Who's Online
5 registered (RB1, Crunchie Gears, Martinus, Knucklefreak, M3W55), 116 Guests and 15 Spiders online.
SwanMog Christmas party
Finished Plus 4 Side View
Mkiss Mog +4 fourseater
Management of cooling air flow
Morgan Rutherford Modsports +8
12 volt wiring help please!
by Fat Wolfie
15/01/19 07:09 PM
Ford VW Alliance confirmed
by +8Rich
15/01/19 06:56 PM
Spotted this web site
by Jack The Lad
15/01/19 02:43 PM
Jubilee Sailing Trust
by Gambalunga
15/01/19 02:13 PM
Just in case....
by Gambalunga
15/01/19 02:07 PM
nc 500 advice
by B3MOG
14/01/19 08:25 PM
Towing a trailer in France
by Island Mog
14/01/19 08:18 PM
PJS, 250swb, Mkiss, jacquesj, Dodger
6332 Registered Users
Shout Box
Forum Stats
6,332 Registered Members
33 Forums
33,973 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
olleyjp, tarutino
Page 1 of 3 1 2 3 >
Topic Options
#553033 - 10/01/19 04:21 PM Brake Lights not Working
V8Dave Offline
Loc: West Auckland, Co. Durham
Hi.
The brake lights on my 2010 Roadster are not working. I don't believe it is the fuse as the reversing light works and, according to the fuse box listing this is on the same fuse. The brake light switch is mounted at the base of the brake pedal. I have disconnected the wires from the brake switch and tried jumping them but still no brake lights. Has anyone any suggestions to locate the problem.
Top
#553055 - 10/01/19 05:09 PM Re: Brake Lights not Working [Re: V8Dave]
John V6 Offline
Loc: Suffolk
Check the earth at the rear of the car.
Is there power at the switch?
_________________________
2006 Indigo Blue Roadster S1
Top
#553060 - 10/01/19 05:25 PM Re: Brake Lights not Working [Re: John V6]
V8Dave Offline
Thanks for the quick response I will check the earth at the back of the car tomorrow. I am not sure there is power at the switch.
Top
#553071 - 10/01/19 06:05 PM Re: Brake Lights not Working [Re: V8Dave]
clubsport Offline
Loc: Kent / Se London
Once you have checked the fuse and earth, I Would buy a brake light switch, fit the new one, if it makes no difference then you have a spare.
I have got through a couple of these over the years on my 4/4.
Top
#553086 - 10/01/19 07:00 PM Re: Brake Lights not Working [Re: V8Dave]
xc68anc Offline
Loc: Germany, Rhein-Main Area
In cause the fuse mustn't be on the right place it's the first step to have a look about powerinput at the switch. The easy way: take a 12v bulb and put one cable to middle contactpoint and the other cable to the outside metal.
If the switch is broken the light would work if you fix the cables together as you had done.
If there is no power on the cable at the pedal and no fuse is broken (check ecery fuse!) than there may be a problem in the wiring.
Good luck!
René
Top
#553094 - 10/01/19 07:22 PM Re: Brake Lights not Working [Re: V8Dave]
sospan Offline
Loc: Llanelli
I had similar on my old 4/4 on the driver side rear indicator. I did the “wiggle” test on the wiring by reaching up under the wing and wiggling the wires. The earth wire was the problem. I took the light fitting off and the eatyh wire was simple rivetted to the plate and was not a tight fit. I renewed the fit , put vaseline over it and it sorted the problem. So, do as JohnV6 suggested. Check earthing.
A lot of the wiring on a Morgan is exposed and it is worth giving it a check, especially earth points.
Red Plus8
Top
#553131 - 10/01/19 11:26 PM Re: Brake Lights not Working [Re: V8Dave]
Jacques Offline
Loc: Between Paris & Montlhery - Fr...
Check all the fuses as the fuse box listing is only a joke !
My two cents
Happy Morgan +8 (2001) owner
Top
#553174 - 11/01/19 11:14 AM Re: Brake Lights not Working [Re: V8Dave]
Felix42 Offline
Loc: Newton Abbot, South Devon UK
The hydraulic brake light switches in older Morgans have a habit of burning out because the addition of the cobra light put too much current through them. The switch has very crude contacts inside (I sawed on in half once to have a look).
The solution to this is to fit a relay and/or LED lightbulbs.
Top
#553181 - 11/01/19 11:35 AM Re: Brake Lights not Working [Re: V8Dave]
DaveW Offline
Loc: South Yorkshire
I put a microswitch on the pedal of my 2005, with a relay. You could also retro fit the current pedal switch.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#553185 - 11/01/19 12:05 PM Re: Brake Lights not Working [Re: V8Dave]
V8Dave Offline
Hi,
Checked the earths and all of the fuses and all OK. It would appear that there is power reaching the switch terminals as the test light lit when connected to the live wire coming in. However when you bridge the two leads there are no brake lights coming on. Would I be right in assuming there is a connection problem between the switch and the brake lights and is there a splitter connector at the rear of the car prior to the connectors at each lamp.
Thanks
Top
#553188 - 11/01/19 12:31 PM Re: Brake Lights not Working [Re: V8Dave]
MOG 615 Offline
Loc: London
Dave
This sounds like a classic pressure switch failure to me as mentioned by John above. I assume the Series 1 Roadsters used the same switch as my 1999 +8? (Others like DaveW will know better than I)
Replacement of the switch itself is the only cure.
This is not exactly easy unless you can raise the car high enough to get good access from underneath. If you can, just remember to hold the switch body very firmly as you release each of the pipes , you don't want to bend/twist them as the job becomes a lot bigger if you do.
Andy G
1999 +8 , Indigo Blue.
Top
#553191 - 11/01/19 12:39 PM Re: Brake Lights not Working [Re: V8Dave]
Richard Wood Offline
Loc: East Harling, Norfolk UK
According to latest parts manual for classics the brake light circuit between switch and lamps passes through a four way connector which also supports the reversing light circuit. Not sure where this connector is located but pin 2 feeds all three brake lights.
I would suspect a connection issue there. The earth's are split anyway so would only affect one lamp which doesn't seem to be the case.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#553196 - 11/01/19 01:03 PM Re: Brake Lights not Working [Re: V8Dave]
DaveW Offline
Yes S1 is standard pressure switch. I left mine in place and piggy backed the microswitch across the terminals through a relay. One of my early posts covers it.
Top
#553202 - 11/01/19 01:23 PM Re: Brake Lights not Working [Re: V8Dave]
John V6 Offline
Loc: Suffolk
I went the LED route on mine.
Top
#553209 - 11/01/19 02:31 PM Re: Brake Lights not Working [Re: V8Dave]
Felix42 Offline
Top
#553230 - 11/01/19 03:29 PM Re: Brake Lights not Working [Re: V8Dave]
Graham, G4FUJ Online   content
Loc: Cheltenham, Glos. UK
Originally Posted By V8Dave
Hi.
... The brake light switch is mounted at the base of the brake pedal...
So, a micro switch I presume and not one in the hydraulic brake pipe?
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#553238 - 11/01/19 03:39 PM Re: Brake Lights not Working [Re: V8Dave]
John V6 Offline
Loc: Suffolk
It should be a micro switch by the age of the car Graham.
Top
#553243 - 11/01/19 04:07 PM Re: Brake Lights not Working [Re: V8Dave]
V8Dave Offline
Hi All,
It is a micro switch at the base of the brake pedal. There is power to the switch but when the two leads are connected there is still no brake lights. Will concentrate the search tomorrow for the four way connector that Richard mentions and hope the issue is found there. Now just need to locate it. I am hoping it's under the spare wheel.
Thanks Dave
Top
#553327 - 11/01/19 10:24 PM Re: Brake Lights not Working [Re: John V6]
As I thought John from the original description. Just double checking, as a number of replies were referencing the problems experienced with the (Land Rover) hydraulic switch.
Dave, tracing wiring can be a pain. As both brake lights are not working, at least you are looking at a common section of cable/interconnection. Good chance it may be under wheel arch rather than spare wheel space. Good luck with the search. If I was closer I'd offer an extra pair of paws/eyes, test meter &c.
'07 MINI Cooper
Top
#553400 - 12/01/19 11:10 AM Re: Brake Lights not Working [Re: John V6]
Roady Offline
Loc: Excommunicated OggieMoger
+1 - No problems since
Top
#553432 - 12/01/19 12:28 PM Re: Brake Lights not Working [Re: V8Dave]
V8Dave Offline
Hi All,
Thanks for all the relies. As of this morning have eliminated the brake switch and any issues at the rear of the car. If I run a cable from the non live of the switch to the central pin on the main connector just inside the spare wheel space next to the drivers side rear wheel arch I have brake lights. Therefore the problem would appear to be between the switch and the main connector. I assume that the simplest way to repair this will be to run a new cable from the switch to the connector but any other suggestions on moving forward would be appreciated.
Thanks,
Dave
Top
#553445 - 12/01/19 02:18 PM Re: Brake Lights not Working [Re: V8Dave]
Very likely Dave.
The cable to the rear likely runs along the right hand sill (inside the car). You would have to remove the trim / leather etc. to follow it. Have a good check around the forward leaf spring mount that side, you may find where the cable goes through the panel below the parcel shelf. Just thinking out loud, but a possible pinch point?
'07 MINI Cooper
Top
#553453 - 12/01/19 03:21 PM Re: Brake Lights not Working [Re: Graham, G4FUJ]
V8Dave Offline
Thanks Graham,
Have run a new cable from the switch to the rear and the brake lights are now working. Need to tidy up the routing and sort out the connections.
Dave
Top
Page 1 of 3 1 2 3 >
