7 registered members (madmax, Quicksilver, stumog, RJW, Andy, Tresco, DCH), 194 guests, and 9 spiders.
+8Rich 244
Hamwich 139
Peter J 111
Image 111
Retromobile Paris 2020
by nestor59310. 18/02/20 10:52 PM
Nice day for it
by Landy. 18/02/20 09:18 PM
Damp membrane and fuel line
by Image. 18/02/20 06:29 PM
Airbag
by DanT. 18/02/20 02:25 PM
Ford mustang gt500
by madmax. 18/02/20 11:13 AM
carburettor
by swordfish. 17/02/20 11:39 PM
Non-MOG spares?
by Skalman. 17/02/20 06:15 PM
Mild winter en Provence
A few more NZ pics
Travels in New Zealand
Crovie and Gamrie, North East Scotland.
M3W artwork
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,280
Posts605,676
Members6,829
Most Online1,033
Dec 28th, 2019
Duke, SteveH
Re: Main Fuse [Re: MOG 615] #558974
10/02/19 10:24 AM
10/02/19 10:24 AM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Originally Posted By MOG 615
Originally Posted By +8Rich
I use Dow Corning MS4 grease as I have some left over from a previous occupation but this stuff is half the price with the same electrical properties. It also has the side effect of making the fuses easier to pull and replace.
silicon grease
In a similar preventative vein if you have the new type electronic pcb behind your dash it's well worth giving it a good coating of this conformal coating to prevent an expensive happening when the water finds it's way in there. conformal coating
Rich
Conformal coatings are a great idea providing that you are sure that the substrate is 100% clean. I used to work in the chemical cleaning industry and we sold far more chemicals to help people try to remove conformal coatings because they had trapped water or dirt behind them than we did cleaning fluid to clean the PCB in the first place. Because the coating is designed to stick , it is the very devil to remove entirely and most of the components ended up being used for spares only.
The other issue is that once applied any maintenance of the electronics is impossible, so dry joints etc became an issue.
Andy
Interesting and valid points, when I was using it professionally it was on clean PCB's that were exposed sometimes to a marine environment and it was very effective but they were small replaceable units and non repairable.
The spraying of the Morgan PCB seemed to have saved my bacon (£500 if in stock) so I guess I was lucky in that the area was clean. Thanks for the information.
I did once try and clean off a PCB with this applied and it was not an experience I would care to repeat, I think the Morgan PCB are non serviceable items - I could be wrong.
Regards Richard
2009 4/4 Sport Green
1994 Connaught Green +8
Re: Main Fuse [Re: IcePack] #558991
10/02/19 11:00 AM
10/02/19 11:00 AM
East Harling, Norfolk UK
Richard Wood Offline
It seems the main (maxi) fuse suffers from its damp and dirty location. It does/should have a cover though.
Checking the integrity of same and sealing out the damp should pay dividends without affecting the actual fuse contacts.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Main Fuse [Re: IcePack] #559118
11/02/19 12:43 AM
11/02/19 12:43 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Seem to recall Dave W. finding an unexpected main fuse behind the dashboard on one of his Mogs a few years back, which was half out. He secured it with a cable tie.
Doug
2011 +4 in Rich Maroon
Re: Main Fuse [Re: IcePack] #559140
11/02/19 08:54 AM
11/02/19 08:54 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
That was Mr Bumble (2012). The main fuse was up in the top right corner under the dash.
On my Roadster, its next to the battery behind the nearside seat.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Main Fuse [Re: IcePack] #559285
11/02/19 11:35 PM
11/02/19 11:35 PM
E
Esprit Offline
Esprit  Offline
E
Dave, what is your recommendation for protecting this fuse please? We don't seem to have a consensus view on this thread. I assume / hope that failure of the main fuse is rare. Cain's experience sounds alarming!
Tom
2018 Plus 4
Re: Main Fuse [Re: IcePack] #559307
12/02/19 08:20 AM
12/02/19 08:20 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I'm reasonably relaxed about this Tom. My Roadster has the main bank of fuses on the bulkhead. Recently I pulled them (eight) and just polished the contacts, which were slightly tarnished.
The bank of twenty fuses under the dash is hard to get at so I only go there when I have to, such as when the horns stopped working.
The single main fuse in the rear cavity I would only check if I was in there.
I found the problem under the dash of Bumble (2012 4/4 75th Anniversary) when I was tracing a hiccup in the engine over bumps. The fuse was half out of the holder and I added cable tie to hold it in. That wasn't the cause of the problem though, which was a loose connection on the engine.
Re: Main Fuse [Re: IcePack] #559316
12/02/19 08:55 AM
12/02/19 08:55 AM
Sumerset
Rog Offline
Rog  Offline
Sumerset
It does seem quite vulnerable just poked in the corner next to the wheel. Perhaps a squirt of acf50 before putting it in a small but rugged plastic bag and securing around the cables with a couple of zip ties might help?
Roger
Re: Main Fuse [Re: Esprit] #559321
12/02/19 09:29 AM
12/02/19 09:29 AM
I don't think there can be one size fits all answer to fuse issues Tom. This due to variation on location of main fuse if one is fitted at all. All the latest cars have this fuse located close to the battery which makes sense as it offers protection to the cable as a whole. Ironic that there is a similar cable direct to starter with no fuse at all, although this is the norm. Fusing for the stater circuit would require a very large fuse in the order of 100's of amps and add unreliability. Fortunately the physical size hence rigidity and thickness of insulation on such cables, together with care in routing makes them less vulnerable.
It should be noted that only in the past few decades battery located fuses were added to cars in general. The fuse is there to protect the cable and attached equipment assuming as with most, they don't have their own internal fuse.
Careful routing and physical protection of cables is just as important as fusing them. Interesting to note my 55 year old Land Rover managed with just two 30 amp fuses and still retains the original loom although past its sell by date wink
Since the 90's most cars use blade type fuses which come in a range of physical sizes. Current Morgans use the mini type with the exception of the maxi battery fuse. Although blade fuses fair better long term than the various earlier types, they do benefit from simply being removed and replaced as the method of contact offers a self cleaning action. If the fuse slides in too easily its socket is worn or damaged. It may be possible to very carefully bend the socket contacts but otherwise replacement required. Dave's issue mentioned above springs to mind.
Finally be wary of squirting any product in the direction of fuse contacts if it has insulating properties.
Re: Main Fuse [Re: IcePack] #559501
12/02/19 11:24 PM
12/02/19 11:24 PM
E
Esprit Offline
Esprit  Offline
E
Richard, thanks for taking the time to write such a full reply. I suppose there is always the risk of a failure, and additional protection and good maintenance are just reducing that risk. It could be that my X3 has a main fuse and I've been blissfully unaware of it but I feel a bit more vulnerable in a Plus 4 of course.
Tom
2018 Plus 4
Re: Main Fuse [Re: Rog] #559507
13/02/19 06:48 AM
13/02/19 06:48 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
IMO, unless you can hermetically seal the plastic bag around the cables, (near impossible), then it is likely to do more harm than good. Any water that enters, or condensation that might occur will not be able to escape, and corrosion may be worse than if left open to the air.
Doug
Moderated by  Aeroman, Simon
