10 registered members (TBM, Gordon D, RobCol, Scrambledsignals, M3W55, AlyMatt, Grumpy2, John V6, Tresco, Spanner Juggler), 147 guests, and 16 spiders.
John V6 366
+8Rich 236
TBM 141
CooperMan 128
plus 8 oil pressure relief valve
by Grumpy2. 31/10/20 08:57 PM
shifting
by stanley. 31/10/20 08:52 PM
Front baffle removed
by Hogzilla. 31/10/20 07:17 PM
My Plus 8 is Plus zero
by Viper. 31/10/20 05:52 PM
Rear springs
by thelastgizmo. 31/10/20 02:25 PM
Plus 8 air box upgrade
by Viper. 31/10/20 01:48 PM
RIP Sean Connery
by Paul F. 31/10/20 12:44 PM
The Great Escape Gang does Flixton
Krazy Horse Spacer
Cobra Bezel
Definition of a classic sports car
Another Lancastrian
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,721
Posts657,400
Members7,205
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 4 of 4 1 2 3 4
Re: SSL verses Rutherford? [Re: series1] #551979
05/01/19 08:31 PM
05/01/19 08:31 PM
Australia - NSW North Coast
OZ 4/4 Offline
OZ 4/4  Offline
Originally Posted By series1
Hi not long purchased a 2014 plus 4 with 2500 on the clock after a run to Yorkshire decided to renew all the suspension after looking around and trying a plus 4 with just the front fitted I decided on SSL front and rear, boy what a difference,the car is now very usable,fitted rear myself easier than i thought ,leaf springs came out easy,on front fitted chrome kingpins,steering now lighter, so very pleased with set up.If any body wants to try mine they are welcome,duncan
Sounds like a very worthwhile exercise series1, Enjoy
ps, nice offer of a drive...
Re: SSL verses Rutherford? [Re: Redfate] #552329
07/01/19 10:48 AM
07/01/19 10:48 AM
South West France
CBY Offline
CBY  Offline
South West France
Fully agree with Ivormog who well summurizes the SSL advantages.
The best improvement made on my 2005 PLUS 4. A suspension which works on the right way.
On mechanical aspect, less stress on the chassis and the radiator. Installed by myself without difficulties, but if you have to change the kingpins and the bushes you must have some mechanical know-how and a reamer.
Regards
2005 PLUS 4
Re: SSL verses Rutherford? [Re: Redfate] #552385
07/01/19 03:58 PM
07/01/19 03:58 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
The "Coil Over" shock rear suspension I have driven are trailing arm designed units. The rods go from the rear perch forward to the axle. Seems to Me this is much simpler than the SSL unit and I wonder why SSL did not use it.
Button
Re: SSL verses Rutherford? [Re: Button] #552401
07/01/19 04:59 PM
07/01/19 04:59 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Talking to Peter Ballard it seems that the SSL design was arranged as it is to give a useful amount of anti roll and anti squat, hence the angled upper links mounted forward of the axle line...
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: SSL verses Rutherford? [Re: Redfate] #552420
07/01/19 06:20 PM
07/01/19 06:20 PM
London England
Redfate Offline OP
Redfate  Offline OP
London England
Hi all,
I had my car MOT'd on Saturday by a Morgan dealer, he advised that there was some play in my front suspension but nothing much to worry about yet. It would probably be ok for another year or two yet!
So now I'm thinking of just changing to the basic SSL front kit of springs and shocks and leaving the king pins etc alone for a while longer.
It sounds as though The Rutherford set up would require new king pins and bushes at the same time which I think would be unecessary for now.
I don't push the car hard and the handling for my driving style is pretty good, I just need something that will handle todays poor roads better.
I think, listening to you guys, I'll go with a DIY fit of SSL fronts and maybe some new shocks for the rear while I'm at it :-)
2009 4/4 Sport in Red
2016 Harley Davidson Road Glide Ultra
1976 Honda Goldwing GL1000
Re: SSL verses Rutherford? [Re: Redfate] #552468
07/01/19 10:30 PM
07/01/19 10:30 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
A set of hardchrome king pins will not cost much. I would do the job while you are at it as the suspension will work much better with new kingpins and bushes.
There might be someone around who has a reamer and can help you fit them.
Re: SSL verses Rutherford? [Re: Gambalunga] #552471
07/01/19 10:42 PM
07/01/19 10:42 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Sage advice indeed. If a job is worth doing...
and of course, the fewer times things are taken apart the better!
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: SSL verses Rutherford? [Re: Peter J] #552582
08/01/19 06:28 PM
08/01/19 06:28 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
Don't understand how the angled upper links accomplish this. I would think the adjustments of the damper as well as the Spring Rate would control roll and either forward or rear mounted links squat. But remember I am a retired Accountant not Suspension Engineer.
Button
Re: SSL verses Rutherford? [Re: Deejay] #552593
08/01/19 07:06 PM
08/01/19 07:06 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Absolutely. Once the hardchrome kingpins are in it should be good for well over 50,000 miles. Do the job once and you won't have to touch it again.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Page 4 of 4 1 2 3 4
Moderated by  Aeroman, Simon
