5 registered members (+8Rich, Kevcaster, BigSteve, ChrisConvertible, petemog), 200 guests, and 41 spiders.
+8Rich 203
John V6 132
Hamwich 99
Rod Stuarts train set
by Bonesie. 13/11/19 05:34 AM
Painted or powdercoated front wheels
by LightSpeed. 12/11/19 09:33 PM
Deer crossing the road
by Moggo. 12/11/19 07:51 PM
Series 1 Morgan in Movie Breathe see here
by BuyBritish. 12/11/19 07:28 PM
Classic LM2014
by John07. 12/11/19 01:05 PM
2011/2012 MISCELLANY
by KEVFITZ. 12/11/19 10:17 AM
Classic Motor Hub, New Year’s Day
by Ricardo. 12/11/19 08:18 AM
Keith's 4/4 resto
New 1913 Runabout replica in progress
Alloy spare wheel Cover
Williams teasing me
Production Car Trial (PCT)
jackOCD, Rsputt, Rob82, Sib, Baker
6750 Registered Users
Topics36,592
Posts591,105
Members6,750
Most Online596
Nov 6th, 2019
petrolcol, Slikdik
Poor starting? #552696
09/01/19 11:24 AM
09/01/19 11:24 AM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
She struggles to start after being left a couple of days, and this morning (6.30am and cold) took a real effort to get her going.
Once warm, or a day after use she starts on the button.
To me, this points to the battery - a new one was fitted in Nov 16, but she's been mainly say around since then and done minimal mileage.
Any other thoughts?
If in agreement, any recommendations for a battery, or will one from my local motor factors be sufficient? She gets used at least two or three times a week.
1972 4/4 4 seater
Too many ratty motorbikes
Re: Poor starting? [Re: TBM] #552697
09/01/19 11:26 AM
09/01/19 11:26 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Do you use a battery conditioner?
Is the alternator or dynamo generating enough volts?
Are the starter motor & coil earths OK?
I have used Halfrauds batteries in 2 of my Mogs. They both lasted over 5 years at which point I sold the car.
2006 Indigo Blue Roadster S1
Re: Poor starting? [Re: John V6] #552699
09/01/19 11:35 AM
09/01/19 11:35 AM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Not at the moment (although I have a shed full of 'Optimates' for my bikes - I'll wire one up tonight and see how I get on)
Good call - I have my doubts about the accuracy of the ammeter, so will stick a meter on it this evening to check.
Should be - I have no issues starting when warm, but I'll check them at the weekend.
Thank you - I think the lack of use may well have 'dulled' the battery - I've done more miles in the last two months than in the last 6 years of previous ownership - I'll wager she's not been started more that 10 times since the battery was fitted.
1972 4/4 4 seater
Re: Poor starting? [Re: TBM] #552701
09/01/19 11:41 AM
09/01/19 11:41 AM
Surrey. UK
Neilda Offline
Neilda  Offline
Surrey. UK
I am a very long way from being an expert in such matters, but having owned a few cars I think the amount of 'cranking amps' a battery has is pretty important. The voltage can be a bit misleading as it's the 'woof' behind the volts (the cranking amps) that tends to dictate if the motor will turn.
+8 4.8
Re: Poor starting? [Re: TBM] #552703
09/01/19 11:44 AM
09/01/19 11:44 AM
The frozen North
Jack The Lad Offline
Posting Desperado
Posting Desperado
The frozen North
Sounds like swmbo
Any other thoughts?
Re: Poor starting? [Re: Neilda] #552704
09/01/19 11:44 AM
09/01/19 11:44 AM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Yes - I've also had bike batteries that will read 12.8v, but drop dramatically when any load is put on them.
I'll compare the CCA numbers if I get to replace it.
1972 4/4 4 seater
Re: Poor starting? [Re: TBM] #552705
09/01/19 11:45 AM
09/01/19 11:45 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Correct volts that jolt mils (mA) that kill.
On my mogs the gauges are at best a guide of general direction so check the voltage with a multi meter.
Re: Poor starting? [Re: TBM] #552722
09/01/19 12:59 PM
09/01/19 12:59 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
What symptoms areyou getting?
Is the engine slow turning over?
Does it turn over ok but not fire up?
Slow turnover could be the battery, or a bad earth as the common issues.
Failure to fire could be fuel or spark issues needed detailed checks.
Red Plus8
Re: Poor starting? [Re: TBM] #552725
09/01/19 01:12 PM
09/01/19 01:12 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Based on the history of the car, sounds like battery to me.
Worth checking earthing just in case. If you have the steel sheathed heater control, if it is getting hot enough to burn you, that would indicate a poor earth (don’t ask how I know!). MMC fit a flimsy earth from gearbox to chassis. For what it will cost, it is worth adding an extra earth strap in the engine compartment where you can easily check it.
In your shoes, I would fit a new battery anyway. Our 1985 4/4 was never hooked to a charger and the battery lasted around 7 years. Always started easily, until the battery started to fade. The code number on the battery and a tape measure should suffice to get the correct battery. If yours is fitted under the bonnet (4 seater IIRC?) then easy to swap. More modern cars with a constant current drain through ECU and immobiliser definitely need a float charger. With your use pattern, you shouldn’t really need one.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Poor starting? [Re: sospan] #552727
09/01/19 01:29 PM
09/01/19 01:29 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
It seems to turn over OK, but I notice a 'slowing' after third or fourth attempt. It's difficult to know whether it turning over fast enough. Once started it runs and ticks over beautifully, which makes me think spark/fuel is OK.
I had an old Suzuki GS that would appear to spin over at a spirited rate, but if the battery was anything but tiptop would fail to start. A new battery would have her starting in seconds. Old suzuki's are renowned for having 'interesting' electrics...
1972 4/4 4 seater
Moderated by  Aeroman, Simon
