Who's Online
9 registered (Neptune, Gambalunga, griffo, MJF, Supamog, Alistair, Ulli, Northernmorgan, Q8morgan), 120 Guests and 12 Spiders online.
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
A day out in Felixstowe
Ecoboost Plus 4 rolling road session
Magnum Tuning Performance Chip for S&S Engine
by Bunny
23/03/19 12:04 PM
Thoughts please
by meabh
23/03/19 11:05 AM
Rear tyres for the Coupe, whats the latest ?
by Alistair
23/03/19 08:26 AM
The Brabham BT62 will race at Le Mans
by +8Rich
22/03/19 10:49 PM
Fitting a Panhard Rod
by Button
22/03/19 07:51 PM
Carol Vorderman joins MMC asadvisor ?
by sospan
22/03/19 06:59 PM
Mercedes E300 Hybrid
by Budster
22/03/19 06:26 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,605 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 8 1 2 3 4 5 6 7 8 >
Topic Options
#552324 - 07/01/19 09:33 AM I wonder if Morgan are aware of this?
milligoon Offline
Loc: Dorset, UK
_________________________
Mark - driving
Top
#552325 - 07/01/19 09:49 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
John V6 Offline
Loc: Suffolk
Sounds like a great development.
2006 Indigo Blue Roadster S1
Top
#552326 - 07/01/19 10:10 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
waikiore Offline
Loc: auckland new zealand
Wood is and has always been a wonderful engineering material, and now being recognised as a renewable one too, in an earlier life I was working with advanced composites - mainly for racing yacht construction, and apart from very much Grand Prix level construction was looking for a more economic answer that could be utilised for the average mans yacht.
We ended up utilising certain timbers in combination with carbon fibre to give all the right properties desired with the added benefit of ease of construction for one off projects .
I will never forget setting up some samples to be tested to destruction then inviting a number of popular designers at the time to come and observe, after a number of the extremely expensive foam cores failed at limits well before any of the wood composite samples the look of enlightenment spread around the room.
99 plus 8 indigo
Top
#552330 - 07/01/19 10:54 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
Ray Offline
Loc: Llanelli
Wow an indestructible Morgan. joy
Top
#552331 - 07/01/19 11:06 AM Re: I wonder if Morgan are aware of this? [Re: waikiore]
Peter J Offline
Formerly known as Aldermog
Loc: Salisbury, UK
Wood is already a bio-composite, chemically modifying and reforming will take it to the next level.
If the re-shaping under pressure could be done in a purpose designed press - a 21st C version of the wheel arch press used by MMC - then a wood chassis might be possible!! hide
Tarka the 'Otter Mog
2014 Plus 8
Top
#552333 - 07/01/19 11:13 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
lowebird Offline
Loc: norfolk, UK
Would this wood be any use in a Morgan as part of the "design" of the current trad is that everything flexes a bit to allow some form of comfort. If they started using this super wood would they have to put proper suspension onto the cars?
Reg
Top
#552335 - 07/01/19 11:19 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
sospan Offline
Loc: Llanelli
This reminds me of “knocking in” a new cricket bat to compress the fibres to prevent cracking. We used either a rounded wooden mallet or a cricket ball stuck onto a handle. Tap, tap tap for a couple of hours. Some manufacturers used to press the new bats as a similar option. It can reduce the spring effect and many modern bats are used uncompressed hence earlier failure.
A lot of wooden beams for roof/floor support are now made up laminated instead of solid wood.
I haven’t read the whole article but fatigue is a possible issue where regular flexing occurs as would happen in a chassis.
I wonder how these superwoods would work out for lintel or I-beam replacement?
The pressing process they describe looks like it would need very hefty warm/hot presses similar to metal forges/presses.
Edited by sospan (07/01/19 11:22 AM)
Red Plus8
Top
#552336 - 07/01/19 11:22 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
John V6 Offline
Loc: Suffolk
You see particularly in Austria & Switzerland companies making beam of laminated wood of long lengths.
Top
#552338 - 07/01/19 11:25 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
sospan Offline
Loc: Llanelli
Yes John. I think Japan too as they love wooden structures.
I saw a prog about beams and the laminates were staggered and finger joints use to connect shorter lengths. Modern adhesives have really helped development too.
Red Plus8
Top
#552342 - 07/01/19 11:53 AM Re: I wonder if Morgan are aware of this? [Re: milligoon]
Jon G4LJW Offline
Loc: Lampeter, Wales
In a related article, it seems that magnetic wood, and transparent wood are also possible!
Super Wood Science
Jon
AM02 MOG
2011 Ivory Plus 4 Sport
Photos
Top
