Who's Online
19 registered (HeadlessBlue, nippymog, spooner, Ross, Gambalunga, atalante83, bmgermany, pandy, beneviro, nick w, srapendle, Hamwich, Guten, Sir Percival, 231, Peter J, paulmog, Andrew Kidney, ewn), 115 Guests and 17 Spiders online.
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Morgan Rutherford Modsports +8
Wine with a difference
by Gambalunga
16/01/19 06:01 PM
12 volt wiring help please!
by Fat Wolfie
15/01/19 07:09 PM
Ford VW Alliance confirmed
by +8Rich
15/01/19 06:56 PM
Spotted this web site
by Jack The Lad
15/01/19 02:43 PM
Jubilee Sailing Trust
by Gambalunga
15/01/19 02:13 PM
Just in case....
by Gambalunga
15/01/19 02:07 PM
nc 500 advice
by B3MOG
14/01/19 08:25 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
33,974 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
olleyjp, tarutino
Topic Options
#550793 - 30/12/18 08:32 AM Electric steering issue on Roadster
Richard Wood Offline
Loc: East Harling, Norfolk UK
Not sure how long the electric steering assistance has been standard fit on latest Roadsters or how long it was an option before that, so unsure how much experience there is out there.
However just noticed a distinct whirring noise from mine when manouvering in or out of road junctions, despite my diminishing hearing. The noise cuts in just after wheel is turned in either direction, and continues for a similar short time after wheel is straightened.
It may have been there from new but its significantly more noticeable now with 3500+ miles on the clock. Anyone else with electric steering noticed this?
_________________________
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#550850 - 30/12/18 12:30 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
Burgundymog Offline
Loc: Essex
I have the first +4 (press car) fitted with electric power steering. Never experience any noise Richard, suggest a trip to the dealer.
Keith
2013 narrow bodied + 4 Ruby
The world is my Lobster
Top
#550857 - 30/12/18 01:13 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
Stringers Best Mate Offline
Loc: Northamptonshire UK
No noise at all from the steering on mine either, Richard..
Top
#550858 - 30/12/18 01:14 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
lowebird Offline
Loc: norfolk, UK
Same here Richard, after 3 years of wheel twirling, no noise thank goodness. Sounds like it is going to cost year some of your Xmas pressy money!!
Reg
Top
#550890 - 30/12/18 04:58 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
Thanks for responses. Needed an excuse to visit KH anyway.
Will get them to check bottom hose issue as well. Couldn't see any damage whilst jacked up for greasing today, but hose resting on steering rack support bracket with neoprene pad between doesn't allude confidence.
Top
#550920 - 30/12/18 06:43 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
sid Offline
Loc: Leics UK
Hi Richard,
There shouldn't be any noise from the steering motor, so worth getting it checked whilst under warranty.
I've just replaced the bottom hose on mine (Phil Ledgerwood sent me a repalcemnet under warranty), and the design has been altered slightly so that it no longer fouls the inner wing bolts, so with yours being a newer model maybe there isn't an issue. But worth checking all the same. And don't forget to check if the brake pipe fouls the brake servo vacuum hose, too.
Sid
2014 3.7 Roadster in Ferrari Le Mans Blue
Ex Indigo Blue '99 +4
MogMMX Innovations winner
Top
#550940 - 30/12/18 08:49 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
Thanks Sid, will add brake pipe/servo check to the list.
Following your earlier thread I checked bottom hose today from underneath, and it is clearly resting on top of the offside steering rack clamp. Pushing the hose up and away from its resting place there doesn't seem to be any damage yet, but factory must have been aware as they have secured a neoprene pad to top of rack clamp, although this is only visible from wheel side.
Top
#551047 - 31/12/18 05:00 PM Re: Electric steering issue on Roadster [Re: Richard Wood]
lowebird Offline
Loc: norfolk, UK
I did that to mine some time ago and so far, so good. How can these things still be happening. It just needs a slightly better curve for goodness sake.
Reg
Top
#551127 - 01/01/19 12:46 AM Re: Electric steering issue on Roadster [Re: Richard Wood]
DaveW Offline
Loc: South Yorkshire
The neoprene pad was a more recent addition. My Plus 4 has one. I've posted a fair bit about chafing here and it gets a mention in my book! read
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#551624 - 04/01/19 08:33 AM Re: Electric steering issue on Roadster [Re: Richard Wood]
Update on electric steering issue. After greasing front suspension, which I do every 1000 miles, problem seems to have dissapeared.
Only change is that I'm using a new flex hose connection on my Wanner grease gun and this allows positive clip on connection to grease nipples, so it all goes where it should.
Top
