Who's Online
5 registered (DCH, SFG, RJW, planenut, MPS65), 37 Guests and 14 Spiders online.
Sunny Shropshire!
As Ordered
Spring in Norway
Vehicle Lifts
When Your Wife Understands You...
Happy St George's day
by Neptune
51 minutes 42 seconds ago
2018 +4 GDI engine - metric or imperial?
by xc68anc
58 minutes 7 seconds ago
Paint code please 2012 Black
by SFG
Today at 10:02 AM
Google search
by Gambalunga
Yesterday at 10:38 PM
Morgan Simulator
by milligoon
Yesterday at 08:51 PM
Snake Pass
by Phil1953
Yesterday at 06:57 PM
X100 MOG
by Peter J
Yesterday at 02:43 PM
Andy Hatch, Toyracer59, Roxy Plus4, RobCol, Rsglush
6471 Registered Users
Shout Box
Forum Stats
6,471 Registered Members
33 Forums
34,849 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Lance
Page 3 of 4 < 1 2 3 4 >
Topic Options
#557056 - 31/01/19 10:31 PM Re: Garage Humidity [Re: IvorMog]
SALMO Offline
Loc: Mercia, UK
Hi everyone,
Many many years ago MMC told me an airy garage was ideal, a car port even.
So,I bought an Airflow chamber and it seems to work for me.
Discs do not yellow up and bodywork dries up if the car goes in wet (a seldom ocassion).
Keeps dust off too, and the odd small ltem that falls from a nearby shelf.
_________________________
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Top
#557060 - 31/01/19 11:01 PM Re: Garage Humidity [Re: IvorMog]
Esprit Offline
Many years ago I recall advice in a motoring journal that a car port was better than a garage as it allowed air to circulate.
Tom
2018 Plus 4
Top
#557102 - 01/02/19 09:05 AM Re: Garage Humidity [Re: IvorMog]
Tresco Offline
Loc: Thatcham
Would be nice to have a garage but ours is outside and in the winter is in one of these https://www.autopyjama.com/permabag-engl/cars/ which keeps it around 60% humidity and comes out looking as good as it went in and from September last year it is also under one of these https://rolloutcovers.co.uk so now has double protection.
Ian
70th Anniversary 4/4 Edition (1976)
Top
#557117 - 01/02/19 10:04 AM Re: Garage Humidity [Re: Tresco]
Michael P Offline
Loc: Vienna, Austria
The relative air humidity is very strongly dependent on the temperature.
100% r.h. at 0°C corresponds to approx.
70% at 5°C,
50% at 10°C and
35% at 15°C.
For details see here.
Unfortunately, I did not find a diagram with English lettering blush (simply search for Mollier diagram or h-x diagram).
The diagram is a bit confusing at first glance.
If you want to know which humidity at a certain temperature corresponds to the value at another temperature, simply proceed as follows:
In the graph, find the intersection of the initial temperature (red line) and the initial humidity (blue line) and then go down or up along the vertical (gray) line to the desired target temperature. From this intersection, follow the blue line > target humidity.
This diagram also shows when air of a certain temperature and humidity condenses during cooling. Simply follow the grey line down to the intersection of the blue line for 100% humidity.
I would try to avoid a relative humidity above 70%. Good ventilation is usually sufficient.
Dehumidifying air is a fairly energy-intensive process. If you decide to dehumidify the air, you should make sure that the room to be dehumidified is well sealed - otherwise you dehumidify the ambient air wink
Michael
2018 Plus 4 Sport
Top
#557122 - 01/02/19 10:18 AM Re: Garage Humidity [Re: Esprit]
Ray Offline
Loc: Llanelli
. My cars live in an older metal roofed garage with plenty of drafts.does not seem to have an averse effect on them, exept for some condensation drips in cold weather. Biggest problem is warming it enough to work in winter even with a pot belly stove.
Top
#557129 - 01/02/19 10:42 AM Re: Garage Humidity [Re: Ray]
JCK Offline
Loc: Massachusetts, USA
I keep my car in Massachusetts where summer.rs are hot and humid and winters extremely cold and dry. I don't drive the Morgan in winter because of the cold and the salt and other c**p on the roads. I rent a garage because I don't have one at home. Last year's garage let water in frequently but wasn't ventilated. This year's is concrete, dry, and extremely well ventilated. I am much more relaxed.
JCK
1960 Plus 4 Roadster
Top
#557151 - 01/02/19 11:38 AM Re: Garage Humidity [Re: IvorMog]
Neilda Offline
Loc: Surrey. UK
My cars live in an oak barn - which suffers from less condensation than brick built garages I've had in the past. I run a dehumidifier... a £200 thing I bought years ago and it's permanently on. I've no idea if it's effective, but I have no rust on tools or cars.
I am told that heating a garage is a bad idea as that does promote condensation.
+8 4.8
Top
#557175 - 01/02/19 01:08 PM Re: Garage Humidity [Re: Craig Jezz]
Michael P Offline
Originally Posted By Craig Jezz
Outside temp 0
Garage temp 38 F
Garage humidity 69%
dewpoint is 29 (going on the online calculator)
Looking at the graph below, I’m within the recommended storage area.
Have I worked this out correctly ?
It's correct. At a relative humidity of 69% at 38°F, the dew point is 29°F (the outside temperature is irrelevant for the calculation). According to the graph this is in the recommended range.
Michael
2018 Plus 4 Sport
Top
#557180 - 01/02/19 01:22 PM Re: Garage Humidity [Re: Craig Jezz]
PHZI Offline
Originally Posted By PHZI
Is it me?
Non insulated garage, no floor tiles, no dehumidifier. Cover my cars with breathable outdoor cover. No problem!
No problem at all if you want to keep your Morgan outside.
Inside my garage actually.
Top
#557190 - 01/02/19 01:47 PM Re: Garage Humidity [Re: PHZI]
Craig Jezz Offline
Loc: Oxon
Is it me?
Now that is a good idea 👍
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
Top
