Who's Online
2 registered (Carrotious, bmgermany), 93 Guests and 9 Spiders online.
The winter M3W
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Spot lights
by Craig Jezz
18/01/19 11:23 PM
Aero Air Bag Help
by jonathan7barrow
18/01/19 08:05 PM
VDO Clock Set
by AZJowett
18/01/19 06:23 PM
ROY POW power pack gets the Roadster started ...
by dmh
18/01/19 05:57 PM
Workshop Note -Steering Damper
by DaveW
18/01/19 05:19 PM
fan knob only working on one speed
by tom+4
18/01/19 04:49 PM
S&S X-Wedge Manual Found!
by AZJowett
18/01/19 03:22 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
33,991 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
BertR
Topic Options
#551293 - 01/01/19 10:54 PM Does Your Morgan Tick When it is Off
2Sharp Offline
Installed a new battery and my battery ran down. I noticed every now and then you hear a tick and the tachometer moves up and down. Is this normal? I assuming that is what is running the battery down when it sits.
Thanks
Top
#551297 - 02/01/19 12:07 AM Re: Does Your Morgan Tick When it is Off [Re: 2Sharp]
PaulV Offline
Loc: Oxon
No ticking for me...
1. I use a CTEK connected to the 12v accessory port in the car. Never had a problem starting after its been on this (on original 3 yr old battery)...
2. When overnighted at RTTC twice this year and the battery failed to start the car on both occasions. I took their suggestion to check and top up the battery - found the water levels low. Carry a Lithium booster pack in case of issues on travels though...
Top
#551298 - 02/01/19 12:43 AM Re: Does Your Morgan Tick When it is Off [Re: 2Sharp]
2Sharp Offline
Thanks. Maybe just better to use a tender charger. The ticking is very odd. Very intermittent timing wise and takes about 5 minutes. It is like a pulse of electricity going through to the tack.
Top
#551314 - 02/01/19 08:52 AM Re: Does Your Morgan Tick When it is Off [Re: 2Sharp]
Calypso Red Offline
Loc: Staffordshire UK
2Sharp, what model of Morgan do you have & what year is it?
_________________________
Calypso Red
1994 +8 BMW Calypso Red.
2002 4/4 4 seater BMW Calypso Red.
Top
#551341 - 02/01/19 12:13 PM Re: Does Your Morgan Tick When it is Off [Re: PaulV]
lowebird Offline
Loc: norfolk, UK
I will admit to this, but I thought Morgan batteries were either sealed for life, no fill or gel type. Is that wrong, if so I better get out to the garage and have a look.
Reg
Top
#551353 - 02/01/19 01:13 PM Re: Does Your Morgan Tick When it is Off [Re: 2Sharp]
2Sharp Offline
I have a 2017 Morgan 3 wheeler.
Top
#551356 - 02/01/19 01:27 PM Re: Does Your Morgan Tick When it is Off [Re: 2Sharp]
planenut Offline
Loc: United Kingdom, Lincolnshire
No ticking or flick of the tacho on my 2013 M3W. Suggest something is not quite right there. Try removing a fuse at a time to see what circuit is causing the "tick" as a start. Even with the immobiliser fitted your battery shouldn't drain in less a month, if it's in good condition.
Top
Moderator:  Aeroman
