Who's Online
2 registered (Elcyd, AZJowett), 39 Guests and 10 Spiders online.
Last snowman waves goodby from deep Bavaria
 Morgan 1909 Runabout Electric Replica
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
Oh dear!
by Scrambledsignals
25/03/19 01:48 AM
Roll on Friday!
by Mac39
24/03/19 11:53 PM
At last the affordable 917K ;-)
by +8Rich
24/03/19 10:41 PM
Speedo dial
by DaveK
24/03/19 08:58 PM
4/4 Wings
by DaveK
24/03/19 08:45 PM
chrome rear view mirror
by Chilliblu
24/03/19 06:28 PM
Tarka is 5 years old
by Peter J
24/03/19 05:47 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,620 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
RJobso, Stuart Mort
Page 2 of 3 < 1 2 3 >
Topic Options
#552731 - 09/01/19 02:07 PM Re: Poor starting? [Re: TBM]
IvorMog Offline
Loc: Staffordshire
Originally Posted By TBM
She struggles to start after being left a couple of days, and this morning (6.30am and cold) took a real effort to get her going.
Once warm, or a day after use she starts on the button.
To me, this points to the battery - a new one was fitted in Nov 16, but she's been mainly say around since then and done minimal mileage.
Any other thoughts?
If in agreement, any recommendations for a battery, or will one from my local motor factors be sufficient? She gets used at least two or three times a week.
I don't think you have a real problem at all, just an excuse to brag about starting your Morgan at 6.30 am on a freezing cold morning when most of us were still tucked up in a nice warm bed.
I struggle to get started these days at 6.30 on a freezing cold morning.
Maybe I should plug myself into a battery conditioner overnight.
_________________________
Bob
1999 4/4 1.8 Zetec
Top
#552738 - 09/01/19 02:30 PM Re: Poor starting? [Re: TBM]
Hamwich Offline
Loc: Gloucestershire, UK
rofl
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#552743 - 09/01/19 02:46 PM Re: Poor starting? [Re: TBM]
brownbaker Offline
I had similar with my silver top zetec,fitted a high torque starter never had a problem since
Top
#552750 - 09/01/19 03:13 PM Re: Poor starting? [Re: IvorMog]
TBM Offline
Loc: Northants, UK
Not through choice! Mrs. nicked my other car as she's having her clutch done - and it was far preferable to dragging a bike out smile
1972 4/4 4 seater
Too many ratty motorbikes
Top
#552779 - 09/01/19 05:05 PM Re: Poor starting? [Re: TBM]
TBM Offline
Loc: Northants, UK
She's charging nicely at about 14.4V, so no issues there.
Battery Voltage was showing at over 13V before I tested her (after 25mile drive home). Probaby won't drive her now till Saturday, so will check the voltage drop before I start her.
I also wonder if I'm 'over choking' her on start up? I usually try her on full choke first - I might try 1/2 to 3/4 to see if that makes a difference.
1972 4/4 4 seater
Top
#552794 - 09/01/19 05:43 PM Re: Poor starting? [Re: TBM]
Ray Offline
Loc: Llanelli
There's a good chance it may not need a lot of choke. Two or three pumps of the throttle pedal may be enough.
Edited by Ray (09/01/19 05:44 PM)
Top
#552842 - 09/01/19 08:06 PM Re: Poor starting? [Re: TBM]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
Presumably you still have the mechanical fuel pump Phil?
My '76 would turn over very slowly if left for more than a couple of days. But you say it's turning over quickly.
Check all earth connections (I added a couple of extra ones to my '76 which eased things a little). Also fitted an electronic (321) distributor and high spec coil, doing away with the points and ballast resistor.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#552844 - 09/01/19 08:09 PM Re: Poor starting? [Re: Graham, G4FUJ]
TBM Offline
Loc: Northants, UK
Yep - mechanical pump (new last year). Electronic ignition is definitely on the 'list'
1972 4/4 4 seater
Top
#552851 - 09/01/19 08:33 PM Re: Poor starting? [Re: TBM]
britmog Offline
Loc: Colorado, USA
Of course you could have a small drain on the battery when it is standing. If the drives after starting are not too long then there will not be enough charge before the next small drain. A trickle charger will cure this, also if you have an immobilizer switch then turning that off would indicate if there is a drain or not. Otherwise try disconnecting the battery when not in use and see how it performs when reconnected, this will indicate if there is a naughty drain taking place.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Top
#553143 - 11/01/19 06:24 AM Re: Poor starting? [Re: TBM]
PHZI Offline
Anyway if it turns out to be the battery then cheapest is on line, probably E Bay or Tanya Batteries. I always opt for the biggest (AH and CCA) the better, the only thing to check out is the physical dimensions of the battery tray/installation space available.
Edited by PHZI (11/01/19 06:25 AM)
Top
