19 registered members (BertR, Marmota, Lance, +8Rich, DCH, Craig Jezz, Gordon D, Rog, Gambalunga, bmgermany, Richard Wood, Morph, petemog, PaulV, MJF, Treesurveyor, David_E, N22MOG, Image), 156 guests, and 15 spiders.
John V6 475
+8Rich 386
TBM 247
Heinz 199
Reassurance for the over 60s
by Peter J. 29/05/20 04:36 PM
Bonnet locks
by Marmota. 29/05/20 02:27 PM
What about Brexit/climate change etc.?
by Luddite. 29/05/20 02:17 PM
My Latest ‘Poverty’ Solution
by Budster. 29/05/20 10:03 AM
After sales.
by Obie. 29/05/20 09:24 AM
rear brakes - again
by Grumpy2. 29/05/20 08:34 AM
Covid-19 Lung Transplant
by Gambalunga. 29/05/20 08:03 AM
Plus four Test Drive
Engine running!
Slow progress
Social distancing
Somewhere in Scotland?
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,357
Posts628,498
Members6,938
Most Online1,033
Dec 28th, 2019
Mogcollector
Main Fuse #558843
09/02/19 04:41 PM
09/02/19 04:41 PM
I
IcePack Offline OP
IcePack  Offline OP
I
Interesting article in MOG magazine this month re main fuse corrosion & failure.
I did not know there was one as have never seen it, despite changing the battery fairly recently. In terms of servicing & preventative measures, what would my learned friends recommend to prevent/arrest any corrosion. My first thought is WD40, but I know long term it can actually attract moisture. Not sure of using ACF50 on an electrical component either.
Thanks
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Main Fuse [Re: IcePack] #558856
09/02/19 05:21 PM
09/02/19 05:21 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
I use Dow Corning MS4 grease as I have some left over from a previous occupation but this stuff is half the price with the same electrical properties. It also has the side effect of making the fuses easier to pull and replace.
silicon grease
In a similar preventative vein if you have the new type electronic pcb behind your dash it's well worth giving it a good coating of this conformal coating to prevent an expensive happening when the water finds it's way in there. conformal coating
This prevented a disaster when the licquorice tubing washer pipes fell off soaking it all on my 4/4 Sport.
Regards Richard
1994 Connaught Green +8 prev
Re: Main Fuse [Re: IcePack] #558861
09/02/19 05:38 PM
09/02/19 05:38 PM
East Sussex, ENGLAND
andymot Offline
andymot  Offline
ACF50 is fine for electrics and is just what I'm going to use on the said fuse - after reading the Mog article.
I have used it on fuseboxes ( cars - not domestic!) and even PCBs on old Rover sat-nav units where water ingress is possible/likely.
Re: Main Fuse [Re: IcePack] #558871
09/02/19 06:22 PM
09/02/19 06:22 PM
Essex
Burgundymog Offline
Burgundymog  Offline
Essex
Thanks
You should speak to Cain who had a catastrophic failure of this nature on the Wolf Cafe Racer on an unlit stretch of the A14 at night.
Keith
2013 narrow bodied + 4 Ruby.
Re: Main Fuse [Re: IcePack] #558905
09/02/19 08:59 PM
09/02/19 08:59 PM
Mandello del Lario
Gambalunga Online content
Gambalunga  Online Content
Mandello del Lario
Which fuse is this and where is it located?
Photo?
Re: Main Fuse [Re: Gambalunga] #558917
09/02/19 10:30 PM
09/02/19 10:30 PM
East Harling, Norfolk UK
Richard Wood Online NoMood
Photo?
On the latest +4 and Roadster (maybe 4/4) there are two approx 35mm2 red cables from battery positive terminal. One feeds stater motor directly and the other the common positive battery stud at front of car via an 80 amp maxi fuse in holder located close to battery. These two cables follow a similar path to the front, secured internally to wood frame underneath right hand door.
On mine the fuse is clearly visible when the battery access plate is removed.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Main Fuse [Re: IcePack] #558926
09/02/19 11:15 PM
09/02/19 11:15 PM
I
IcePack Offline OP
IcePack  Offline OP
I
+8Rich thanks for those links. Andy thanks for info on acf50.
I still have to find my fuse it seems well hidden. I will be lifting the tool tray next week & will have a look then.
Re: Main Fuse [Re: IcePack] #558930
10/02/19 12:03 AM
10/02/19 12:03 AM
Mandello del Lario
Mandello del Lario
Thanks. I too will check it out in due course.
Re: Main Fuse [Re: +8Rich] #558940
10/02/19 08:24 AM
10/02/19 08:24 AM
London
MOG 615 Offline
MOG 615  Offline
London
silicon grease
Rich
Conformal coatings are a great idea providing that you are sure that the substrate is 100% clean. I used to work in the chemical cleaning industry and we sold far more chemicals to help people try to remove conformal coatings because they had trapped water or dirt behind them than we did cleaning fluid to clean the PCB in the first place. Because the coating is designed to stick , it is the very devil to remove entirely and most of the components ended up being used for spares only.
The other issue is that once applied any maintenance of the electronics is impossible, so dry joints etc became an issue.
Andy G
1999 +8 , Indigo Blue.
Re: Main Fuse [Re: IcePack] #558969
10/02/19 10:11 AM
10/02/19 10:11 AM
Durham, UK
smudger1 Offline
smudger1  Offline
Durham, UK
Just a word of caution. WD40 has excellent insulating properties ( which is why people spray HT leads to stop electrical tracking in wet weather). If you get this on an electrical contact i.e. Fuse and Fuse Holder there is every chance you will eventually end up with a high resistance.
There is a copper rich grease available ( not coppaslip) which is specifically designs to preserve / prevent water ingress which is used in the marine environment but my old brain has ran out out of memory but I'm sure one of you can find it online.
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
Moderated by  Aeroman, Simon
