Morgan Aero 8
8 registered members (KEVFITZ, HeadlessBlue, teifistar, Alistair, Mogdavid, David Gibson, milligoon, MOG 615), 138 guests, and 15 spiders.
+8Rich 256
John V6 149
CooperMan 109
false center nut for motolita steering wheel
by nestor59310. 23/08/19 11:00 PM
Air Filter Cover Made in Belgium
by nestor59310. 23/08/19 10:39 PM
Wood colors of "New dashboard design"
by Marmota. 23/08/19 08:56 PM
New member in Madrid, Spain.
by Marmota. 23/08/19 08:30 PM
Toe be or not toe be.
by griffo. 23/08/19 04:18 PM
is this clutch worn out ?
by thono. 23/08/19 11:57 AM
Anyone Following the Test Match?
by Budster. 23/08/19 11:52 AM
Roads less travelled  2
Mk 2 tool tray
Roads less travelled..?
My Morgan related badges
North Coast 500
OhioM3W, Gandalf1, BigLes, Lenmog, TVRWill
6660 Registered Users
Forums33
Topics35,954
Posts580,485
Members6,660
Most Online459
Aug 3rd, 2019
No Birthdays
DAB antenna q #558066
05/02/19 02:57 PM
05/02/19 02:57 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Afternoon all,
Is there a DAB aerial/antenna available that will fit behind the dash (i.e. with the stereo and all the wiring gubbins) without needing to be routed somewhere?
I ask as most antenna I have seen are screen mounted which won't work with the heating elements, and I don't want anything visible from the inside ideally. Any suggestions would be appreciated.
If not I shall use the DAB radio app on my phone via Bluetooth instead cheers
Aero 8 S1
Re: DAB antenna q [Re: NickCW] #558068
05/02/19 03:21 PM
05/02/19 03:21 PM
East Harling, Norfolk UK
Richard Wood Offline
Do you have an FM/AM car aerial used in conjunction with FM/DAB radio?
If so there are various splitters on the market which offer an amplified DAB aerial signal. Power for this can come from radio itself depending on model or the main radio 12 volt feed.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: DAB antenna q [Re: NickCW] #558071
05/02/19 03:37 PM
05/02/19 03:37 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Thanks Richard.
I have a main FM/AM aerial from the Aero, the Headunit is an Alpine and has two inputs, FM/AM and DAB.
I am off to Halfords now to pickup another adaptor, whilst there I will see if they have anything suitable as I am not entirely sure which one is best.
Aero 8 S1
Re: DAB antenna q [Re: NickCW] #558073
05/02/19 04:04 PM
05/02/19 04:04 PM
eBay are a good source for these adaptors. I bought mine in advance of Sony radio which required an external 12 volt feed (powered aerial feed on radio loom is useful supply).
Later found there was a dedicated Sony adaptor available which the radio could power itself if so configured on setup menu. Just ensured this was turned off and had it wired as suggested above. All wiring hidden of course.
One caveat - ensure the adaptor is pre-wired with plug to match DAB aerial connector on radio - there are two or three variants although tiny aerial adaptors are available.
Re: DAB antenna q [Re: NickCW] #558084
05/02/19 04:40 PM
05/02/19 04:40 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Thanks Richard,
Just searching on Amazon now as Halfords don't do them.
Trying to work out the correct one is a minefield though as I have no idea what the relevant dab connectors are called, or whether or not the Aero has an "amplified" aerial?
Aero 8 S1
Re: DAB antenna q [Re: NickCW] #558090
05/02/19 05:04 PM
05/02/19 05:04 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
Someone posted about the 12V splitter on this forum only a few weeks ago
I’ll try and find the link
2008 Bugatti Blue Roadster 4 Seater
Re: DAB antenna q [Re: NickCW] #558091
05/02/19 05:09 PM
05/02/19 05:09 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
http://www.talkmorgan.com/ubbthreads.php/topics/554143/Re:__Fitting_a_radio_and_lugga#Post554143
Check out the post by Teknome
Re: DAB antenna q [Re: NickCW] #558100
05/02/19 05:39 PM
05/02/19 05:39 PM
Salisbury Plain
Gareth H Offline
Gareth H  Offline
Salisbury Plain
I had an alpine head unit fitted to mine, the standard leccy aerial was used for dab reception as well as AM / FM, all worked fine
Gareth
Aero 8
R Nine T
335d
BMW Power!
Re: DAB antenna q [Re: NickCW] #558101
05/02/19 06:06 PM
05/02/19 06:06 PM
Originally Posted By NickCW
Thanks Richard,
Trying to workout the correct one is a minefield though as I have no idea what the relevant dab connectors are called, or whether or not the Aero has an "amplified" aerial?
Nick, have forgotten the names of likely connectors but one is a push fit to radio and the other a small screw thread. I had to buy a tiny adaptor as my lead came with screw type.
BTW the DAB amplifier is within the splitter and nothing to do with OE Aero fit.
Re: DAB antenna q [Re: Stewart S] #558113
05/02/19 07:15 PM
05/02/19 07:15 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Thanks Stewart!
Do you happen to know which of the 5 listed below is correct? Ideally I was hoping for one that is powered from the head unit as I believe you can get?
https://www.dabonwheels.co.uk/product-category/dab-car-aerials/dab-aerial-converters/
Thanks Richard,
Thanks Richard, good to know I can adapt if necessary!
Aero 8 S1
Moderated by  Aeroman, Simon
