Who's Online
3 registered (M3W55, Graham, G4FUJ, BLG83), 107 Guests and 16 Spiders online.
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Morgan Rutherford Modsports +8
12 volt wiring help please!
by Fat Wolfie
15/01/19 07:09 PM
Ford VW Alliance confirmed
by +8Rich
15/01/19 06:56 PM
Spotted this web site
by Jack The Lad
15/01/19 02:43 PM
Jubilee Sailing Trust
by Gambalunga
15/01/19 02:13 PM
Just in case....
by Gambalunga
15/01/19 02:07 PM
nc 500 advice
by B3MOG
14/01/19 08:25 PM
Towing a trailer in France
by Island Mog
14/01/19 08:18 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
33,973 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
olleyjp, tarutino
Page 3 of 4 < 1 2 3 4 >
Topic Options
#551132 - 01/01/19 07:07 AM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
Mogdriver Offline
Loc: Tauranga. New Zealand
Hi Dave
With your fitting of the attachment point of the panhard rod to the spring base, will that bolt that attaches the rod not hammer out on the chassis cross brace on rebound. Just looking at your first picture of the rod laid out is it not designed for the cross brace to be mounted approximately 25mm further back so that the bolt head will clear the cross brace. It means that the panhard rod will then be at a slight angle to the Chassis brace.
I admit I am not privy to the installation instructions so I may be totally out of order. Hopefully this makes sense. Comments from PGB.
Doug
From deep deep downunder.
Top
#551147 - 01/01/19 09:29 AM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
DaveW Offline
Loc: South Yorkshire
Hi Doug.
The crossmember is meant to fit hard up against the rear floor timber. It could be mounted further forward on cars with this fuel tank but not on later cars with much less space.
The six leaf springs make the bottom plate much lower than the four leaf springs. Static test shows minimal clearance so I think it will be fine.
If it knocks, I'll insert some spacers between the chassis and crossmember and file a bit away from the crossmember at the point of contact. thumbs
_________________________
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#551148 - 01/01/19 10:22 AM Re: Workshop Note - Fitting a Panhard Rod [Re: madmax]
Hamwich Offline
Loc: Gloucestershire, UK
Originally Posted By madmax
Panhard rod is a must on a trad
I would agree. After the SSL front conversion, this is the best mod one can make to improve handling.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#551152 - 01/01/19 10:56 AM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
John V6 Offline
Loc: Suffolk
It made a huge difference to my +4. Can't say on the Roadster as it had one fitted & I then added anti tramp bars to keep it all in line.
2006 Indigo Blue Roadster S1
Top
#551156 - 01/01/19 12:18 PM Re: Workshop Note - Fitting a Panhard Rod [Re: KEVFITZ]
Burgundymog Offline
Loc: Essex
Originally Posted By KEVFITZ
You do know that if you bought a +4 Supersports all your wished for modifications and performance updates would have been fitted at the factory !!!
Says the man who hasn't stopped modifying since he bought it ! laugh2
Keith
2013 narrow bodied + 4 Ruby
The world is my Lobster
Top
#551203 - 01/01/19 02:46 PM Re: Workshop Note - Fitting a Panhard Rod [Re: Burgundymog]
BobtheTrain Offline
Loc: Renfrewshire
Does he mod the rocker?
Best Regards
Lang may yer lum reek
Top
#551206 - 01/01/19 02:59 PM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
Craig Jezz Offline
Loc: Oxon
I’ve noticed SIFAB are now manufacturing Panhard Rod kits (in Miscellany)
It’s on my wish list to have one installed this year.
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
BWM 320d M Sport Xdrive
Top
#551209 - 01/01/19 03:14 PM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
Redfate Offline
Loc: London England
Personally I'm not keen on the idea of clamping the leaf springs with the bracket arrangement that the SIFAB uses, I do like the SSL method with the plate under the mounting though.
Top
#551366 - 02/01/19 01:49 PM Re: Workshop Note - Fitting a Panhard Rod [Re: DaveW]
CooperMan Offline
Loc: Yorkshire
Dave, top job as ever !
I had a Mulfab one on the S1 and it definitely made a difference
Top
#551410 - 02/01/19 05:02 PM Re: Workshop Note - Fitting a Panhard Rod [Re: Redfate]
IvorMog Offline
Loc: Staffordshire
I've been thinking about which is the better clamping method as I'm going to be fitting one soon.
The Sifab (and Mulfab) method of clamping directly onto the spring will in theory alter the movement of the spring but as it's right against the axle mounting I doubt it will have any noticeable effect. It's also well tried and tested over many years and fitments.
My slight worry with the SSL method (and remember I'm a great fan of the SSL front suspension system) is that it might induce some twisting moment into the axle clamping U bolts and I don't know what long term effect that will have on the U bolt tightness.
I think I'll go with the Sifab spring clamping system and see how the SSL method develops.
Edited by IvorMog (02/01/19 06:19 PM)
Bob
1999 4/4 1.8 Zetec Silvertop
Top
