10 registered members (Nick55, DJC, BigLes, Heinz, Bishmog, croftmog, PaulV, +8Rich, Kevcaster, SFG), 119 guests, and 11 spiders.
+8Rich 256
John V6 156
CooperMan 108
Babs a brief history.
by +8Rich. 24/08/19 09:54 PM
The Plus Six road ahead...
by pete757. 24/08/19 09:26 PM
Is the footwell storage box really useful?
by Marmota. 24/08/19 08:36 PM
Lavenham Classics
by Richard Wood. 24/08/19 07:28 PM
Upstaged again!
by PhilRoyle. 24/08/19 04:42 PM
Heater control sticking
by DJC. 24/08/19 03:19 PM
Plus 6 vs Jag - Pistonheads Review
by Fat Wolfie. 24/08/19 08:12 AM
FolkMog in Wales
Roads less travelled  2
Mk 2 tool tray
Roads less travelled..?
My Morgan related badges
OhioM3W, Gandalf1, BigLes, Lenmog, TVRWill
6660 Registered Users
Forums33
Topics35,962
Posts580,598
Members6,660
Most Online459
Aug 3rd, 2019
No Birthdays
Roadster Starter Motor #556568
29/01/19 04:22 PM
29/01/19 04:22 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
My S1 starter motor doesn't always turn. I get a click, the immobiliser light is off & when I rock the car in gear it will release & start.
I plan therefore to replace the starter motor.
Has anyone done that ? Any advice on how to do it & who to get a new one from?
2006 Indigo Blue Roadster S1
Re: Roadster Starter Motor [Re: John V6] #556570
29/01/19 04:24 PM
29/01/19 04:24 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
I wonder if the "Hi-Torque" type starter is available to fit these engines. Probably not necessary, just thinking out loud... smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Roadster Starter Motor [Re: John V6] #556571
29/01/19 04:29 PM
29/01/19 04:29 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
I did wonder that Graham
Re: Roadster Starter Motor [Re: John V6] #556583
29/01/19 05:50 PM
29/01/19 05:50 PM
The frozen North
Jack The Lad Offline
Posting Desperado
Posting Desperado
The frozen North
I had problems with my 4/4 1905cc sometimes it would start sometimes it refused this was anyday and any weather. A starting motor with attitude . Ben Duncan had sent me several one may start it when cold but not hot . Then another would do the other way . It was like banging my head against the brick wall . Lying in the snow is no fun . So I contacted this firm and asked if they could help they made me one and never had a problem its a few years ago one chap on TM had the same problem and I gave him the firms details he popped it on TM they sorted his problem also . May be worth a telephone call.
Here are 2
AES
Auto Electric Supplies Ltd
Worcestershire
01584 819552.
it cost me total 158.63 33/07/2010 ( HIGH TORQUE )
Also this firm in my files
PowerLite
Moor Street Brierley Hill Dudley West Midlands
DY 3SU, ENGLAND
www. powerlite-units.com
01384 261984
GOOD LUCK
Re: Roadster Starter Motor [Re: John V6] #556626
29/01/19 07:52 PM
29/01/19 07:52 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
John, never known an S1 Roadster starter to fail, are you really high mileage with 1000's of starts ?
First I would clean up the main heavy cable connection into the solenoid & engine earth strap, they often look a bit crusty on Mogs I've worked on
Re: Roadster Starter Motor [Re: John V6] #556628
29/01/19 07:58 PM
29/01/19 07:58 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Check the hole at six o'clock in the bellhousing John. You can see the ring gear, and if a cover plate isn't fitted it will allow water and road debris to enter the bellhousing.
The starter on my Roadster had a Jaguar sticker and number.....if you look at my early posts there's photo which shows the number.
Got it! http://www.talkmorgan.com/ubbthreads.php/topics/38329/2
AHVFA Jaguar 12v
3R83 11,000 AA
4161AI India
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Re: Roadster Starter Motor [Re: John V6] #556656
29/01/19 09:23 PM
29/01/19 09:23 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Dave,
I covered the bolt hole a long time ago.
In Holland this week but will check the car Friday.
Also plan to check all the connections & replace the relay.
The car has done 35.5k miles.
Re: Roadster Starter Motor [Re: John V6] #556659
29/01/19 09:56 PM
29/01/19 09:56 PM
East Harling, Norfolk UK
Richard Wood Offline
Just a thought but starter solenoid which piggybacks the motor may be at fault. Symptons are loud click but no churning of engine.
Mechanics stick a large screwdriver across main solenoid terminals and see if motor spins up. It won't engage of course but indicates which is faulty. Not sure if latest starter motors have service replacement solenoids though.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Roadster Starter Motor [Re: John V6] #556679
29/01/19 10:58 PM
29/01/19 10:58 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Definitely check the solenoid and connections, especially the earth.Years ago I had a car (not Morgan) with the same symptoms of clicking but no engagement. The motor itself was ok but the solenoid failed to engage the gear. A local auto electrical specialist cleaned and sorted it. I occasionally had to tap the solenoid (with a piece of wood )on the top of the motor to unstick it.
Red Plus8
Re: Roadster Starter Motor [Re: John V6] #556703
30/01/19 08:10 AM
30/01/19 08:10 AM
Essex
Burgundymog Offline
Burgundymog  Offline
Essex
Could be damage to the ring gear or starter dog.
Keith
2013 narrow bodied + 4 Ruby. Wolf performance Re-map suspension mods and K&N cone filter.
Re: Roadster Starter Motor [Re: sospan] #556704
30/01/19 08:24 AM
30/01/19 08:24 AM
Yes to work efficiently the solenoid armature has to be a close fit to the soft iron core surrounding it, which provides the magnetic field to energise. A tiny amount of corrosion on the armature can cause it to partially jam giving rise to the temporary cure of tapping it with a soft hammer.
Re: Roadster Starter Motor [Re: John V6] #556781
30/01/19 04:56 PM
30/01/19 04:56 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The most unusual problem I had with a clicking solenoid was a hairline crack in the battery positive terminal.
Re: Roadster Starter Motor [Re: John V6] #556916
31/01/19 10:30 AM
31/01/19 10:30 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Too cold to fiddle today -2c. But I turned the car over & it started perfectly.
Re: Roadster Starter Motor [Re: John V6] #557362
01/02/19 09:47 PM
01/02/19 09:47 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
If it's the Jag one fitted to mine then it already is a high torque type, the problem with mine was that it was over greased and the dust from the clutch gummed up the works in the solenoid.
Stripped it down cleaned it leaving the shaft grease free, put it back on and it worked a treat.
Mark - No Longer driving
Re: Roadster Starter Motor [Re: John V6] #557458
02/02/19 02:42 PM
02/02/19 02:42 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
I had a similar problem on a K series caterham, that didn't like to start when the engine was hot. Being a passenger on a track day with my son facing oncoming traffic at Brands following a spin, reminds you why you need a reliable starter!
It was finally tracked down to the starter not being exactly square to the flywheel and ring gear this was exaggerated when hot, effectively jamming the starter. Being tucked up under the exhaust manifold, didn't help either. A high torque replacement and some fettling of the mounting flange to square it up, solved the problem.
Not spinning also helps blush
David
Aero S4
Re: Roadster Starter Motor [Re: John V6] #559335
12/02/19 11:11 AM
12/02/19 11:11 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Well as I had time today & it is a balmy 10c so I started the testing.
To my joy when I used a jump lead as a second earth it started. Take of the jump lead a it would only click.
The earth from the engine is hard to reach. I had to take off the air filter for access.
I cleaned up the contact areas & rebuilt it.
Will now buy a second earth lead as belt and braces.
Re: Roadster Starter Motor [Re: John V6] #559337
12/02/19 11:21 AM
12/02/19 11:21 AM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
That's a good one fixed John thumbs.
Regards Richard
2009 4/4 Sport Green
1994 Connaught Green +8
Re: Roadster Starter Motor [Re: John V6] #559347
12/02/19 11:50 AM
12/02/19 11:50 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Yes Richard. I spent last week on holiday worrying about it.
The crazy part is the earth looked fine & was tight.
Re: Roadster Starter Motor [Re: John V6] #559358
12/02/19 01:23 PM
12/02/19 01:23 PM
Good result John. As the chassis is an important part of this high current circuit it may be worth checking the negative battery connection to it as well.
Ohms law dictates that a fixed resistance will create a volt drop proportional to current.
Re: Roadster Starter Motor [Re: John V6] #559360
12/02/19 01:38 PM
12/02/19 01:38 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Yep, I made a mental note to self to look at all the earthing points tomorrow when I will have the time.
Re: Roadster Starter Motor [Re: John V6] #559521
13/02/19 08:03 AM
13/02/19 08:03 AM
Similar problem with my first 4/4. Starter always turned, but on a cold start after a few days non-use would always be slow.
I ended up adding an additional earth lead from gearbox to chassis and replacing the battery lead.
'07 MINI Cooper
Moderated by  Aeroman, Simon
