Who's Online
3 registered (norcal_moggirl, ShaunD, M3W55), 65 Guests and 12 Spiders online.
The winter M3W
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Spot lights
by Craig Jezz
18/01/19 11:23 PM
Aero Air Bag Help
by jonathan7barrow
18/01/19 08:05 PM
VDO Clock Set
by AZJowett
18/01/19 06:23 PM
ROY POW power pack gets the Roadster started ...
by dmh
18/01/19 05:57 PM
Workshop Note -Steering Damper
by DaveW
18/01/19 05:19 PM
fan knob only working on one speed
by tom+4
18/01/19 04:49 PM
S&S X-Wedge Manual Found!
by AZJowett
18/01/19 03:22 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
33,991 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
BertR
Page 1 of 3 1 2 3 >
Topic Options
#550617 - 29/12/18 12:33 AM Is this a common leak?
KenShapiro Offline
Loc: Baltimore, Maryland USA
Just noticed a small oil leak and think it’s one of the 1/2”bolts that joins the front of the block to the rear. Love to post a picture but no idea how to on this forum. I also noticed what looks like a slice from a circular saw along the seam between the block halves... REAL strange. I’d greatly appreciate if somebody can email me (sobikes@verizon.net), letting me send you the pics for inclusion here.
_________________________
The Original Ken
2016 Smith & Stankos Special
10,000 miles.
2014 BMW R9T
Top
#550619 - 29/12/18 02:34 AM Re: Is this a common leak? [Re: KenShapiro]
Hamwich Offline
Loc: Gloucestershire, UK
Posting pictures is very straightforward. The TalkMorgan image server is free for all TalkMorgan members to use.
The basic principle is that you upload an image from your computer to the image server, and then paste a link to the image into your posting. it's all explained here:
https://www.tm-img.com/page/ifu
Have a look and give us a shout if you get stuck.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#550778 - 30/12/18 12:36 AM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Yeah...it’s Greek to me. It was simple when I first joined. Where’s the Talk Morgan image server?
Edited by KenShapiro (30/12/18 12:37 AM)
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#550779 - 30/12/18 12:46 AM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Let’s see if I git it. Here’s the strange “slice” that looks like it was done with an angle grinder:https://www.tm-img.com/image/YO3oK
https://www.tm-img.com/image/YOFm6
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#550781 - 30/12/18 01:35 AM Re: Is this a common leak? [Re: KenShapiro]
Sportster Offline
Loc: Wisconsin
Hi Ken,
From the angle of the picture it looks like a piece of the crankcase broke away. Something definitely for the dealer. Is some of the seal extruding? Everything is fixable.
Best of luck with this, Ken.
Top
#550785 - 30/12/18 05:00 AM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
It actually looks like somebody put an angle grinder in there and I can’t figure out why that would happen. It’s definitely a cut, not broken off.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#550787 - 30/12/18 06:29 AM Re: Is this a common leak? [Re: KenShapiro]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#550888 - 30/12/18 04:53 PM Re: Is this a common leak? [Re: KenShapiro]
planenut Offline
Loc: United Kingdom, Lincolnshire
I don't think the "angle grinder" cut in the crank case is a problem Ken. I have had a look at my engine and it has the same machining mark. It's a polished engine rather than a black one so maybe doesn't show up as well, I never noticed it until you mentioned it. I have no leaks from that area though.
Top
#550938 - 30/12/18 08:31 PM Re: Is this a common leak? [Re: planenut]
KenShapiro Offline
Yeah...I wasn’t clear then. No leak there. The 1/2” bolt forward of thetecwas wet around the bolt. That “slice” just surprised me. You have it too? Strange. Wonder why.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#550939 - 30/12/18 08:34 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
The leak was around the head of that (yellow arrow) bolt.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551131 - 01/01/19 03:30 AM Re: Is this a common leak? [Re: KenShapiro]
Dan_Lockwood Offline
Loc: O'Fallon, Missouri USA
Some smooth castings have slots cut into them like this to allow for a pry bar to be used to pop the two halves apart. This looks like a machined cut out on the one half only which would give the impression of a slot cut into the case.
I would guess that on the other side of the crankcase you'll find another similar cut in one half of the case so that the two pry bars are about 180 degrees apart for disassembly purposes.
Dan
Dan's Car - Bike - Projects Photo Albums
Top
#551207 - 01/01/19 03:04 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
No cut like that on the other side. I would think they’d cast a cut in for prying. This is obviously sawed out.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551245 - 01/01/19 05:34 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Pretty sure I’ve now identified the source of the leak. Is this the sender for the oil pressure idiot light, or what?
https://www.tm-img.com/image/YhQxn
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551249 - 01/01/19 05:45 PM Re: Is this a common leak? [Re: KenShapiro]
Hamwich Offline
Ken. Look at your picture that you've uploaded. See at the bottom, there it says "embed codes"? That's where you get all the links to be able to embed the code to link to your picture for all sorts of applications, including Bulletin Board applications like TalkMorgan.
Click on 'Embed Codes' then scroll down the list until you see 'BBCode", it's the 6th one down in the 'Full Image' section. Hover your mouse over the right hand end of the link and a little 'copy' button appears. click on that and it will copy the link to your clipboard.
The all you have to do is paste it into your TalkMorgan message and it will make the image appear direct in your post. That way people don't have to click on the link to view the image:
Top
#551273 - 01/01/19 08:21 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Actually, no, lol. Using my phone and don’t see “embed codes”.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551276 - 01/01/19 08:35 PM Re: Is this a common leak? [Re: KenShapiro]
Hamwich Offline
Ah. I only ever use a proper computer. I'll have a look. Are you iPhone or Android?
Top
#551278 - 01/01/19 08:41 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
iPhone. My iMac finally became obsolete and I’ve been watching to see if I need to buy anew.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551286 - 01/01/19 09:36 PM Re: Is this a common leak? [Re: KenShapiro]
Bitsobrits Offline
Loc: SW Iowa, U.S.A.
[quote=KenShapiro]Pretty sure I’ve now identified the source of the leak. Is this the sender for the oil pressure idiot light, or what?
Per the parts book, it's the cam angle sensor. I believe this is used by the ECU for crank position, rpm, etc.
There is no seal shown in the parts book, but the sensor is cylindrical, so maybe an o-ring?
Edited by Bitsobrits (01/01/19 09:37 PM)
2012 M3W #458
SW Iowa
Top
#551289 - 01/01/19 10:29 PM Re: Is this a common leak? [Re: KenShapiro]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
Ken. I have Android but I think iPhone would show the same thing. When you display an image it usually shows full screen at first, if I "touch" on the image again it brings up a medium sized image and underneath it a lot of details. Down 3 lines is the word "About" and next to it is an up and down pointer. This is in fact the menu which, if you touch on the "About" brings up the options;"About", "Embed codes", and "Full info". If you touch on "Embed codes" you get a list of possible embed codes with a little "Copy" button on each one. Scroll down to "BBCode", touch on the "Copy" button and then you can paste the copied embed code directly in to your post.
Have fun
Top
#551294 - 01/01/19 10:58 PM Re: Is this a common leak? [Re: Bitsobrits]
KenShapiro Offline
Thanks Steve. A big help.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551458 - 02/01/19 10:14 PM Re: Is this a common leak? [Re: KenShapiro]
Lance Offline
Loc: Georgia, USA
Let us know how it goes
Lance
Top
#551464 - 03/01/19 12:10 AM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
It’s an o ring on the crank position sensor. It’s not an S&S part but a Morgan one. Dealer has submitted a warrant claim.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551465 - 03/01/19 12:13 AM Re: Is this a common leak? [Re: planenut]
KenShapiro Offline
I’m curious. I sent the pictures in an email to S&S and copied Morgan, asking for an explanation. I agree it’s not a “problem” but I’m curious. I’ll let ya’ll know what they say.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#551575 - 03/01/19 07:50 PM Re: Is this a common leak? [Re: KenShapiro]
Lance Offline
Loc: Georgia, USA
See if you can find out the size. Probably a 10 cent part we can source locally
Lance
Top
#551609 - 03/01/19 11:28 PM Re: Is this a common leak? [Re: Lance]
KenShapiro Offline
Next time I get bored I’ll pop it out and let ya’ll know. Yeah... pretty sure it’s gonna be a common size o ring.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#553279 - 11/01/19 05:42 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Been running her once a week lately so the leaking stopped.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
#553281 - 11/01/19 05:43 PM Re: Is this a common leak? [Re: KenShapiro]
KenShapiro Offline
Just heard from S&S. It’s done intentionally to sus in splitting the case. Everybody should have it.
The Original Ken
10,000 miles.
2014 BMW R9T
Top
Page 1 of 3 1 2 3 >
Moderator:  Aeroman
