3 registered members (twotribes, Nick55, +8Rich), 108 guests, and 14 spiders.
+8Rich 273
John V6 169
15 months to the day...
by 3Gs. 21/08/19 07:34 PM
It’s Coming !
by sospan. 21/08/19 03:33 PM
Another M3W Exhaust Supplier
by Rog G. 21/08/19 03:12 PM
BHM Plus 6 Test Drive
by RBW. 21/08/19 01:44 PM
A real Porker
by +8Rich. 21/08/19 01:22 PM
Oil leak
by ADM3W. 21/08/19 12:51 PM
"SPORTY" exhaust note ...
by dmh. 21/08/19 12:21 PM
My Morgan related badges
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,930
Posts580,132
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
Workshop Note: S1 Roadster Mulfab Brake Upgrade #559373
12/02/19 02:58 PM
12/02/19 02:58 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Two garage days presented themselves, so I lost no time in getting on with my front brake upgrade.
A few weeks ago, I did a rear brake inspection, and changed the rear flexible hose, and brake fluid in that circuit in readiness.
First a preamble. Ten years ago, not long after bringing my Roadster home, I discovered that the front nearside hub nut was extremely tight on the threads. Hub nuts should be hand tight after being loosened, but this one was spanner tight all the way off. It's what happens if you over-tighten, it distorts the threads on the hub.
I lived with that ever since, knowing that it needed sorting out. So a week or two ago, I bought a replacement hub assembly from MWS. The first thing I did was to try the hub nut on the new hub, and I found that it wound on all the way, by hand. This confirmed to me that the problem was with the old hub assembly.
The snag is that the new hub comes without bearings, which means either buying new bearings or extracting and refitting the old ones. Being tapered, the outer bearing drops out, and the much bigger inner bearing also drops out, once the oil seal is persuaded to come out. This has a thin metal outer cover, so needs care.
What's left is the two inner tracks. Normally, when replacing with new, I would drift the old ones out and fit the new ones using the old as buffers. Anyway I took extra care drifting these metal rings out, but I don't have a suitable puller, so it involves hammer action. They are very hard so deal with shocks quite well.
I heated up the new hub to help fit the new bearing tracks. The outer one is easy enough as a socket can be used with a threaded ro to pull it into place. The inner track is more problematical, as it's large diameter, so I had to resort to drifting in using a hammer, and soft(ish) punch. This one doesn't fit so far into the hub so went OK in the end.
This is a view you don't often see......the new hub in the back of the wheel........
I might try adopting the old hub to carry the spare wheel. It needs a spacer of 2", and would allow use of a proper hub nut , but doesn't work with a luggage rack.
Pressing in the outer bearing track........
Starting with the nearside....the original Lockheed Caliper with Greenstuff slotted and grooved discs, which are showing signs of lack of use........
New and old.....these discs are amazing. Well engineered and an interference fit into the hub. Secured with five nuts & bolts.
Now the side you don't see....there are no instructions, but the assembly is self evident. The five threaded holes visible here are for cars which use a hub mounted speedometer sensor. In this case you would need to fit five short bolts into those holes. I've given everything a light smear of ACF50, except the disc faces of course.
The caliper.......
Pads in place. Held by two through pins and R clips, plus wire spring clips as an antirattle. Those R clips do like springing away if you let them!!!
And assembled. The old caliper is still plumbed in at this stage. Connecting the brake pipe was my final job. Amazingly not one drop of fluid came out while doing this. Usually there's a drip drip drip, when you break the circuit. There are two bleed nipples on each caliper. I didn't notice the inside one to begin with. Obviously the nipples are mounted at the top!
More to follow.......>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559376
12/02/19 03:12 PM
12/02/19 03:12 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Part 2......................
Next the offside.......
This shows the inner bearing and oil seal.........
Caliper and pad details....
Fully asembled....
Too nice to use really!!!
Problems? Not really. I nearly lost an R clip when it made a bid for freedom. I missed the fact that there were two nipples per caliper, but the pedal came straight back anyway. When I'd finished the nearside I bled that side before staring on the offside.
I ended up bleeding more than I needed due to not double checking the rear flexible. It had a tiny leak at the union on the axle, so when everything was done, the pedal was very slowly sinking under pressure.
It almost got me thinking that the master cylinder needed re-rubbering. Having double checked all the front connections, I then found a damp patch on the axle and breathed a sigh of relief!
All done the old fashioned way with my bleed tube from 1972, which has just split and is no longer useable......
I can't wait to road test all these changes, but it looks like being the weekend before I can get out.
So you'll have to wait for the verdict on this, the Panhard Rod, and the Steering Damper!! grin2 thumbs
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559379
12/02/19 03:28 PM
12/02/19 03:28 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Looks good Dave. I hope it is an improvement.
2006 Indigo Blue Roadster S1
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559381
12/02/19 03:32 PM
12/02/19 03:32 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Data:
Bearing outer: NTN 4T-LM 11910 USA-D LW
Bearing inner: NTN 4T-LM 67010 USA-D MW
Oil Seal: 8B2-1.750 2.500 0.375 CNO 04114
Brake pipe inner wing: Pipe nut: 13mm. Under wing 16mm; Engine bay 17mm.
Hub nut: 1&3/16ths"
Caliper bolts: 19mm or 3/4"AF
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559392
12/02/19 04:48 PM
12/02/19 04:48 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
looks good Dave
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559402
12/02/19 05:50 PM
12/02/19 05:50 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
A clear and lucid description, as usual.
I always felt the Roadster's brakes on the one we had were a bit underwhelming. They worked, but lacked feel.
I'm sure your new calliper and brake combination will be much better!
Tarka the 'Otter Mog
2014 Plus 8
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559403
12/02/19 06:02 PM
12/02/19 06:02 PM
Taunton
deano Offline
deano  Offline
Taunton
Great account of your upgrade Dav. Looking forward to your feedback on the level of braking lmprovement.
Martin (Deano)
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559434
12/02/19 07:30 PM
12/02/19 07:30 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
When I converted My +8 Bitsa from Girling 2 puck to 300MM Wilwood 4 puck I improved the braking a lot. It was interesting, the procedure Wilwood specifies to break in the rotors and then a different procedure to break in the Wilwood pads. The rear drums are Chevy S10 (a little larger than Morgan issue) and have Porterfield linings. I used Wilwood because it is a U.S. Product. It required a bit of machining to install. If UK buy a UK product
Button
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: Button] #559437
12/02/19 07:35 PM
12/02/19 07:35 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
BTW: The calipers scraped on the inside of the wheel. I used spacers to gain clearance. Make sure the wheel studs are long enough to do their jobs.
Button
Re: Workshop Note: S1 Roadster Mulfab Brake Upgrade [Re: DaveW] #559496
12/02/19 10:55 PM
12/02/19 10:55 PM
London
MOG 615 Offline
MOG 615  Offline
London
Dave
Great diy guide as ever .
I must admit to being unclear as to whether you replaced the old bearings with new?
The high spec billet calipers must have changed slightly over time. Mine have the 2 pins and 2 "R" clips but the anti-rattle strips are not present.
I find that bleeding the calipers is best done starting with the inside nipple first and then working to the outside. I have found them quite sensitive to this procedure and even a small amount of air seems to give an "soft" pedal.
Andy G
1999 +8 , Indigo Blue.
Moderated by  Aeroman, Simon
