Who's Online
18 registered (mph, Richard Wood, Martinus, P Dron, BobJ, BuyBritish, Heinz, waikiore, britmog, DaveW, PaulV, auster, 1560, MJF, M3W55, Old man, Rog G, cerealsurfer), 120 Guests and 13 Spiders online.
More recent pics...
pic of car as suggested in welcome forum
Ford GDI engine for sale
Today at Rattray Head
The brae of Coynach
1964 4/4 - Battery
by britmog
16/02/19 08:18 PM
Seeking 1981 Red 4/4 Reg XEL358X
by andymot
16/02/19 07:05 PM
Nothing wrong with a bit of bondage.
by Eurosystem0
16/02/19 03:17 PM
Easy up hood
by DavidC
16/02/19 01:10 PM
TV Formula One on TV.
by Jack The Lad
16/02/19 11:41 AM
S3 to S5
by Gareth H
15/02/19 11:36 PM
Where are you from.
by Alistair
15/02/19 10:16 PM
Lindsay B, Reckless, nate22, Mike3W, Dutchie55
6364 Registered Users
Shout Box
Forum Stats
6,364 Registered Members
33 Forums
34,227 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Ken A, Ruut Bianchi
Page 3 of 9 < 1 2 3 4 5 6 7 8 9 >
Topic Options
#553724 - 14/01/19 07:55 AM Re: Won't idle..... [Re: TBM]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
The dip beam problem could be the switch on the steering column stalk. Some people fit relays for the headlights to reduce the current running through the switch and thereby protecting it.
Have you checked the fuel filters? It may be that you have had some dirty or water contaminated fuel at some time.
I'm not familiar with the Weber but I would have thought there should be a small filter on the fuel input plus a filter in the fuel line. If there is a drain plug on the fuel float bowl you could try draining it in case there is water or sediment in the float bowl.
Edited by Gambalunga (14/01/19 08:03 AM)
_________________________
Top
#553727 - 14/01/19 08:05 AM Re: Won't idle..... [Re: Gambalunga]
TBM Offline
Loc: Northants, UK
I upgraded to Halogens a couple of weeks ago, so that may well be the case - possibly burnt the switch out. I'll check tonight. I have a spare relay so will pop that in and bypass the switch pro tem.
It was all done by Allon White just before christmas - new filter and carb clean, but if refilling the tank is stirring up debris then it'll block up again. I'll fit a new filter and clean the gauze on the fuel pump. If it was a bike, I'd whip the tank off and give it a flush and a treatment!
At least I can now discount the 'uniformity' of the problem - that was probably just coincidence!
1972 4/4 4 seater
Too many ratty motorbikes
Top
#553738 - 14/01/19 09:19 AM Re: Won't idle..... [Re: TBM]
John V6 Offline
Loc: Suffolk
Try cleaning out the idle jet.
2006 Indigo Blue Roadster S1
Top
#553739 - 14/01/19 09:23 AM Re: Won't idle..... [Re: John V6]
TBM Offline
Loc: Northants, UK
Just 'googled' and they look are fairly accessible and easy to remove, so will have a crack at that too.
1972 4/4 4 seater
Top
#553743 - 14/01/19 09:37 AM Re: Won't idle..... [Re: TBM]
CooperMan Offline
Loc: Yorkshire
Originally Posted By TBM
Back to the drawing board.....
Started fine this morning, first 20 miles (mixture of fast road and 30mph stuff) all fine.
Got to MK and third roundabout in she stalled at idle and continued to do so at each one till I got to work (starts immediately after each stall). Removed the fuel cap when I got to work, started fine, but wouldn't idle. She will idle with about 1/3 choke.
Any thoughts? Done about 50 mile so far on this tank full.
TBM, looking at the age of your Mog, I would suggest you replace your Condenser as they are known to fail erratically when hot (assuming you're still on points & condenser ignition)
Top
#553744 - 14/01/19 09:41 AM Re: Won't idle..... [Re: CooperMan]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
Beat me to it Jon! smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Top
#553746 - 14/01/19 09:49 AM Re: Won't idle..... [Re: CooperMan]
TBM Offline
Loc: Northants, UK
Good call.
I'll get that sorted as well. Ultimately will change to an electronic but that'll in a couple of 'pay days'!
1972 4/4 4 seater
Top
#553753 - 14/01/19 11:27 AM Re: Won't idle..... [Re: TBM]
Gambalunga Offline
Yes. I wondered about an electrical problem but discounted it because it starts again straight away. So long that I haven't had to worry about points ignition that I forgot about the condenser. They cost so little that it is worthwhile changing it if only to eliminate that as the source of the problem.
Top
#553754 - 14/01/19 11:37 AM Re: Won't idle..... [Re: Gambalunga]
TBM Offline
Loc: Northants, UK
That's what's been frustrating me - if she struggled to start, then it would be easier to diagnose, but she springs back into life virtually instantly - on occasions I've just dropped the clutch and bumped her back into life very easily.
My plan so far:
Change Fuel Filter
Clean fuel pump gauze
Remove and clean idle jets.
Replace Condenser (or if I can sneak it past the Mrs, buy an electronic ignition and new coil smile )
1972 4/4 4 seater
Top
#553771 - 14/01/19 01:06 PM Re: Won't idle..... [Re: TBM]
Paul F Offline
Loc: Costock, South Nottinghamshire...
That looks like a good solid plan.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
