11 registered members (NZPlusSix, +8Rich, Nick55, B3MOG, Alpha1, BobtheTrain, C2RM, Paul F, Roger*, bmgermany, Brian G),
88
guests, and 23
spiders. |
Topics43,869
Posts738,852
Members8,072
Most Online1,033 Dec 28th, 2019
Re: M3W GP Week on The Isle of Man 2020 (not TT week)
[Re: chocadoodledoo]
#746625
02/07/22 05:44 AM
02/07/22 05:44 AM
atalante83
#746626
02/07/22 05:46 AM
02/07/22 05:46 AM
atalante83
#746627
02/07/22 05:47 AM
02/07/22 05:47 AM
atalante83
#746628
02/07/22 05:48 AM
02/07/22 05:48 AM
atalante83
#746658
02/07/22 03:04 PM
02/07/22 03:04 PM
Posts: 76 Greensboro, NC, USA
sbarracl
Greensboro, NC, USA
Looks like a great time. Fantastic photos - thanks for sharing.
Scott
2018 M3W 1995 Porsche 993
#752073
14/08/22 07:58 AM
14/08/22 07:58 AM
Posts: 1,466 Oxon
PaulV
Oxon
Just completed my IoM trip! After spline repairs (and a preventative regulator change) at Phil’s in Lancaster I collected the M3W for a hot drive South (29C in Lancaster, 31C Telford etc) via M6, A49, A41, A44… car back in the garage by 10pm!
[Re: PaulV]
#752148
14/08/22 05:53 PM
14/08/22 05:53 PM
Posts: 634 Grindelwald Switzerland
Laurens
Just completed my IoM trip! After spline repairs (and a preventative regulator change) at Phil’s in Lancaster I collected the M3W for a hot drive South (29C in Lancaster, 31C Telford etc) via M6, A49, A41, A44… car back in the garage by 10pm! Hi Paul, Can you explain your spline repair ?
[Re: Laurens]
#752149
14/08/22 06:16 PM
14/08/22 06:16 PM
Posts: 1,466 Oxon
PaulV
Oxon
...After spline repairs (and a preventative regulator change) at Phil’s in Lancaster ... Hi Paul, Can you explain your spline repair ? Hi Laurens - my spline was repaired (I believe) per 2) in Phils post on the 5 speeder crankshaft ... Phil did show me there was a slight concave in the S&S spline faces which reduced the contact area! My thanks again to Phil for sorting the fix and spending the time to explain it to me, as well as sorting a quick-fix kit for my old regulator (ie ready to fit!). 2/ if the splines on the shaft are more severely damaged then fit a second undersize hub but filing the damaged shaft splines in order to recover the original shape as far as possible - it should be noted that in this case the nitrided hard skin will be compromised and so a good tight fit is even more important
