62 will race at Le Mans
by +8Rich
22/03/19 10:49 PM
Fitting a Panhard Rod
by Button
22/03/19 07:51 PM
Carol Vorderman joins MMC asadvisor ?
by sospan
22/03/19 06:59 PM
Mercedes E300 Hybrid
by Budster
22/03/19 06:26 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,605 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 2 of 3 < 1 2 3 >
Topic Options
#551131 - 01/01/19 03:30 AM Re: Is this a common leak? [Re: KenShapiro]
Dan_Lockwood Offline
Loc: O'Fallon, Missouri USA
Some smooth castings have slots cut into them like this to allow for a pry bar to be used to pop the two halves apart. This looks like a machined cut out on the one half only which would give the impression of a slot cut into the case.
I would guess that on the other side of the crankcase you'll find another similar cut in one half of the case so that the two pry bars are about 180 degrees apart for disassembly purposes.
_________________________
Dan
Dan's Car - Bike - Projects Photo Albums
Top
#551207 - 01/01/19 03:04 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Loc: Baltimore, Maryland USA
No cut like that on the other side. I would think they’d cast a cut in for prying. This is obviously sawed out.
The Original Ken
2016 Smith & Stankos Special
10,000 miles.
2014 BMW R9T
Top
#551245 - 01/01/19 05:34 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Pretty sure I’ve now identified the source of the leak. Is this the sender for the oil pressure idiot light, or what?
https://www.tm-img.com/image/YhQxn
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551249 - 01/01/19 05:45 PM Re: Is this a common leak? [Re: KenShapiro]
Hamwich Online   content
Loc: Gloucestershire, UK
Ken. Look at your picture that you've uploaded. See at the bottom, there it says "embed codes"? That's where you get all the links to be able to embed the code to link to your picture for all sorts of applications, including Bulletin Board applications like TalkMorgan.
Click on 'Embed Codes' then scroll down the list until you see 'BBCode", it's the 6th one down in the 'Full Image' section. Hover your mouse over the right hand end of the link and a little 'copy' button appears. click on that and it will copy the link to your clipboard.
The all you have to do is paste it into your TalkMorgan message and it will make the image appear direct in your post. That way people don't have to click on the link to view the image:
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#551273 - 01/01/19 08:21 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Actually, no, lol. Using my phone and don’t see “embed codes”.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551276 - 01/01/19 08:35 PM Re: Is this a common leak? [Re: KenShapiro]
Ah. I only ever use a proper computer. I'll have a look. Are you iPhone or Android?
Top
#551278 - 01/01/19 08:41 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
iPhone. My iMac finally became obsolete and I’ve been watching to see if I need to buy anew.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551286 - 01/01/19 09:36 PM Re: Is this a common leak? [Re: KenShapiro]
Bitsobrits Offline
Loc: SW Iowa, U.S.A.
[quote=KenShapiro]Pretty sure I’ve now identified the source of the leak. Is this the sender for the oil pressure idiot light, or what?
Per the parts book, it's the cam angle sensor. I believe this is used by the ECU for crank position, rpm, etc.
There is no seal shown in the parts book, but the sensor is cylindrical, so maybe an o-ring?
Edited by Bitsobrits (01/01/19 09:37 PM)
2012 M3W #458
SW Iowa
Top
#551289 - 01/01/19 10:29 PM Re: Is this a common leak? [Re: KenShapiro]
Gambalunga Online   content
Loc: Mandello del Lario, Lake Como,...
Ken. I have Android but I think iPhone would show the same thing. When you display an image it usually shows full screen at first, if I "touch" on the image again it brings up a medium sized image and underneath it a lot of details. Down 3 lines is the word "About" and next to it is an up and down pointer. This is in fact the menu which, if you touch on the "About" brings up the options;"About", "Embed codes", and "Full info". If you touch on "Embed codes" you get a list of possible embed codes with a little "Copy" button on each one. Scroll down to "BBCode", touch on the "Copy" button and then you can paste the copied embed code directly in to your post.
Have fun
Top
#551294 - 01/01/19 10:58 PM Re: Is this a common leak? [Re: Bitsobrits]
KenShapiro Offline
Thanks Steve. A big help.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
Moderator:  Aeroman
