Who's Online
15 registered (Stewart S, CooperMan, NickCW, DonM, N22MOG, brian battersby, jimmyw, jong, rcmatt, SER, dodgyken, rainbowj, Guten, yobtaf, Budster), 53 Guests and 10 Spiders online.
Rodger's M3W oil cooler
Bonesies new car :
4/4 80th Anniversary
Dunnottar Moonrise
Rodger's M3W
oil cooler installation
by rcmatt
20/02/19 01:40 PM
Fitting a valance to my +4
by tommog
20/02/19 11:08 AM
A big welcome from the Inner Circle
by DaveW
20/02/19 10:01 AM
Spark Plugs
by James B W
20/02/19 09:30 AM
Golf Clubs
by SFG
20/02/19 08:29 AM
Im in the club !! new (to me ) +4
by Bonesie
19/02/19 11:05 PM
How do you say "Worcestershire sauce"?
by Gambalunga
19/02/19 08:44 PM
lysholmn1, LightSpeed, David Gibson, thelastgizmo, Shadmog
6386 Registered Users
Shout Box
Forum Stats
6,386 Registered Members
33 Forums
34,273 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Boshly
Page 5 of 9 < 1 2 3 4 5 6 7 8 9 >
Topic Options
#553867 - 14/01/19 10:09 PM Re: Won't idle..... [Re: TBM]
britmog Offline
Loc: Colorado, USA
So the idle issues have occurred since you "set up" the idle mixture screw and throttle screw a few weeks ago?
_________________________
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Top
#553870 - 14/01/19 10:21 PM Re: Won't idle..... [Re: britmog]
TBM Offline
Loc: Northants, UK
No, they've been occurring since I bought her in Novemeber.
Last time it happened (before this most recent event) I wound the tickover right up to try and stop her from stalling. When she cleared herself the idle was really high, so I reduced the idle and set the mixture. Had two clear weeks, until the latest fill up....
1972 4/4 4 seater
Too many ratty motorbikes
Top
#553872 - 14/01/19 10:39 PM Re: Won't idle..... [Re: TBM]
Ray Offline
Loc: Llanelli
Have you tried the Italian tune up.... Some times it does work.
Top
#553876 - 14/01/19 11:08 PM Re: Won't idle..... [Re: TBM]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
Originally Posted By TBM
The card has only done 600 miles from new, so shouldn't be worn. If the other fixes don't work, I'll start digging deeper.
I assume that is automatic predictive text error and you actually meant "The car has only done 600 miles from new". If so it means it has been sitting unused in a garage for an awful long time. In a case like this you can get corrosion in the fuel tank due to condensed water. I have never done it but I believe that the fuel tank can be removed from under the car. It might be an idea to keep in mind the possibility of removing it and giving it a good flush and maybe a treatment or alternatively put a new tank in the budget.
The fact that it is cutting out at idle tends to eliminate the possibility of an actual fuel line blockage or it would be running lean or cutting out under load. If you have an exhaust leak that is heating the fuel line or the fuel line has bee routed too close to the exhaust it could be causing vaporisation in the fuel line.
If it is a fuel problem it is either too rich at idle (black exhaust smoke or plugs fouling) or too lean. Fuel level too high or too low or either the needle jet, the float, or the idle jet giving problems.
Have you fitted new plugs, plug caps and leads? The old ones could well be faulty. Losing the spark through a faulty plug lead is not uncommon. If still original they have probably deteriorated over the years.
A new condenser, new plugs, caps and plug leads won't cost a fortune and will pretty much eliminate ignition problems (check for any poor, corroded, or loose wiring connections too.
If that is not the problem you have to chase down the possibility of a fuelling issue.
When you get it all sorted you will have a wonderful low mileage classic.
Top
#553878 - 14/01/19 11:20 PM Re: Won't idle..... [Re: Gambalunga]
+8Rich Offline
Loc: Devonshire
Peter, reading that back I think TBM maybe meant that the carb has only got 600 miles on it from new so has been replaced recently.
I maybe wrong.
1999 Indigo +8
Top
#553882 - 15/01/19 12:09 AM Re: Won't idle..... [Re: +8Rich]
pandy Offline
Loc: West Paris, France
Won't idle ?
Get it a job with the council hide
Giles. Mogless in Paris.
Top
#553884 - 15/01/19 02:58 AM Re: Won't idle..... [Re: TBM]
morgan_75 Offline
Loc: Massachusetts, USA
A vacuum leak would cause poor idle and make it impossible to tune low speed. A blockage in the idle circuit will also make it impossible to tune. You might not notice either of these at higher engine speeds.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
Top
#553887 - 15/01/19 07:05 AM Re: Won't idle..... [Re: Ray]
TBM Offline
Loc: Northants, UK
Funny you should say that - first time it happened I was in the Cotswolds, it lasted for a couple of days and I was getting VERY frustrated - took a very fast blat up the M5 to Worcester to see my folks, and it cleared..... (I reckon it was as soon as she caught sight of the Malverns!)
Edited by TBM (15/01/19 07:06 AM)
1972 4/4 4 seater
Top
#553888 - 15/01/19 07:09 AM Re: Won't idle..... [Re: +8Rich]
TBM Offline
Loc: Northants, UK
I maybe wrong.
Correct - it's the carb.
However, although she's done about 82000 in total, she's only done about 600 in the last 6 years, so I think there will be a lot of crud in the tank getting stirred up.
I've have priced up a replacement tank as a last resort!
1972 4/4 4 seater
Top
#553889 - 15/01/19 07:14 AM Re: Won't idle..... [Re: TBM]
TBM Offline
Loc: Northants, UK
First of all, a big thank you for all the help and advice - very much appreciated.
Frustratingly, she started perfectly last night after I'd got the headlights working, and she did the 25 miles commute to work without issue......
1972 4/4 4 seater
Top
