Who's Online
16 registered (jimmyw, Stewart S, rcmatt, M3W55, Shooter, N22MOG, Ricardo, NickCW, DonM, brian battersby, jong, SER, dodgyken, rainbowj, Guten, yobtaf), 54 Guests and 10 Spiders online.
Rodger's M3W oil cooler
Bonesies new car :
4/4 80th Anniversary
Dunnottar Moonrise
Rodger's M3W
oil cooler installation
by rcmatt
20/02/19 01:40 PM
Fitting a valance to my +4
by tommog
20/02/19 11:08 AM
A big welcome from the Inner Circle
by DaveW
20/02/19 10:01 AM
Spark Plugs
by James B W
20/02/19 09:30 AM
Golf Clubs
by SFG
20/02/19 08:29 AM
Im in the club !! new (to me ) +4
by Bonesie
19/02/19 11:05 PM
How do you say "Worcestershire sauce"?
by Gambalunga
19/02/19 08:44 PM
lysholmn1, LightSpeed, David Gibson, thelastgizmo, Shadmog
6386 Registered Users
Shout Box
Forum Stats
6,386 Registered Members
33 Forums
34,273 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Boshly
Page 8 of 9 < 1 2 3 4 5 6 7 8 9 >
Topic Options
#554079 - 16/01/19 10:15 AM Re: Won't idle..... [Re: Graham, G4FUJ]
TBM Offline
Loc: Northants, UK
Just another thought - you possibly have a recirc line (excess fuel returned to fuel tank). May be worth a check.
No - thankfully just a single line.
The fact that she's playing up hot and cold, start of a journey and end of a journey, full tank and 3/4 tank and then fixing herself, points me towards a 'mechanical' issue rather than an electrical issue.
That said, when I have the problem, she the fact that she stills runs perfectly above idle, and accelerates well, and will idle with a little choke makes me think that the fuel pump, fuel line and carb is OK.
I'm going back to my original thought (prior to the cap breather) that due to lack of use, the tank is full of crap and teeny bits are making through the filter and fuel pump gauze and gumming up the idle jet. I might get a spare to carry round so I can try a quick roadside swap next time it happens.
Hopefully, with time and a few filters, everything will get flushed through!
_________________________
1972 4/4 4 seater
Too many ratty motorbikes
Top
#554082 - 16/01/19 10:33 AM Re: Won't idle..... [Re: TBM]
tmg513 Offline
Loc: Powick
Mine's got a drain plug on the bottom of the tank. Might be worth draining it when you get low to see what comes out.
1972 4/4 2 Seater
Top
#554089 - 16/01/19 11:01 AM Re: Won't idle..... [Re: tmg513]
TBM Offline
Loc: Northants, UK
Good plan, thank you. Worth sacrificing a few litres. I can give her a good 'sloshing' before hand too.
1972 4/4 4 seater
Top
#554128 - 16/01/19 02:38 PM Re: Won't idle..... [Re: TBM]
sospan Offline
Loc: Llanelli
I had a fuel problem on my 1993 4/4. It was the pump. While renewing it I decided to check the whole system. I drained the tank using the drain plug. Filtered the fuel and saw crud in it. So, I flushed the tank. Next I fitted a serviceable glass filter between tank and new pump, put new flexible pipes. New filter under the bonnet. Used Millers additive in the first few tankfulls to hopefully flush clean the solid pipes and injectors. Car went really well after that.
The lesson, I think, is that the car was 20+ years old so the fuel system was due for a bit of refurb. Luckily the tank had the drain plug which meant draining/flushing was easier. As a check I put 1 gallon into an empty tank and looked at the gauge on the dash. I then knew where the safety margin was! Mind you the gauge would fluctuate a lot on cornering. If draining the tank it would be a nice touch.
Just to edit......I flushed by draining, filtering and using the filtered fuel to slosh round thetank. As far as I could see the interior was good and no crud after the 3rd flush.
Edited by sospan (16/01/19 02:41 PM)
Red Plus8
Top
#554170 - 16/01/19 08:18 PM Re: Won't idle..... [Re: TBM]
TBM Offline
Loc: Northants, UK
Anyone know the idle jet size on the Weber twin choke carb?
Thinking about getting a spare for a quick roadside swap if it happens in future? I could just whip the original out and clean it, but knowing me I'll drop it and it'll roll down a drain so if I have a spare at least I can get home!
1972 4/4 4 seater
Top
#554172 - 16/01/19 08:36 PM Re: Won't idle..... [Re: TBM]
tmg513 Offline
Loc: Powick
Whip the jet out, it'll be engraved on the side. If the engine's been modified at any point it may have been re-jetted.
1972 4/4 2 Seater
Top
#554326 - 17/01/19 03:56 PM Re: Won't idle..... [Re: TBM]
jbk Offline
Loc: Essex
Back in the dark ages I had a similar idling problem, turned out be a shard of fibreglass in the idle jet, you could see right through the jet and it was not until I blew through it against the direction of flow that it lightly stuck into my finger. That was a Ginetta with a fibreglass fuel tank, but you might get a similar effect with a grain of sand, give it a blow, worth a try?
1993 T16 +4 Lancia Blue.
Top
#554449 - 18/01/19 01:44 AM Re: Won't idle..... [Re: TBM]
morgan_75 Offline
Loc: Massachusetts, USA
your slow running jets should be 50/45
'61 +4 DHC
'70 4/4
'80 4/4 4seater
Top
#554481 - 18/01/19 09:19 AM Re: Won't idle..... [Re: TBM]
Richard Wood Offline
Loc: East Harling, Norfolk UK
Over the years I've had a couple of cars when first purchased that wouldn't idle properly or for a period of time before stalling.
On a newish Sunbeam Imp Sport with twin Strombergs, I discovered the plastic float in one of them was leaking so full of petrol, in turn causing over rich carb. New float and perfect idle.
On an early 911S rough idle just needed distributor tweak to correct poorly set up ignition timing.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#555279 - 22/01/19 07:42 AM Re: Won't idle..... [Re: TBM]
TBM Offline
Loc: Northants, UK
Been running fine all weekend. Fitted a new fuel filter and popped out one of the idle jets (the one on the opposite side to the engine) and gave it a blow through - it's a 55. Will get a spare for emergency roadside swapouts.
Checked the history that came with the car, and she had a full fuel tank clean by Allon White about 8 years ago, so I imagine it's just a bit of surface rust (hence small particles that are clearing themselves). It all depends if she's been kept with a full tank of fuel or not. It might explain why she plays up with a full tank - slight corrosion on the upper surfaces which gets dislodged when full.
1972 4/4 4 seater
Top
