Who's Online
2 registered (rossocorsa, Elcyd), 31 Guests and 9 Spiders online.
Last snowman waves goodby from deep Bavaria
 Morgan 1909 Runabout Electric Replica
VictoryMog June 2019 Form and Car Passes
2019 Classic Car & Restoration Show
Triumph TR4a-IRS
Oh dear!
by Scrambledsignals
25/03/19 01:48 AM
Roll on Friday!
by Mac39
24/03/19 11:53 PM
At last the affordable 917K ;-)
by +8Rich
24/03/19 10:41 PM
Speedo dial
by DaveK
24/03/19 08:58 PM
4/4 Wings
by DaveK
24/03/19 08:45 PM
chrome rear view mirror
by Chilliblu
24/03/19 06:28 PM
Tarka is 5 years old
by Peter J
24/03/19 05:47 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,620 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
RJobso, Stuart Mort
Page 2 of 3 < 1 2 3 >
Topic Options
#553188 - 11/01/19 12:31 PM Re: Brake Lights not Working [Re: V8Dave]
MOG 615 Offline
Loc: London
Dave
This sounds like a classic pressure switch failure to me as mentioned by John above. I assume the Series 1 Roadsters used the same switch as my 1999 +8? (Others like DaveW will know better than I)
Replacement of the switch itself is the only cure.
This is not exactly easy unless you can raise the car high enough to get good access from underneath. If you can, just remember to hold the switch body very firmly as you release each of the pipes , you don't want to bend/twist them as the job becomes a lot bigger if you do.
_________________________
Andy G
1999 +8 , Indigo Blue.
Top
#553191 - 11/01/19 12:39 PM Re: Brake Lights not Working [Re: V8Dave]
Richard Wood Offline
Loc: East Harling, Norfolk UK
According to latest parts manual for classics the brake light circuit between switch and lamps passes through a four way connector which also supports the reversing light circuit. Not sure where this connector is located but pin 2 feeds all three brake lights.
I would suspect a connection issue there. The earth's are split anyway so would only affect one lamp which doesn't seem to be the case.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#553196 - 11/01/19 01:03 PM Re: Brake Lights not Working [Re: V8Dave]
DaveW Offline
Loc: South Yorkshire
Yes S1 is standard pressure switch. I left mine in place and piggy backed the microswitch across the terminals through a relay. One of my early posts covers it.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#553202 - 11/01/19 01:23 PM Re: Brake Lights not Working [Re: V8Dave]
John V6 Offline
Loc: Suffolk
I went the LED route on mine.
2006 Indigo Blue Roadster S1
Top
#553209 - 11/01/19 02:31 PM Re: Brake Lights not Working [Re: V8Dave]
Felix42 Offline
Loc: Newton Abbot, South Devon UK
Top
#553230 - 11/01/19 03:29 PM Re: Brake Lights not Working [Re: V8Dave]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
Originally Posted By V8Dave
Hi.
... The brake light switch is mounted at the base of the brake pedal...
So, a micro switch I presume and not one in the hydraulic brake pipe?
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#553238 - 11/01/19 03:39 PM Re: Brake Lights not Working [Re: V8Dave]
John V6 Offline
Loc: Suffolk
It should be a micro switch by the age of the car Graham.
Top
#553243 - 11/01/19 04:07 PM Re: Brake Lights not Working [Re: V8Dave]
V8Dave Offline
Loc: West Auckland, Co. Durham
Hi All,
It is a micro switch at the base of the brake pedal. There is power to the switch but when the two leads are connected there is still no brake lights. Will concentrate the search tomorrow for the four way connector that Richard mentions and hope the issue is found there. Now just need to locate it. I am hoping it's under the spare wheel.
Thanks Dave
Top
#553327 - 11/01/19 10:24 PM Re: Brake Lights not Working [Re: John V6]
As I thought John from the original description. Just double checking, as a number of replies were referencing the problems experienced with the (Land Rover) hydraulic switch.
Dave, tracing wiring can be a pain. As both brake lights are not working, at least you are looking at a common section of cable/interconnection. Good chance it may be under wheel arch rather than spare wheel space. Good luck with the search. If I was closer I'd offer an extra pair of paws/eyes, test meter &c.
'07 MINI Cooper
Top
#553400 - 12/01/19 11:10 AM Re: Brake Lights not Working [Re: John V6]
Roady Offline
Loc: returned OggieMogger
+1 - No problems since
Top
