6 registered members (P964, Bluebricked, planenut, RobCol, +8Rich, MartinC), 109 guests, and 17 spiders.
+8Rich 273
John V6 169
15 months to the day...
by 3Gs. 21/08/19 07:34 PM
It’s Coming !
by sospan. 21/08/19 03:33 PM
Another M3W Exhaust Supplier
by Rog G. 21/08/19 03:12 PM
BHM Plus 6 Test Drive
by RBW. 21/08/19 01:44 PM
A real Porker
by +8Rich. 21/08/19 01:22 PM
Oil leak
by ADM3W. 21/08/19 12:51 PM
"SPORTY" exhaust note ...
by dmh. 21/08/19 12:21 PM
My Morgan related badges
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,930
Posts580,132
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
Page 1 of 4 1 2 3 4
Chrome Headlamp rings #555565
23/01/19 07:35 PM
23/01/19 07:35 PM
Cheshire
Chilliblu Offline OP
Cheshire
Am I missing something? I removed the headlamp chrome rings to clean them up a bit and now I can't get them back on. I get the two notches at the top lined up, I can get the screw at the bottom in but they wont go flush at the bottom left side. Is there a knack to getting these back on? am i missing something to get these flush. I have tried several times without much joy. Help!!!
Andy
Rolls Royce Royal Blue
MY14 Morgan Plus 4 smile
Re: Chrome Headlamp rings [Re: Chilliblu] #555566
23/01/19 07:48 PM
23/01/19 07:48 PM
South Warwickshire
Wirewheel Offline
Wirewheel  Offline
South Warwickshire
Andy, I tend to put the top of the rim on to the lamp fitting, offset and then using extended hands on each side of the rim turn the rim round until the grub screw hole underneath, lines up.
I put little arrows of masking tape on the rim and the car body where the hole needs to line up.
I hope that helps.
Ian
Wild Mogs "Carried on to the Isle of Man" 2017
Wild Mogs "Carried on to Caramulo" 2016
Re: Chrome Headlamp rings [Re: Wirewheel] #555570
23/01/19 08:08 PM
23/01/19 08:08 PM
Cheshire
Cheshire
Thanks Ian. I have tried that. Is there just the two lugs at the top and the screw at the bottom? nothing to keep the left side in?
Andy
Re: Chrome Headlamp rings [Re: Chilliblu] #555599
23/01/19 10:52 PM
23/01/19 10:52 PM
East Harling, Norfolk UK
Richard Wood Offline
MMC put a 4 inch strip of self adhesive molded strip of neoprene on top of mounting ring which makes outer rim a tad difficult to replace. Presumably to stop headlamp rattling around so kept them.
To replace I orientate pip on rim at top then carefully hook top of it onto the two lips oriented approx 1030 & 1330 on plastic bowl rim. Then push firmly down until it fits over locating hole at approx 1630. If needed the rim can just about be twisted to align perfectly with this hole before replacing self tapper. A bit of vaseline may help.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Chrome Headlamp rings [Re: Chilliblu] #555601
23/01/19 11:22 PM
23/01/19 11:22 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I put a strip of masking tape over the top of the headlamp cowl and mark the position of the pip before I take the rim off.
The neoprene strip helps to stop the whistle and sometimes needs extending.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Re: Chrome Headlamp rings [Re: Chilliblu] #555615
24/01/19 07:13 AM
24/01/19 07:13 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
The neoprene stops the whistle as Dave says.
Draught excluder self adhesive tape also works
2006 Indigo Blue Roadster S1
Re: Chrome Headlamp rings [Re: Chilliblu] #555728
24/01/19 05:45 PM
24/01/19 05:45 PM
South Warwickshire
Wirewheel Offline
Wirewheel  Offline
South Warwickshire
Hi Andy, I cannot remember whether or not there are any additional lugs. I had the whole headlamp fitting out a couple of weeks ago doing some wiring so did not take enough notice to answer your question. If I get an opportunity to have a look in the factory tomorrow I will come back to you.
Ian
Re: Chrome Headlamp rings [Re: Chilliblu] #555755
24/01/19 07:11 PM
24/01/19 07:11 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
These rings are a bugger sometimes. With mine I locate the top edge and press down, push in the bottom to locate and screw on. Witness marks( masking tape/pencil) help line it up.
Red Plus8
Re: Chrome Headlamp rings [Re: Chilliblu] #555859
25/01/19 03:53 PM
25/01/19 03:53 PM
South Warwickshire
Wirewheel Offline
Wirewheel  Offline
South Warwickshire
Andy, spoke to the guys in the factory today.
There are two lugs on the top of the headlamp mount
One at 11 o’clock and the other at 1 o’clock.
The rim is lined up and the rim located on the two lugs and with the bottom screw hole.
The rim is then given a gentle bash with the heal of your hand. There is an interference fit around the headlamp mount.
Screw the bottom screw in and job done.
I hope that helps.
Send me a private message with your email address if you want me to send you the 3 photos I took this morning.
Ian
Re: Chrome Headlamp rings [Re: Wirewheel] #555861
25/01/19 03:59 PM
25/01/19 03:59 PM
Northamptonshire UK
Stringers Best Mate Offline
Northamptonshire UK
Originally Posted By Wirewheel
a gentle bash
That's me knackered, then..
Page 1 of 4 1 2 3 4
Moderated by  Aeroman, Simon
