23 registered members (DCH, Uther, esse16, B3MOG, DickJ, Dab of oppo, tmg513, JoeSpeetjens, +8Rich, andymot, petemog, Ritchie B, Kevin Martin, John07, milligoon, Andrew Kidney, John V6, Hamwich, PaulyG, Heinz, Sir Percival, Mike D, Image), 204 guests, and 18 spiders.
John V6 457
+8Rich 403
TBM 239
Peter J 197
Late 4/4 values
by andymot. 31/05/20 10:18 AM
Corran Ferry anyone ?
by +8Rich. 31/05/20 09:31 AM
Where to go first
by thelastgizmo. 31/05/20 05:52 AM
Fossilmog Hive Beach Picnic 2020 Cancelled
by rid967. 30/05/20 10:20 PM
Testing out a steering wheel spacer
by JohnMat. 30/05/20 10:04 PM
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
Social distancing
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,371
Posts628,776
Members6,938
Most Online1,033
Dec 28th, 2019
7024, hbatts
Re: Roadster Starter Motor [Re: sospan] #556704
30/01/19 08:24 AM
30/01/19 08:24 AM
East Harling, Norfolk UK
Richard Wood Online NoMood
Originally Posted By sospan
Definitely check the solenoid and connections, especially the earth.Years ago I had a car (not Morgan) with the same symptoms of clicking but no engagement. The motor itself was ok but the solenoid failed to engage the gear. A local auto electrical specialist cleaned and sorted it. I occasionally had to tap the solenoid (with a piece of wood )on the top of the motor to unstick it.
Yes to work efficiently the solenoid armature has to be a close fit to the soft iron core surrounding it, which provides the magnetic field to energise. A tiny amount of corrosion on the armature can cause it to partially jam giving rise to the temporary cure of tapping it with a soft hammer.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Roadster Starter Motor [Re: John V6] #556781
30/01/19 04:56 PM
30/01/19 04:56 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The most unusual problem I had with a clicking solenoid was a hairline crack in the battery positive terminal.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Roadster Starter Motor [Re: John V6] #556916
31/01/19 10:30 AM
31/01/19 10:30 AM
Suffolk
John V6 Online content OP
John V6  Online Content OP
Suffolk
Too cold to fiddle today -2c. But I turned the car over & it started perfectly.
2006 Indigo Blue Roadster S1
Re: Roadster Starter Motor [Re: John V6] #557362
01/02/19 09:47 PM
01/02/19 09:47 PM
Dorset, UK
milligoon Online content
milligoon  Online Content
Dorset, UK
If it's the Jag one fitted to mine then it already is a high torque type, the problem with mine was that it was over greased and the dust from the clutch gummed up the works in the solenoid.
Stripped it down cleaned it leaving the shaft grease free, put it back on and it worked a treat.
Mark - No Longer driving
Re: Roadster Starter Motor [Re: John V6] #557458
02/02/19 02:42 PM
02/02/19 02:42 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
I had a similar problem on a K series caterham, that didn't like to start when the engine was hot. Being a passenger on a track day with my son facing oncoming traffic at Brands following a spin, reminds you why you need a reliable starter!
It was finally tracked down to the starter not being exactly square to the flywheel and ring gear this was exaggerated when hot, effectively jamming the starter. Being tucked up under the exhaust manifold, didn't help either. A high torque replacement and some fettling of the mounting flange to square it up, solved the problem.
Not spinning also helps blush
David
Aero S4
Re: Roadster Starter Motor [Re: John V6] #559335
12/02/19 11:11 AM
12/02/19 11:11 AM
Suffolk
Suffolk
Well as I had time today & it is a balmy 10c so I started the testing.
To my joy when I used a jump lead as a second earth it started. Take of the jump lead a it would only click.
The earth from the engine is hard to reach. I had to take off the air filter for access.
I cleaned up the contact areas & rebuilt it.
Will now buy a second earth lead as belt and braces.
Re: Roadster Starter Motor [Re: John V6] #559337
12/02/19 11:21 AM
12/02/19 11:21 AM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
That's a good one fixed John thumbs.
Regards Richard
1994 Connaught Green +8 prev
Re: Roadster Starter Motor [Re: John V6] #559347
12/02/19 11:50 AM
12/02/19 11:50 AM
Suffolk
Suffolk
Yes Richard. I spent last week on holiday worrying about it.
The crazy part is the earth looked fine & was tight.
Re: Roadster Starter Motor [Re: John V6] #559358
12/02/19 01:23 PM
12/02/19 01:23 PM
Good result John. As the chassis is an important part of this high current circuit it may be worth checking the negative battery connection to it as well.
Ohms law dictates that a fixed resistance will create a volt drop proportional to current.
Re: Roadster Starter Motor [Re: John V6] #559360
12/02/19 01:38 PM
12/02/19 01:38 PM
Suffolk
Suffolk
Yep, I made a mental note to self to look at all the earthing points tomorrow when I will have the time.
Moderated by  Aeroman, Simon
