Who's Online
0 registered (), 109 Guests and 11 Spiders online.
65 Plus 4 Four Seater back seat Lift-a-dot studs
Fuel cap seal
Touring Scotland with Anglemog.
Not out the woods yet...
"Slammed Lada"
Seeking a half tonneau for a 65 +4 four seater
by Edwin
Today at 02:12 AM
Goodwood Festival of Speed and Factory 'tickets'
by pete757
Yesterday at 06:08 PM
Use Gunk/degreaser to clean rear compartment?
by Joejoe
Yesterday at 05:16 PM
A rose between two thorns
by M3W55
Yesterday at 04:16 PM
Fossilmog Annual Hive Beach Picnic Sunday 30 June
by rid967
Yesterday at 12:47 PM
Exhaust Bobbins
by Craig Jezz
14/06/19 11:08 PM
Back on TM with a M3W on order
by lord-richfield
14/06/19 08:51 PM
arnieb, BradB, PANTHRO, MarsdenRobinson, M500
6524 Registered Users
Shout Box
Forum Stats
6,524 Registered Members
33 Forums
35,367 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 3 1 2 3 >
Topic Options
#552696 - 09/01/19 11:24 AM Poor starting?
TBM Offline
Loc: Northants, UK
She struggles to start after being left a couple of days, and this morning (6.30am and cold) took a real effort to get her going.
Once warm, or a day after use she starts on the button.
To me, this points to the battery - a new one was fitted in Nov 16, but she's been mainly say around since then and done minimal mileage.
Any other thoughts?
If in agreement, any recommendations for a battery, or will one from my local motor factors be sufficient? She gets used at least two or three times a week.
_________________________
1972 4/4 4 seater
Too many ratty motorbikes
Top
#552697 - 09/01/19 11:26 AM Re: Poor starting? [Re: TBM]
John V6 Offline
Loc: Suffolk
Do you use a battery conditioner?
Is the alternator or dynamo generating enough volts?
Are the starter motor & coil earths OK?
I have used Halfrauds batteries in 2 of my Mogs. They both lasted over 5 years at which point I sold the car.
2006 Indigo Blue Roadster S1
Top
#552699 - 09/01/19 11:35 AM Re: Poor starting? [Re: John V6]
TBM Offline
Loc: Northants, UK
Not at the moment (although I have a shed full of 'Optimates' for my bikes - I'll wire one up tonight and see how I get on)
Good call - I have my doubts about the accuracy of the ammeter, so will stick a meter on it this evening to check.
Should be - I have no issues starting when warm, but I'll check them at the weekend.
Thank you - I think the lack of use may well have 'dulled' the battery - I've done more miles in the last two months than in the last 6 years of previous ownership - I'll wager she's not been started more that 10 times since the battery was fitted.
1972 4/4 4 seater
Top
#552701 - 09/01/19 11:41 AM Re: Poor starting? [Re: TBM]
Neilda Offline
Loc: Surrey. UK
I am a very long way from being an expert in such matters, but having owned a few cars I think the amount of 'cranking amps' a battery has is pretty important. The voltage can be a bit misleading as it's the 'woof' behind the volts (the cranking amps) that tends to dictate if the motor will turn.
+8 4.8
Top
#552703 - 09/01/19 11:44 AM Re: Poor starting? [Re: TBM]
Jack The Lad Offline
Posting Desperado
Loc: The frozen North
Sounds like swmbo
Any other thoughts?
Top
#552704 - 09/01/19 11:44 AM Re: Poor starting? [Re: Neilda]
TBM Offline
Loc: Northants, UK
Yes - I've also had bike batteries that will read 12.8v, but drop dramatically when any load is put on them.
I'll compare the CCA numbers if I get to replace it.
1972 4/4 4 seater
Top
#552705 - 09/01/19 11:45 AM Re: Poor starting? [Re: TBM]
John V6 Offline
Loc: Suffolk
Correct volts that jolt mils (mA) that kill.
On my mogs the gauges are at best a guide of general direction so check the voltage with a multi meter.
Top
#552722 - 09/01/19 12:59 PM Re: Poor starting? [Re: TBM]
sospan Offline
Loc: Llanelli
What symptoms areyou getting?
Is the engine slow turning over?
Does it turn over ok but not fire up?
Slow turnover could be the battery, or a bad earth as the common issues.
Failure to fire could be fuel or spark issues needed detailed checks.
Red Plus8
Top
#552725 - 09/01/19 01:12 PM Re: Poor starting? [Re: TBM]
Paul F Offline
Loc: Costock, South Nottinghamshire...
Based on the history of the car, sounds like battery to me.
Worth checking earthing just in case. If you have the steel sheathed heater control, if it is getting hot enough to burn you, that would indicate a poor earth (don’t ask how I know!). MMC fit a flimsy earth from gearbox to chassis. For what it will cost, it is worth adding an extra earth strap in the engine compartment where you can easily check it.
In your shoes, I would fit a new battery anyway. Our 1985 4/4 was never hooked to a charger and the battery lasted around 7 years. Always started easily, until the battery started to fade. The code number on the battery and a tape measure should suffice to get the correct battery. If yours is fitted under the bonnet (4 seater IIRC?) then easy to swap. More modern cars with a constant current drain through ECU and immobiliser definitely need a float charger. With your use pattern, you shouldn’t really need one.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
#552727 - 09/01/19 01:29 PM Re: Poor starting? [Re: sospan]
TBM Offline
Loc: Northants, UK
It seems to turn over OK, but I notice a 'slowing' after third or fourth attempt. It's difficult to know whether it turning over fast enough. Once started it runs and ticks over beautifully, which makes me think spark/fuel is OK.
I had an old Suzuki GS that would appear to spin over at a spirited rate, but if the battery was anything but tiptop would fail to start. A new battery would have her starting in seconds. Old suzuki's are renowned for having 'interesting' electrics...
1972 4/4 4 seater
Top
Page 1 of 3 1 2 3 >
