Who's Online
15 registered (Stewart S, CooperMan, NickCW, DonM, N22MOG, brian battersby, jimmyw, jong, rcmatt, SER, dodgyken, rainbowj, Guten, yobtaf, Budster), 53 Guests and 10 Spiders online.
Rodger's M3W oil cooler
Bonesies new car :
4/4 80th Anniversary
Dunnottar Moonrise
Rodger's M3W
oil cooler installation
by rcmatt
20/02/19 01:40 PM
Fitting a valance to my +4
by tommog
20/02/19 11:08 AM
A big welcome from the Inner Circle
by DaveW
20/02/19 10:01 AM
Spark Plugs
by James B W
20/02/19 09:30 AM
Golf Clubs
by SFG
20/02/19 08:29 AM
Im in the club !! new (to me ) +4
by Bonesie
19/02/19 11:05 PM
How do you say "Worcestershire sauce"?
by Gambalunga
19/02/19 08:44 PM
lysholmn1, LightSpeed, David Gibson, thelastgizmo, Shadmog
6386 Registered Users
Shout Box
Forum Stats
6,386 Registered Members
33 Forums
34,273 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Boshly
Page 4 of 9 < 1 2 3 4 5 6 7 8 9 >
Topic Options
#553791 - 14/01/19 03:32 PM Re: Won't idle..... [Re: TBM]
britmog Offline
Loc: Colorado, USA
For the sake of being boorish, carry out each corrective measure separately or you will never know what the actual problem was.
_________________________
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Top
#553816 - 14/01/19 05:37 PM Re: Won't idle..... [Re: britmog]
TBM Offline
Loc: Northants, UK
I think I'll start with cleaning the fuel systems - the problam is that the issue is fairly sporadic so might take weeks
On the 25 mile journey home tonight the problem continued almost immediately I put the choke in and persisted all the way home. I found that if I pulled the choke out about 2cm prior to each potential stop, she would keep running (albeit a slightly quicker tickover).
Just jerry rigged the headlights to bypass the broken column switch which took about an hour (I'm working on the drive in the dark!), started her up to turn her round on the drive and she's ticking over normally again!!!
The fact that she'll run on choke still makes me lean more towards a fuelling issue, rather that electrical but I'm baffled by her ability to 'self fix'. Usually a blocked jet in a bike means a carb strip and fettle.....
1972 4/4 4 seater
Too many ratty motorbikes
Top
#553825 - 14/01/19 06:20 PM Re: Won't idle..... [Re: TBM]
Paul F Offline
Loc: Costock, South Nottinghamshire...
Sounds like a small bit of crud flapping about in the idle jet - assuming that your choke trick is engaging the fast idle which (IIRC) is main jet.
If the car has had little use prior to your giving it a good home, then there could well be issues in the fuelling system. There may even be deterioration of some of the pipes. A friend had an issue with an MG Midget that kept losing power - transpired the fuel hose near the tank had broken down inside but still looked in good order from the outside.
Good luck.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Top
#553826 - 14/01/19 06:28 PM Re: Won't idle..... [Re: TBM]
TBM Offline
Loc: Northants, UK
Yes, I'm pretty sure that's the main problem - tank crud. Thankfully the main run of fuel pipe is copper, and everything under the engine bay is new, but I'll have a look at the last bit between tank and copper.
I've read about a 'fix' where a bit of stainless fly screen mesh is fitted over the tank pick up pipe - however the bits must be pretty tiny if they're getting through the filter and the fuel pump gauze so I doubt they'd be stopped by the mesh.
I might see if I can get a better quality filter than the plastic ones being fitted.
1972 4/4 4 seater
Top
#553842 - 14/01/19 08:19 PM Re: Won't idle..... [Re: TBM]
britmog Offline
Loc: Colorado, USA
When she idles without the use of choke, etc. the revs are at the normal level aren't they? Just making sure that the accelerator stop screw has not shifted or is loose. Also just check that the accelerator cable is moving freely and everything returns to where it should on de-acceleration.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Top
#553846 - 14/01/19 08:30 PM Re: Won't idle..... [Re: TBM]
CooperMan Online   content
Loc: Yorkshire
Originally Posted By TBM
Originally Posted By CooperMan
TBM, looking at the age of your Mog, I would suggest you replace your Condenser as they are known to fail erratically when hot (assuming you're still on points & condenser ignition)
Good call.
I'll get that sorted as well. Ultimately will change to an electronic but that'll in a couple of 'pay days'!
TBM, don't pay silly money for some of the electronic conversions on the market
I use one by Accuspark that gets rid of the points & condenser, fits inside the existing Dizzy cap and uses your existing coil, only about £30, half an hour to fit and you can still set the timing up with a basic timing light
Top
#553848 - 14/01/19 08:37 PM Re: Won't idle..... [Re: britmog]
TBM Offline
Loc: Northants, UK
When idling on the choke, she is idling faster than usual. I did originally consider that the idle screw was slowly unscrewing but I'm pretty sure it's not - I set it up nicely (and the idle mixture screw) a couple of weeks ago when she was running nicely. I've just gone out and checked - it looks like it's still in the same place, but have wound it on about 1/8 of a turn so the screw is perfectly vertical - will be easier to check if it's moved.
1972 4/4 4 seater
Top
#553850 - 14/01/19 08:40 PM Re: Won't idle..... [Re: CooperMan]
TBM Offline
Loc: Northants, UK
Yep - I was originally looking at Aldon stuff but then remembered simonbbc who I used on my Land Rovers about 10 years ago - have got a new Powerspark unit, non ballast coil and rotor for under £60! Can easily sneak that past the Mrs.... smile smile
1972 4/4 4 seater
Top
#553861 - 14/01/19 09:34 PM Re: Won't idle..... [Re: TBM]
tmg513 Offline
Loc: Powick
It could be a worn needle valve allowing the carb to flood slightly. Have a look at its tip and make sure it's perfectly conical.
1972 4/4 2 Seater
Top
#553864 - 14/01/19 09:41 PM Re: Won't idle..... [Re: tmg513]
TBM Offline
Loc: Northants, UK
The card has only done 600 miles from new, so shouldn't be worn. If the other fixes don't work, I'll start digging deeper.
1972 4/4 4 seater
Top
