Who's Online
9 registered (Michael P, OZ 4/4, BobtheTrain, MarioCP, Moggo, Andrew Kidney, pandy, DJC, 60Yards), 87 Guests and 13 Spiders online.
Rodger's M3W oil cooler
Bonesies new car :
4/4 80th Anniversary
Dunnottar Moonrise
Rodger's M3W
Wanted: Rebound springs
by sid
20/02/19 10:09 PM
Anyone tried these razor blades
by Jack The Lad
20/02/19 05:45 PM
by chrivi
20/02/19 05:27 PM
Happy Birthday Button you legend
by +8Rich
20/02/19 04:42 PM
Picture of 4 wheeled M3W wanted
by PaulJ
20/02/19 02:29 PM
oil cooler installation
by rcmatt
20/02/19 01:40 PM
Fitting a valance to my +4
by tommog
20/02/19 11:08 AM
lysholmn1, LightSpeed, David Gibson, thelastgizmo, Shadmog
6386 Registered Users
Shout Box
Forum Stats
6,386 Registered Members
33 Forums
34,278 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 2 of 4 < 1 2 3 4 >
Topic Options
#556984 - 31/01/19 04:17 PM Re: Garage Humidity [Re: IvorMog]
howard Offline
From another angle, the family car is never garaged ( and rarely washed) but in its ten year life to replacement, I dont get any rust issues
I think you are in danger of being a bit precious.
Top
#556997 - 31/01/19 04:45 PM Re: Garage Humidity [Re: IvorMog]
Stewart S Offline
Loc: Lancashire, England
I have an integral non heated garage with insulated cavity brick walls but I do have a dehumidifier on occationally whenever I’ve been out in damp conditions (I always dry off when wet) or if the weather is damp outside
it often amazes me how much water it can take out sometimes so I always think it’s a good thing - I’ve had a few occasions where 10 litres has been collected in 24 hours
Sometimes it can be on and it takes out a dribble but at least I know moisture isn’t killing the Mog
I’d recommend them
_________________________
2008 Bugatti Blue Roadster 4 Seater
Top
#556998 - 31/01/19 04:48 PM Re: Garage Humidity [Re: IvorMog]
Neptune Offline
Pardon my ignorance, I know very little about dehumidifiers.
Would your garage need to be well sealed, gaps around doors etc, or would I just be dehumidifying planet earth (might take a while)?
Top
#557023 - 31/01/19 06:51 PM Re: Garage Humidity [Re: IvorMog]
andymot Offline
Loc: East Sussex, ENGLAND
Best seal it up as best you can if using a dehumidifier.
I agree with Jimmy - I too have a desiccant version - they work perfectly ok in low temps where normal ones can't operate.
Do you need one? Easy to check - put some steel items in the garage and see what happens to them! Tools etc or even a piece of sheet steel. If it forms rust then maybe yes - de-humidifier needed. Not essential - just nice to have!
Since having one my instruments don't mist up hardly at all on cold days-as they used to. I aim for a RH between 45-55%. Precious? Yes I guess so but brings some piece of mind.
Remember it can also be too dry! ( well ok not in the UK during winter!) but a relative humidity of under 35% for long periods will crack leather and damage plastic items etc.
Edited by andymot (31/01/19 06:58 PM)
2015 Morgan 4/4 (Wolf tuned engine, steering and suspension)
Mazda MX5+some preserved BL relics.
Top
#557028 - 31/01/19 07:42 PM Re: Garage Humidity [Re: IvorMog]
KEVFITZ Offline
Loc: YORK
Isn't there something to be said about keeping the car outside with good air circulation under a good storm cover and use it often.
I don't have a garage but I am retired and drive it often.
More difficult I understand for those that can only manage infrequent use.
HEAR THOSE THROTTLE BODIES ROAR !!!!
Top
#557032 - 31/01/19 07:59 PM Re: Garage Humidity [Re: jimmyw]
CooperMan Offline
Loc: Yorkshire
Originally Posted By jimmyw
A desiccant dehumidifier works in cold environments
I leave it on all winter,it is set to 60% has 3 power settings and drains into a large container.
The pure water is good for mixing with antifreeze for coolant changes .
My wife also used it in her iron. Pure steam .
Mine must be one of those, I think it's called a Ruby Dry ?
a little bonus is that it raises the garage temp a couple of degrees, which is handy this time of year
Top
#557034 - 31/01/19 08:03 PM Re: Garage Humidity [Re: IvorMog]
Alistair Offline
Smile, it confuses them
Loc: Hampshire
How well sealed and insulated is the garage?
Do you have other things in there that would benefit as well?
A carcoon or other brand of car bubble might work out cheaper in the long run? https://www.demon-tweeks.com/carcoon-evo-outdoor-car-storage-system-525191/
Just time to burn a little more petrol before dinner.
Top
#557040 - 31/01/19 08:29 PM Re: Garage Humidity [Re: IvorMog]
Craig Jezz Offline
Loc: Oxon
I just checked my garage temperature this evening, I have no dehumidifier or any form of heating, only insulated walls / ceilings and carpet tiles.
Outside temp 0
Garage temp 38 F
Garage humidity 69%
dewpoint is 29 (going on the online calculator)
Looking at the graph below, I’m within the recommended storage area.
Have I worked this out correctly ?
Edited by Craig Jezz (31/01/19 08:31 PM)
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
Top
#557044 - 31/01/19 08:57 PM Re: Garage Humidity [Re: IvorMog]
PHZI Offline
Is it me?
Non insulated garage, no floor tiles, no dehumidifier. Cover my cars with breathable outdoor cover. No problem!
Top
#557045 - 31/01/19 09:08 PM Re: Garage Humidity [Re: PHZI]
Craig Jezz Offline
Loc: Oxon
Originally Posted By PHZI
Is it me?
No problem at all if you want to keep your Morgan outside.
Craig Jezz
Top
